Same issue here Brad on Win10/Chrome. Can't get any of the waypoint or POI properties to display in the pop-up box like normal. Basically non-functional right now.
"The waypoint/poi window is supposed to pop up when clicking an object?"
It is suppose to,
I have been fighting that problem for about a year.
I have a few posts on it, nobody has had an answer.
Try this...
#1 Refresh the browser. (F5)
#2 Delete history from the browser, try the cache first if that fails erase all history.
#3 If you are deleting all history do not have a mission open.
#4 If you still have issues, start form main Litchi screen (web sight) press refresh, then click the link to go to the hub, press refresh then before you open a mission.
#5 Then open your mission.
#6 I usually get it to work...
Rod
I'd like to know what they mean by one decimal accuracy. I don't believe that's possible. Can someone explain this?BTW, I'm not sure why there's a need for one decimal of precision on altitudes.
Mission Hub appears to have been fixed overnight.
Not for me then, I have tested right now with Chrome and Firefox and still doesn’t appear the POI window pop up and when moving waypoints the map is moving without stop.
I have test also to delete history and reset but it doesn’t work either.
Thanks guys it was working for me yesterday, I brought up the hub, checked my only mission that has POI's, saved it to view in GE.
Looked safe than I ran the mission.
When I posted my fix, that mission was still open.
This morning the hub is not working for me ether with FF, Win 7.
Rod
Hum, the only thing I can add, is when I open a litchi hub after clearing cache, the browser would ask if it could use your location, I would pick yes, seems like that is when it usually worked. I just tried chrome, it ask me that, still didn't work.
Rod
