- Joined
- Apr 13, 2018
- Messages
- 31
- Reaction score
- 4
- Age
- 41
Greetings, Pilots!
Today I am opening new topic for DJI GL300 remote controller charging issue.
Let's discuss varieties of errors and knowledge on - how to fix them.
Let's suppose we have a GL300 (A/B/C) remote controller for our P3A, P3X AC. Everything is fine with connection between RC and AC, functions are working fine but it's NOT CHARGING.
There can be several visuals on that.
a) RC is connected to the charger and it shows only 1 or 2 LED blinking when plugged in.
b) RC shows signs of charging but it charges only up to 3 LED lights on board. In other words it does not charges fully to 100%
ISSUE history - how does this happen and why?
- Is it because you have dropped your RC of got some shake or etc., during transportation, therefore something has jumped off the main board (component connection error).
- Is it because of bad battery, cables or something like that?
- Is it because of moisture / temperature changes in the RC?
- Is it because you have not used your RC for a while (again, storage issues - moisture, hot/cold place you keep it it)?
POSSIBLE FIX of this error:
- There are guys showing fix on YouTube with hot air re-flowing over the main board. Have you done it, does it fix this error?
- Have you found correct path which you can test with multi meter - troubleshooting exact error?
- Using hot air re-flow there is one specific component which seems to keep the key of this error. (Check pictures attached). I have tried to run hot air over exact component and it does a job (at least for a while). See that (Battery Metering IC TDFN8 - CW2015CSAD) chip in closeup view.
- Have you tried to replace this component EVER?
Any other suggestions - experience - solutions?
Hope this topic will help those pilots who have had this issue with their GL300 RC's.
Have a great day!
Cheers
Have a great day!
Cheers
