Gimbol dead
Hello all P2 flyers!
I have some problem with my gimbol H3-3D unit.
It is dead after an update of firmware.
I have tried to re-set the unit by short cutting the connection points as showned in severel videos on youtube.
- I have been very focused on really connect correctly to make the short cut.
Do anyone have a tip on how to get my gimbol back to life?
Most appriciated for any help in this matter.
Regards,
Patrik
i had a problem like that, with the gimbol. when i turn the drone the gimbol did come to life and went to center. but when i moved the gimbol to point down, it went but will not come back up.
after talking to dji, i connect the drone to the computer and went back to the calibrate screen, and that help the problem. so if you did not re-calibrate the gimbol try that.
hope that helped
I had a dead gimbal after an update too. It no longer showed up in the assistant. This is the video I followed to reset it. I used a paper clip. Took two tries.
billyboy02
