I use 3.1.46 did a test yesterday and went 1200 metres so Fcc mode worked fine. It does keep popping up the wifi is set to a wrong region but I just click it away with OK.I only use LITCHI to fly. I'm on FCC and I use an iPad mini 4 but I'm interested in installing some version of DJI Go. Which one could I use without changing to CE
Version 3.1.46 is the original of dji or is it modified? Does anyone else use 3.1.46? I do not want to risk that it does not work in FCC. I use Litchi and ipad mini 4. Thanks.
Today went back to 3.1.18 from 3.1.46.
The old one is really better.. Video signal is more fluid, no disconnections, no wifi switch popup.. I will stay with this version.
In fact i usually used 3.1.46 with no problems of signal lost and fpv was good.I had lots of signal loss with the 3.1.18 and with the 3.1.46 video gets choppy and lagged at 1km.
I'm lost. Then I can not download the original version 3.1.18 ?? . I want to install it on an IOS device
I think the last iOS version that stays in FCC mode is 3.1.8. I managed to install that on my iPad using iTunes and a guide I found using Google.Hi guys do u know which is the last version that not switch automatically to CE mode? Is the 3.1.8?? Because i found an italian djigo version based on 3.1.18 but is stock without mods..
I also done the fake gps so this is why i want to know!!
That's correct. Keep it by 3.1.18. A newer version offers nothing for the P3SE and only facilitates other DJI equipment.Okay. Thank you!
Is this the code of version 3.1.8?
