- Joined
- Oct 30, 2014
- Messages
- 31,958
- Reaction score
- 10,786
- Location
- Harrisburg, PA (US)
- Website
- phantomhelp.com
Detailed comparison of commonly used ND filters (for the Phantom 3 & Phantom 4)
Overview
The goal of this thread is to compare the size, weight, type, and quality of commonly used ND filters for the Phantom 3. Since there isn't one best filter for every situation, this comparison should help everyone choose a filter that works best for them.
Since filters from the same sets have the same build quality, only one filter from each filter set was considered. Here's a list of the filters compared below:
Close-Up Photos
DJI UV (screw-on stock filter)
DJI ND8 (screw-on)
Anbee/BTG ND16 (screw-on)
DitzCo ND8 (slide-on)
Freewell ND2-400 (screw-on adjustable)
Mudder ND2-400 (screw-on adjustable)
Neewer ND16 (screw-on)
Polar Pro ND8 (screw-on)
Polar Pro ND8 (slide-on)
SRP ND16/CP (slide-on)
TACO-RC ND16 (screw-on)
ND Filter Specs
Color & Sharpness Comparison
The following photos were taken indoors to ensure the same lighting was used for each photo. The Phantom was not designed to take detailed close-up photos, but it's a great way to compare the color and sharpness produced when using various filters.
Note: The color differences above aren't really that important if you're planning on editing your photos/video in a program like Adobe Lightroom or Adobe Premiere.
Likes & Dislikes
While these filters all produce nearly the same end result, here are some things that set them apart:
Tips
Overview
- DJI UV (screw-on stock filter)
- DJI ND8 (screw-on)
- Anbee/BTG ND16 (screw-on)
- DitzCo ND8 (slide-on)
- Freewell ND2-400 (screw-on adjustable)
- Mudder ND2-400 (screw-on adjustable)
- Neewer ND16 (screw-on)
- Polar Pro ND8 (screw-on)
- Polar Pro ND8 (slide-on)
- SRP ND16/CP (slide-on)
- TACO-RC ND16 (screw-on)
- Most can be purchased on Amazon and/or eBay
- They are commonly discussed in forums on the Internet
- They have good reviews, so you should also have a good experience if you choose one of these brands
- Glass filter: This is the most common type of filter. It has a single glass lens and is only designed to be used in a specific lighting condition (e.g. cloudy, sunny, sunrise/sunset). These filters often come in sets since one is not right for all situations.
- Gel filter: This filter has a thin, flexible plastic lens. Since the lenses are very thin, they can be layered as needed to block out more light. They can be easily scratched and/or bent, so they require more care than glass filters.
- Adjustable ND filter: This filter is made of two layers of glass and has a top and bottom section. When the filter is twisted, more or less light is blocked. The advantage is that you can use one filter for any situation. A commonly discussed disadvantage is that they might not produce as clear of a picture as regular ND filters that contain a single layer of glass.
Close-Up Photos
DJI ND8 (screw-on)
ND Filter Specs
- DJI UV--(screw-on/glass lens/metal rim ― 0.05 oz)
- DJI ND8--(screw-on/glass lens/metal rim ― 0.05 oz ― same size as DJI UV filter)
- Anbee/BTG ND16--(screw-on/glass lens/metal rim ― 0.05 oz ― same size as DJI UV filter)
- DitzCo ND8--(slide-on/gel filter/plastic rim ― 0.01 oz)
- Freewell ND2-400--(screw-on/glass lens/metal rim ― 0.20 oz)
- Mudder ND2-400--(screw-on/glass lens/metal rim ― 0.35 oz)
- Neewer ND16--(screw-on/glass lens/metal rim ― 0.10 oz)
- Polar Pro ND8--(screw-on/glass lens/metal rim ― 0.15 oz)
- Polar Pro ND8--(slide-on/glass lens/plastic rim ― 0.25 oz)
- SRP ND16/CP--(slide-on/glass lens/metal rim ― 0.25 oz)
- TACO-RC ND16--(screw-on/glass lens/metal rim ― 0.05 oz ― same size as DJI UV filter)
Likes & Dislikes
- All: Filters that are not the same size as the DJI UV filter might need to be removed in order to use your camera lens cap and/or gimbal lock.
- DitzCo: These lenses attract more lint/dust than filters with glass lenses.
- DJI: These filters have no marking on the outside, so you'll need to somehow label them or label the storage case so you're able to easily tell them apart.
- Freewell: This filter has tick marks on the outside to show the selected ND level. This could come in handy if you want to use a similar setting again for a specific flying condition/location.
- Polar Pro: Many of the lenses have traces of glue on the edges where they were glued in place. This does not affect the picture quality, but it's something you will visually notice when viewing the inside of the filters close up.
- SRP: These filters fit very tightly, so they are not as convenient to use if you'll be changing them often. I found they are easier to remove if you wiggle them from side-to-side as you slide them off.
Tips
- When using slide-on filters, make sure they are fully depressed. Otherwise, you might see dark spots in the corners of your video/photos (AKA vignetting) or your camera might hit the ground as it rotates when your Phantom is starting up.
- With the exception of the Freewell, SRP, and TACO-RC filters, all filters come with a pretty poorly designed storage case. The TACO-RC filter case works well for DJI filters and those that are the same size as the DJI filters. For all other filters, this 3-pocket or 6-pocket filter case works well.
- You'll definitely need a camera lens cleaner (like this one) to clean fingerprints and/or dust/lint that often clings to the surface of the lenses.
- The Phantom 4 gimbal lock cannot be used if you have filters that are not the same size as the DJI UV filter -- unless you modify it like this.
- Make sure you have the appropriate filters to handle all of the usual lighting conditions where you fly. The following chart will help you figure out which filters you'll need:
