Fixing flash in DM365 chip within Ph3 Pro gimbal
hello friends i bought a broken p3p the gimbal on it is devastated i will check its operation later on but the main board armed and motors spinned on atti now i intend to put this working board on my already working gimbal i fixed (flashed) earlier thanks to the thread, the gimbal is on fw 1.10.90 , but i have no idea of the fw on the broken phantom i bought ????? how to proceed to match the fw of gimbal with that of aircraft??
That won’t matter any.
its weird to know that any firmware on flight controller will speak to any firmware on gimbal or i understood it incorrectly!!
If something doesn't turn on, the first thing you check is whether it is plugged to power.
Power circuit issues are usually easy to solve. Check voltages on the Gimbal Top board. Trace those which are missing.
Hey i Put 12V on the pin 12V.
3.3VD, 5V, are there
on the back 3.3 is there
VDD pin shows 1,04V
A9S 3,3VD, 1,8VDl, VDDA are there okay
This is a board for Advanced. This thread is about fixing Ph3 Pro, ands the chip which is specific to that model - DM365 DaVinci Media Controller. You don't have that chip.
Connecting anything to BT00/BT01 won't matter - these are pads specific to DaVinci chip, which you don't have.
If your board isn't booting, the issue is with Ambarella. Like DaVinci, Ambarella has a separate NAND chip on which its firmware is stored. It also has various boot methods, but since the documentation isn't public, we are not sure how to use them.
Anyway, this thread is about daVinci. It would be best to discuss Ambarella in a separate thread.
Reactions: Mark The Droner
Hey Igot a good platine for the advance. Now A friend has a problem with his PRO. The Gimbal plate didn't show anything no LED Blinking or something. We Installed a ohter one. Now He can take pictures be there is no Live fedd to the phone. We tried to reflash it but there is no communication to the Davinci chip?
Follow the guide I made for GL300a. This way when you reach the issue, you should be able to describe it properly.
Reactions: KachemakDiver
Do I understand i correct that the gl300a fix is for the remote controller? I can't communicate with the chip on gimbal board over TTL.
Hi,
Someone has all the necessary files unpacked for a P3P gimbal motherboard because I just can't unzip the BIN file so I can't try programming after the NAND replacement.
Thanks!
Hi,
Thanks!
If you do a search by tapping on the magnifying glass icon at the top right of this screen. Type in; @SunsetCatcher, you will find links to his downloads you are looking for. Let me know if you need any more help ?
Thanks!
I've been trying this reprogramming for a while now, but I'm stuck with the codes because both CMD and Putty throw errors, for example, on lines starting with DD. I want to do it under Windows 7. I swapped a NAND chip on the panel, and I can't put the order together. I did it by running the repairmydji.bat file and under "boot me" status. Then I uploaded the uimage file with extra putty. Then I got stuck here because I don’t know what’s left out and what still needs to be done. The boot stops at the location shown in the attached image. Can you help me with what else to do? Unfortunately, my English is not very strong either, so it is a bit difficult to adjust to the descriptions as well.
That was much better than Your previous question, I can answer this.
You might have noticed that circa every 6 posts I am inserting this link:
I do that because this is very useful link, and I spent a lot of time preparing that article.
Search for "Encryption issues".
.. but better read it whole, not only that one section.
I've seen this and tried to do it all the way with a GL300A USB panel, but the panel didn't work after that either. Doesn't the P3P gimbal panel need to upload other files? Eg for gimbal I can't find ubl1_prop.img u-boot_prop.img files! THE "
Re-flashing encrypted partition "and" Re-flashing root filesystem "I can't find out what to do! Unfortunately, without perfect English knowledge, this can't be traced in this form! because this form does not work under windows:
"./dji_fwcon.py -vvv -x -p P3X_FW_V01.07.0060.bin
openssl des3 -d -k Dji123456 -in P3X_FW_V01.07.0060_m0800.bin -out P3X_FW_V01.07.0060_m0800_decrypted.tar.gz "
Unfortunately with 0 programming skills this is so very difficult because it is not there in all cases what to type where!
