As the dpi goes up, the signal gets flatter but goes out farther. Often, 9 dbi is the best compromise for wifi. Still flat panels are the worst when it comes to obstructions.Yes the DBS small panel is 2x9dbi and the CCP are 14dbi each.. had them set at same angle and had to adjust flight height to mantain signal on the 2.4 side with the CCP
Hey @dirtybum since you were previously interested in my gear I thought you might like the new look. I can feel the range increasing already![]()
So if i'm reading this correctly you guys are both located near STL? If so, that's awesome as I'm also in that area! Would you guys be interested in meeting up to fly if that's the case? I would love to see the Governator in person and can't believe there has possibly been one in my area all this time. This would also save DB from having to send one my way![]()
That looks purity cool.Hey @dirtybum since you were previously interested in my gear I thought you might like the new look. I can feel the range increasing already![]()
Good work there.For the bracket you guys can do whatever..but i would use aluminium angle 1" or aluminium square tube 1" x 1"... whatever you choose it needs to be 13.5" in length...
On each end measure in 3"- 5/16" and drill a 9/32nd hole..its a little bigger than the 1/4" bolt so you have some room for error
Nice !!! This looks good !! And still a heck of a lot cheaper than those other panels!! Also fun for those of us who enjoy tinkering !! Next ... Results !! Lol
Max there sure looks like a white cross in the tree/bush in the center of you circle. I loss quality when I zoom in. different some thing there.
