- Joined
- Dec 6, 2014
- Messages
- 235
- Reaction score
- 12
+1GSSP said:Well, thats it, I will NEVER plug my Phantom into the internet again....
BlackTracer said:eseckinger said:Allram said:Just updated (Running Vision, not pluss). seems more stable, just didnt manage to calibrate the compass. It's a new warning light. ALOT of red lights flashing when compass calibration has failed. Overall it's nothing special
do you only get one flashing green light now when flying in gps mode with 6 + sats? One side does not seem to flash green anymore but yellow and red work. Im in NAZA mode.
Does your green light on that side work when you first power on during the initialization phase? If not it could be your green led is broken. Unless others can confirm this is a firmware issue. Good grief I hope not.
Mori55 said:Why not just reload the firmware ? Or revert back and see what happens ?
N017RW said:The ESCs receive a PWM signal from the imbedded processor on the main PCB independent of the motor speed PWM signal (which comes from the Naza) to produce the LED colors/patters, etc.
Both motor ESCs 1 & 2 (front right, front left respectively) receive the identical PWM signal while motor ESCs 3 & 4 (rear left & rear right respectively) receive their own separate and identical PWM signals.
Therefore both front and both rear ESCs must display the same, yet different, pattern regardless of being on the left or right side.
If one side is not operating correctly check to see that the 4 pin connector is properly seated, if so then there must be an ESC (or more specifically an LED) fault.
What I'm trying to say is that there is no way for one front or one rear ESC to display a different color/pattern from the other via firmware. It must be a hardware fault.
jadebox said:The DC FRZ extends approximately 13–15 nautical miles (15–17 statute miles) around the VOR/DME located at the Ronald Reagan Washington National Airport. Flight within the FRZ is restricted to governmental, certain scheduled commercial and a limited set of waivered flights. - http://en.m.wikipedia.org/wiki/Washingt ... Rules_Area
Don't be a wuss , just do it. Take a chance instead of someone else.Eltrochaphantom said:So... Should we update? Safe or kinda safe? Anyone flew yet?
Dirty Bird said:jadebox said:The DC FRZ extends approximately 13–15 nautical miles (15–17 statute miles) around the VOR/DME located at the Ronald Reagan Washington National Airport. Flight within the FRZ is restricted to governmental, certain scheduled commercial and a limited set of waivered flights. - http://en.m.wikipedia.org/wiki/Washingt ... Rules_Area
That may be, but this was intended for manned aircraft, NOT small RC aircraft. Until anti-matter becomes readily available, its a tad excessive.
Mori55 said:Don't be a wuss , just do it. Take a chance instead of someone else.Eltrochaphantom said:So... Should we update? Safe or kinda safe? Anyone flew yet?
N017RW said:I believe there are only two LED arrays in/on the ESC - Red and Green.
When BOTH are illuminated it produces the Yellow.
Each color group (red,green) has a separate output port on the driver chip, a separate switching transistor, and separate biasing resistor. So assuming there is not a connector issue, which seems implausible since you are getting some illumination on each side, it comes down to the items in the above sentence.
Maybe this can help you deduce the the problem as it is difficult without seeing it first-hand.
