Oh boy, not sure this guy has his math right... IBV will be all over this guy...lolVery interesting video that explains a lot:
Anxious for flying test!Here's some interesting numbers I found by pre-amping the amp.
I thought I'd just make a lame video, getting everyone's hopes up and then sit in my chair while all wait for me to lose my baby in the sunset.(Laughs).Anxious for flying test!
Lol!!!! Good stuff! Love the build! Looks great!Dave... I am opening the pod bay doors. Just a moment... just a moment..
While you test this pre thing, you may also consider testing the 'chain sequence'.. letting Linx be "last" in the chain in both directions. If I have this in my head right, on the RX side, would the Linx be pre-amping the sunhan since signal is coming back to the RC? (The way your set up now)I had built a 12v power cable assy for powering my amps on tripods mobile setup. It works well, but thats just another flurry of cables to deal with in addition to the LMR octopus. I got a idea of just powering the amps with my 12v batteries that usually attach to controller FPVLR antenna and amps that go on the controller. They have dual leads so I can power both the final amp and if I pre-amp them, those as well. In theory it looks good and should work. I'll need to test the capacity and endurance of this set up.
Hi there,I had built a 12v power cable assy for powering my amps on tripods mobile setup. It works well, but thats just another flurry of cables to deal with in addition to the LMR octopus. I got a idea of just powering the amps with my 12v batteries that usually attach to controller FPVLR antenna and amps that go on the controller. They have dual leads so I can power both the final amp and if I pre-amp them, those as well. In theory it looks good and should work. I'll need to test the capacity and endurance of this set up.
It might do... pre-amping an amp that already got very low minimum input with an amp that requires more and got no proper AGC... What for pre-amping if there is no loss inbetwen the amps to compensate. a 20db Rx gain is huge.- more you only get with better and cleaner listening antennas or increased bird Tx. The Rx only needs to be readable.. it shouldn't burn the Rc's pre-amp...It may make no difference since it's direct connect...
All good points. Interested in results.It might do... pre-amping an amp that already got very low minimum input with an amp that requires more and got no proper AGC... What for pre-amping if there is no loss inbetwen the amps to compensate. a 20db Rx gain is huge.- more you only get with better and cleaner listening antennas or increased bird Tx. The Rx only needs to be readable.. it shouldn't burn the Rc's pre-amp...![]()
