@Jeff48920 Can you try to insert a ND + GR, can you adjust the GR level with the horizon when you screw the barrel completely ?
Absolutely. This is exactly what the barrel was designed to do and solves the problems I had with every other glass GR solution.@Jeff48920 Can you try to insert a ND + GR, can you adjust the GR level with the horizon when you screw the barrel completely ?
Thanks for sharing-- this is the only thing I would like to see -- se the filters can stay on in the case--
"At this point I am still working on a method to allow the barrel to remain on the camera and still lock the gimbal and fit in my cases. "
Give us an update it you determine this. cheers
If you do it, sign me up for one.I have just started to design a GimbalClamp with interchangeable rubberized (Ninjaflex) centers for use with both the barrel and CPL configurations. I will also attempt to have these fit in both the Tradecraft and DJI hardshell backpacks with either no or minimal alteration to the case.
I expect to be able to get something workable in the next few weeks. I'll keep you informed.
If I can do this I will make them available for sale in the spirit of Rainbowers' tradition and charge only my costs of design and production spread over 50 sets. The set would include an ABS shell and two different sizes (and colors) of inserts. If it works as expected I should be able to sell these for no more than $10 plus $5 shipping worldwide. Keep your fingers crossed
Sounds great. Really needed - If it works to your satisfaction I'll be appreciating a set. All the best.I have just started to design a GimbalClamp with interchangeable rubberized (Ninjaflex) centers for use with both the barrel and CPL configurations. I will also attempt to have these fit in both the Tradecraft and DJI hardshell backpacks with either no or minimal alteration to the case.
Super, that is the right spirit in the club !I have just started to design a GimbalClamp with interchangeable rubberized (Ninjaflex) centers for use with both the barrel and CPL configurations. I will also attempt to have these fit in both the Tradecraft and DJI hardshell backpacks with either no or minimal alteration to the case.
Yesterday we called factory for extra stock. For the moment no problems, shipping worldwide is normally 3 days.Still accepting orders? And how long has shipping been taking to the US?
the vignetting is due to having 3 filters stacked on top of each other. The CPL is the culprit though this issue was known when i bought the set so no worries.
If its really an issue you could shoot everything in 4k and crop the vingette out before transcoding to a lower resolution
I'll shoot some video with an ND 16 and CPL tomorrow. I haven't used the CPL/ND combination yet so I want to know also. I'll shoot in 1080 and 4K to test.I'm really considering ordering one of these sets, but I'm still curious about the vignette on that video. So if I were to only use the CPL and one of the ND filters, there won't be any vignette going on? (I'm completely new to video and filters, but trying to learn as quickly as possible.)
Otherwise I am really loving this set of filters.
The very small vignet in 16:9 mode is only because the CPL frame diameter is calculated very limit to the border. In 4:3 (photo) you have more, but of course easy to crop in post. It is showed at the end of my video and has nothing to do with stacking more filters.I'm really considering ordering one of these sets, but I'm still curious about the vignette on that video. So if I were to only use the CPL and one of the ND filters, there won't be any vignette going on? (I'm completely new to video and filters, but trying to learn as quickly as possible.)
In China we ship from Qingdao with SF (1 day delivery) and of course it will be no USD28 for shipping but RMB 25 (USD4)I also live in China... if I purchase a set would they be shipped via DHL or could you just ship them via one of the 快递 kuaidi services? I've never seen DHL trucks driving around the small city that I'm in, and kuaidi is likely much cheaper than shipping with DHL.
Where are you at in China? I'm near Zhengzhou in Henan Province.
Here are the 1080 video tests with the Polarization engaged and not. They are shot with the CPL over the ND 16 on the barrel. The 4K is giving me some trouble uploading. I'll keep trying but, in any case,the vignetting is significantly more noticeable and similar to what Rainbowers already posted. I still see nothing that would keep me from purchasing the set again. Great glass with solid performance.Thanks! I look forward to seeing if there's any vignette on there.
Guess what came a day early!!!!!
Had to be adaptive in order to get the gimbal balanced. The new zinc weights are larger than the ones in the video so, to clear the ribbon cable and still balance properly the weights on the back of the camera had to be repositioned. The 10g goes where 10g and 5g both used to go and one 5g goes on the bottom of the camera in the center.
The last 5g goes on the side as shown in the video
The balance doesn't get much better than this and is good with two filters in place.
With one filter and the CPL the balance is closer to OEM which means the camera tips forward slightly.
I cannot use my Polar Pro filters or my OEM UV filter without the gimbal pulling up and to the right when looking at it from behind.
The Polar Pro gimbal holder I mentioned earlier fits over the lens cap that comes with the set.
The fit and finish is excellent and the glass itself seems to be professional quality.
There was some earlier concerns about whether the barrel would interfere with the ground as the gimbal initializes. In 5 initializations, I experienced no interference.
I also experienced no interference between the barrel and the UAVbits camera guard. I expected there would be some big issues but there were none.
I do expect interference when using the CPL filter but have not had the time to look into that yet.
Kind of a cloudy day here but I did shoot a little video in LOG at 1080/30. I had no problem setting the camera to 60 with the ND 16 installed.
So far I am a very happy camper. I will try to upload some raw footage later tonight.
For those interested in a video sample of the vignetting, it will be available at Youtube as soon as Youtube finishes the processing.
Because the interest was in the vignetting and not in the glass quality I did not use super high quality so the video is somewhat compressed. Hope this helps. As you can see from the cropped 4K video (which was cropped from the video just before it) the vignetting provides very little to worry about. I still believe this is the most useful and highest quality set of filters I have bought and I have purchased filters from 3 different vendors besides Rainbowers.
HiJeff48920,
Can you please post few pictures of how you have added the weights? Are you using all the weights?