Now, based on the picture attached earlier, what else do I need to do to be good?
Now you're diverging from the issue you originally described.
The screenshots clearly show what I described as "Encryption issues". I directed you to the explanation.
Python and OpenSSL are available on Windows, Linux and Mac. You do not need to be a programmer, the tools are already made. You only need to know how to use computers. Knowing how to us Google would help as well.
P3P Gimbal does need other files than GL300a RC. But description from the GL300a post matches both boards.
I did not deviate from the topic, I can only write with a compiler, the GL330A was a previous unsuccessful attempt. But then I don't think I'll deal with it this way anymore, because that's not the way to use it with a compiler! A colleague of mine unpacked the bin, but only managed to fix it with modified commands, in several hours, as it didn’t work as described under windows. Thanks for the info so far.
How did you achieve this?
Can you make a video about it? What is your e-mail address?
UBL Product Vesion : DJI-GSP-UBL-1.0-rc10(2014-08-15)
Dji UBL Version: 1.51(Aug 15 2014 - 17:05:12)
Booting Catalog Boot Loader
BootMode = NAND
Starting NAND Copy...
Valid magicnum, 0xA1ACED66, found in block 0x00000019.
Uboot Checksum:0x7E25B44B
Actua Checksum:0x7E25B44B
U-Boot Product Vesion : DJI-GSP-Uboot-1.0-rc4(2014-07-23)
U-Boot 2010.12-rc2-svn-Dji (Jul 23 2014 - 11:14:40)
Cores: ARM 432 MHz
DDR: 297 MHz
I2C: ready
DRAM: 128 MiB
NAND: 128 MiB
Bad block table found at page 65472, version 0x01
Bad block table found at page 65408, version 0x01
*** Warning - bad CRC, using default environment
Net: Ethernet PHY: GENERIC @ 0xff
DaVinci-EMAC
Press ESC to abort autoboot in 1 seconds
Loading from nand0, offset 0x4a0000
** Unknown image type
Wrong Image Format for bootm command
ERROR: can't get kernel image!
Loading from nand0, offset 0x900000
Image Name: Linux-2.6.32.17-davinci1
Created: 2015-03-30 9:54:39 UTC
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 4032832 Bytes = 3.8 MiB
Load Address: 80008000
Entry Point: 80008000
## Booting kernel from Legacy Image at 80700000 ...
Loading Kernel Image ... OK
OK
Starting kernel ...
[ 0.000000] Kernel Product Vesion : DJI-NOHDMI-WM610-Kernel-1.0-rc6(2015-03-3 0)
[ 0.000000] Linux version 2.6.32.17-davinci1 (root@dji) (gcc version 4.3.3 (S ourcery G++ Lite 2009q1-203) ) #16 PREEMPT Mon Mar 30 17:54:38 HKT 2015
[ 0.000000] CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053177
[ 0.000000] CPU: VIVT data cache, VIVT instruction cache
[ 0.000000] Machine: DaVinci DM36x EVM
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] DaVinci dm36x_rev1.2 variant 0x8
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping off. Total pa ges: 12192
[ 0.000000] Kernel command line: console=ttyS0,115200n8 rw dm365_imp.oper_mod e=0 video=davincifb:vid0=0,10K:vid1=0,10K:osd0=1920x1080X16,8100K mem=48MB davin ci_enc_mngr.ch0_output=COMPOSITE davinci_enc_mngr.ch0_mode=pal ubi.mtd=2,2048 ro ot=ubi0:rootfs rootfstype=ubifs ip=off lpj=1077248
[ 0.000000] PID hash table entries: 256 (order: -2, 1024 bytes)
[ 0.000000] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.000000] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Memory: 48MB = 48MB total
