- Joined
- Sep 7, 2016
- Messages
- 312
- Reaction score
- 103
- Age
- 49
New App this morning 2.9.2 haven't tried it yet but hope the bug was fixed!!
I'm only getting the connect to C1 while using updated iPhone 6. Everything is smooth on the kindle.
My P4 is always lethargic in P mode with obstacle avoidance enabled. It will only fly about 15mph in calm conditions. Turn off OA and P mode will likely work better, 30-33mphTry going down. I've noticed my bird seems lethargic at times. I mostly see it when trying to come down in P mode. Switch to Sport and like you were saying, normal.
John you may just have put me on to something. I wonder if the software only allows a forward speed such that it can stop to avoid an impact. That would seem very sensible to program the logic of the craft this way. That would imply that the braking setting might have an effect on the maximum forward speed. I will test this theory tomorrow because I have set my braking to a mid setting to avoid the severe pitching and motor revving that max braking causes. I suspect that obstacle avoidance programming will have access to maximum manoeuvre capability irrespective of settings.
I will report back.........
Can you guys confirm the consensus is this "DJI connect to C1" dialog ONLY happens after upgrading an Apple device to IOS 10? Android users aren't seeing this?
I'm wondering if DJI has tested IOS10. I've never seen a notice about that, saying IOS10 is OK. Am I wrong?
Hi, For me it happened as soon as I upgraded to IOS 10. DJI issued Go 2.9.2 which fixed it. For me however 2.9.2 caused a new issue with forward control being very very subdued!! DJI then released Go 3.0. This did not fix my Forward control issue but it did bring back the C1 fault. Right now I a bit frustrated, my drone is unflyable and has been for weeks. I seem to be alone with the control issue AND I have had the P4 replaced. I flew it out of the box with all default settings. I also flew it with both IOS and Android devices. I even flew it with no display device attached. On every occasion forward flight will only achieve about 5m/s after some time. Before you ask beginner mode not active. All other settings normal EXP etc. This issue only apparent in P mode, Sport mode is fine. This issue on two Phantoms?? DJI were trying to help me but they have gone quiet!I saw it for the first time time today, which also was my first flight since upgrading my iPad Pro to iOS 10
