Phantom 4 suddenly detected as a Phantom 3 Pro by remote / DJI Go?
Hi, I'm a bit in trouble with my P4's camera live feed...
I 've also posted this message on the official DJI forum and created a ticket on DJI's support; but untill today I couldn't find any working solution.
I hope someone on this forum recognises the described problem or has a good idea I can try out?
Long story short:
Last week I could fly with my Phantom 4 without any issues, everything working fine as aspected.
The other day, I suddenly noticed an in-app warning stating that the 64GB SD card I've been using for months seems to be corrupt.
At this point I can still fly, but I am unable to use the camera. The screen remains black, but every time I remove the SD card, the live video stream returns back to normal.
More details I discovered later on:
I continue flying without SD card, as I don't have any spare memory chips laying around at that moment. After emptying my first battery, I decided to try out my newly bought (official) battery.
So, I turned off the aircraft, the remote control and the DJI Go app, swapped batteries and prepared everything to make another flight with a fresh, fully charged battery, although still without micro SD card.
The first anomaly I notice: when connecting the DJI Go app with the remote control, it now detects my aircraft as a Phantom 3 Pro.
Strange - I thought - and I ignored it, thinking it was just a temporary glitch. But as soon as the dashboard is loaded I notice the second anomaly: a black screen instead of the live camera footage.
As with all strang behaving devices, I do what probably most of us would do: restart everything.
The drone, the RC, my Android tablet, the DJI Go app, ... all got rebooted and reconnected, but the issue remains the same.
My Phantom 4 has an identity crisis thinking it is a Phantrom 3 Pro and there is no more live camera footage.
Conclusion:
I think it might be a chain reaction because the RC or DJI Go app detect my drone as an older model; thereby the app probably uses an older method to receive the camera footage which is incompatible with the P4's hardware resulting in a black screen.
Further investigation:
I tried everything I could imagine in order to get my P4's camera working again:
  1. I used my Android phone instead of my tablet
  2. I cleared the cache of the DJI Go app on both mobile devices
  3. I tried the latest version of the GO app, I even tested 4 older versions of the app
  4. I used another USB cable (maybe the original one was defective)
  5. I tried 3 different, fully charged batteries for the drone and charged the battery of the remote
  6. I tested 2 different micro SD cards, I re-formatted the original 16 GB SD card that came with the Phantom
  7. I tried 4 different firmware versions on the remote control
  8. I tried to upgrade the firmware of the drone via the DJI Go app on my tablet, phone and even with DJI Assistent 2 on my computer with multiple USB cables.
All my attempts failed, but while doing all that, I discovered some extra anomalies.
I am unable to upgrade my drone's firmware, no matter which method I use - all fail, every time. In case of the in-app upgrade methods, but also in case of the computer method:
  • the usual upgrade method:
  • the "hold menu for 5 seconds" upgrade method:
  • The computer method (DJI Assistant 2):
Yet another anomaly:
I also noticed that micro SD cards are not detected anymore:
And also no matter which version version of DJI Go app I tried, none of them detects the firmware version of my Phantom 4:
So... I'm left here with a "blind" aircraft at the moment:
Does anyone know what's going on here, or does someone know how I can solve this issue?
I'm quite certain this is going to be a software related issue...
I miss my favorite aircrafts vision.
Thanks in advance!
are you using (Go app) or (Go 4 app)?
You need Go4
I used both DJI Go and DJI Go 4 app in my testing.
But the first time my video feed disappeared, I was still using the old Go app - which worked perfectly the day before.
I seen another post that said the android go app had an update yesterday but is still using the same version number, sorry I can't be much help I have always used Apple products
The only solution I see is to downgrade AC 's FW.
Yes, I do believe that could solve the issue, but:
ekicaj