[ 0.000000] Memory: 44452KB available (3640K code, 451K data, 116K init, 0K h ighmem)
[ 0.000000] SLUB: Genslabs=11, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, N odes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] NR_IRQS:245
[ 0.000000] Console: colour dummy device 80x30
[ 0.000000] Calibrating delay loop (skipped) preset value.. 215.44 BogoMIPS ( lpj=1077248)
[ 0.000000] Mount-cache hash table entries: 512
[ 0.000000] CPU: Testing write buffer coherency: ok
[ 0.000000] DaVinci: 8 gpio irqs
[ 0.000000] NET: Registered protocol family 16
[ 0.110000] bio: create slab <bio-0> at 0
[ 0.110000] DM365 IPIPE initialized in Continuous mode
[ 0.110000] SCSI subsystem initialized
[ 0.120000] usbcore: registered new interface driver usbfs
[ 0.120000] usbcore: registered new interface driver hub
[ 0.120000] usbcore: registered new device driver usb
[ 0.120000] vpss vpss: dm365_vpss vpss probed
[ 0.120000] vpss vpss: dm365_vpss vpss probe success
[ 0.130000] dm365_afew_hw_init
[ 0.130000] ch0 default output "COMPOSITE", mode "PAL"
[ 0.130000] VPBE Encoder Initialized
[ 0.130000] cfg80211: Using static regulatory domain info
[ 0.130000] cfg80211: Regulatory domain: US
[ 0.130000] (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp )
[ 0.130000] (2402000 KHz - 2472000 KHz @ 40000 KHz), (600 mBi, 2700 mBm)
[ 0.130000] (5170000 KHz - 5190000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
[ 0.130000] (5190000 KHz - 5210000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
[ 0.130000] (5210000 KHz - 5230000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
[ 0.130000] (5230000 KHz - 5330000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
[ 0.130000] (5735000 KHz - 5835000 KHz @ 40000 KHz), (600 mBi, 3000 mBm)
[ 0.130000] cfg80211: Calling CRDA for country: US
[ 0.140000] LogicPD encoder initialized
[ 0.140000] Switching to clocksource timer0_1
[ 0.140000] musb_hdrc: version 6.0, pio, host, debug=0
[ 0.160000] musb_hdrc: USB Host mode controller at fec64000 using PIO, IRQ 12
[ 0.160000] musb_hdrc musb_hdrc: MUSB HDRC host driver
[ 0.160000] musb_hdrc musb_hdrc: new USB bus registered, assigned bus number 1
[ 0.160000] usb usb1: configuration #1 chosen from 1 choice
[ 0.160000] hub 1-0:1.0: USB hub found
[ 0.160000] hub 1-0:1.0: 1 port detected
[ 0.160000] NET: Registered protocol family 2
[ 0.160000] IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.160000] TCP established hash table entries: 2048 (order: 2, 16384 bytes)
[ 0.160000] TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.160000] TCP: Hash tables configured (established 2048 bind 2048)
[ 0.160000] TCP reno registered
[ 0.160000] NET: Registered protocol family 1
[ 0.160000] RPC: Registered udp transport module.
[ 0.160000] RPC: Registered tcp transport module.
[ 0.160000] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.170000] JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[ 0.170000] msgmni has been set to 86
[ 0.180000] alg: No test for stdrng (krng)
[ 0.180000] io scheduler noop registered (default)
[ 0.210000] VBUS on (a_wait_vrise), devctl 19
[ 0.220000] davincifb davincifb.0: dm_osd0_fb: Initial window configuration i s invalid.
