@RSS, maybe @Timinator can help you out, he has had some good luck getting his going.
Hope this tag is ok with you guys...
Randy (HTP)
Randy (HTP)
First off, just want to thank everyone who helped me with this little project. I'm very new to drones and I've only had my Phantom4Pro+ for just about three weeks. You guys have been great and I am learning a lot.
So I was able to get to 509 and it was really quite painless!...........
....... Still haven't flown yet due to poor weather but hope to get into the air tomorrow.
Absolutely, would be happy to help RSS.
Good news! You can absolutely downgrade using DUmldore. I was on the very latest firmware (0300) because of my hastiness last night. I really should have investigated more and if I did I would have learned Dumldore could be used to backup the original 01.02.304 firmware the aircraft had.
This afternoon when I first connected the aircraft I got nervous at first that I couldn't downgrade because of the Dumldore message I received when trying to backup my current FW in case things went sideways. I didn't need to worry since that only meant I couldn't backup the latest firmware that was loaded last night using the traditional update method.
Key things to remember:
1. I did the aircraft first with the remote powered off. Once I verified dumldore was successful by checking the version in DJI assistant and that the aircraft took 1.3.509, I used DJI Assistant to do a factory reset on the aircraft. Next, I used HighTechPauper's firmware (thanks Randy) to update the controller. Not sure if I should have done the factory reset of the controller before loading the firmware but the DJI Go app crashed like crazy on startup just like Randy said ( at least I think it was randy-apologies if it wasn't). I was able to get into the settings on the controller and do a factory reset. After that, it was fine.
2. Last step was to power on the aircraft and the controller so they could see each other and then I was off to the races. Easy peasy!
Good luck and reach out if I can be of help.
Could you send me that link too for .509 firmware? Thanks much.PM sent.
