RC Firmware compatible with AC Firmware 01.03.0509
Hi All,
Does anybody know which RC firmware version works best with AC firmware 01.03.0509? I am experiencing an issue with transmission where the screen flickers then a green screen appears. The same flickering and green screen issue is being recorded in the micro SD card from the AC.
I have the versions below:
DJI GO 4 Version: 4.1.2
AC Firmware: 01.03.0509
RC Firmware: 01.04.00.00
Thank you!
Hi All,
Thank you!
I have 509 on AC and latest version on controller and it seems to be working.....for now. I did notice the green flickering however when using my iPad Air and not my iPhone 7. I changed channels on 5.8 and that solved the video problems. Maybe try that before going down the awful firmware rabbit hole.
Thank you! What is the current RC firmware version?
Not sure which version exactly but it's the latest. I will look tomorrow and let you know. I wouldn't update it though if I were you until you at least play around with different channels to see if that helps at all.
Reactions: Daskid