[ 0.300000] Console: switching to colour frame buffer device 240x67
[ 0.390000] davincifb davincifb.0: dm_osd0_fb: 1920x1080x16@0,0 with framebuf fer size 8100KB
[ 0.390000] davincifb davincifb.0: dm_vid0_fb: 0x0x16@0,0 with framebuffer si ze 10KB
[ 0.390000] davincifb davincifb.0: dm_osd1_fb: 720x576x4@0,0 with framebuffer size 810KB
[ 0.400000] davincifb davincifb.0: dm_vid1_fb: 0x0x16@0,0 with framebuffer si ze 10KB
[ 0.460000] DM365 IPIPEIF probed
[ 0.460000] imp serializer initialized
[ 0.460000] davinci_previewer initialized
[ 0.460000] davinci_resizer initialized
[ 0.470000] Serial: 8250/16550 driver, 2 ports, IRQ sharing disabled
[ 0.470000] serial8250.0: ttyS0 at MMIO 0x1c20000 (irq = 40) is a 16550A
[ 0.930000] console [ttyS0] enabled
[ 0.940000] serial8250.0: ttyS1 at MMIO 0x1d06000 (irq = 41) is a 16550A
[ 0.950000] brd: module loaded
[ 0.960000] NAND device: Manufacturer ID: 0x2c, Chip ID: 0xf1 (Micron NAND 12 8MiB 3,3V 8-bit)
[ 0.970000] Creating 4 MTD partitions on "davinci_nand.0":
[ 0.970000] 0x000000000000-0x0000004a0000 : "bootloader"
[ 0.980000] 0x0000004a0000-0x000000e00000 : "kernel"
[ 0.990000] 0x000000e00000-0x000007f00000 : "filesystem"
[ 1.000000] 0x000000000000-0x000008000000 : "all"
[ 1.010000] davinci_nand davinci_nand.0: controller rev. 2.3
[ 1.020000] UBI: attaching mtd2 to ubi0
[ 1.020000] UBI: physical eraseblock size: 131072 bytes (128 KiB)
[ 1.030000] UBI: logical eraseblock size: 126976 bytes
[ 1.030000] UBI: smallest flash I/O unit: 2048
[ 1.040000] UBI: sub-page size: 512
[ 1.040000] UBI: VID header offset: 2048 (aligned 2048)
[ 1.050000] UBI: data offset: 4096
[ 1.530000] UBI: attached mtd2 to ubi0
[ 1.530000] UBI: MTD device name: "filesystem"
[ 1.530000] UBI: MTD device size: 113 MiB
[ 1.540000] UBI: number of good PEBs: 904
[ 1.540000] UBI: number of bad PEBs: 0
[ 1.550000] UBI: max. allowed volumes: 128
[ 1.550000] UBI: wear-leveling threshold: 4096
[ 1.560000] UBI: number of internal volumes: 1
[ 1.560000] UBI: number of user volumes: 0
[ 1.570000] UBI: available PEBs: 891
[ 1.570000] UBI: total number of reserved PEBs: 13
[ 1.580000] UBI: number of PEBs reserved for bad PEB handling: 9
[ 1.580000] UBI: max/mean erase counter: 2/1
[ 1.590000] UBI: image sequence number: 0
[ 1.590000] UBI: background thread "ubi_bgt0d" started, PID 331
[ 1.600000] console [netcon0] enabled
[ 1.600000] netconsole: network logging started
[ 1.610000] Initializing USB Mass Storage driver...
[ 1.610000] usbcore: registered new interface driver usb-storage
[ 1.620000] USB Mass Storage support registered.
[ 1.620000] i2c /dev entries driver
[ 1.630000] Linux video capture interface: v2.00
[ 1.640000] davinci_interrupt 370: VBUS error workaround (delay coming)
[ 1.640000] VBUS off (a_wait_vfall) ERROR, devctl 90
[ 1.650000] vpfe_init
[ 1.650000] vpfe-capture: vpss clock vpss_master enabled
[ 1.660000] vpfe-capture vpfe-capture: v4l2 device registered
[ 1.660000] vpfe-capture vpfe-capture: video device registered
[ 1.670000] EVM: switch to ambarella video input
[ 1.670000] vpfe-capture vpfe-capture: v4l2 sub device ambarella registered
[ 1.680000] vpfe_register_ccdc_device: DM365 ISIF
[ 1.690000] DM365 ISIF is registered with vpfe.
[ 1.690000] Trying to register davinci display video device.
[ 1.700000] layer=c105ec00,layer->video_dev=c105ed64
[ 1.710000] Trying to register davinci display video device.
[ 1.710000] layer=c105f000,layer->video_dev=c105f164
[ 1.720000] davinci_init:DaVinci V4L2 Display Driver V1.0 loaded
[ 1.720000] watchdog watchdog: heartbeat 1 sec
[ 1.730000] TCP cubic registered
[ 1.730000] NET: Registered protocol family 17
[ 1.740000] lib80211: common routines for IEEE802.11 drivers
hcashmore11
