Phantom 3 Standard- Weird problem
In the GoApp, on the top right of the camera view screen are three dots. Tap that to open general settings. Scroll to the bottom to access the 'about' section, and tap that. It should show the app version, aircraft and r/c firmware versions listed......if they are connected to the app correctly.
My Rc is connected to the app and how v1.07.9 but the aircraft isn’t connected so it shows N/A
Reactions: RodPad
The Standard has combined" all in one firmware", which updates firmware on both aircraft and r/c at the same time.....with the same version. So both your RC and drone are on 1.07.9 firmware. I'd leave it as is for now, and troubleshoot the failed link up further.
Reactions: IANZONE and RodPad
I’m trying to troubleshoot the link problem but haven’t got any success yet and it was linked before and motors ran/armed up also checked the gimbal cables have no damage
Reactions: RodPad
Ok. Just to clarify, the micro SD card is not in the camera slot is it.? If so, take it out, and leave it out. The drone does NOT need it installed to fly.
Then restart everything, and try to link again.
Reactions: RodPad
Not sure. Just following up on the list in post #62......... and a members' input (@MapMaker53) had in posts #24 and #29 who had a corrupted SD card in his drone causing issues. Once removed, the issues were gone.
Just removed the SD card and tried pairing using the manual and DJI link method both of them are not working, the controller beeps and the link light on the Ac flashes but no connection at all the DJI go app says Aircraft Disconnected
Reactions: RodPad
Just removed the SD card and tried pairing using the manual and DJI link method both of them are not working, the controller beeps and the link light on the Ac flashes but no connection at all the DJI go app says Aircraft Disconnected View attachment 126180
Ok. Darn. I'll troubleshoot the subject a bit more. Maybe your 'drone guy' has a few ideas..........
Reactions: RodPad and Arkusss
WOW!
Thank you guys for your input!
The last couple of weeks for me, just been? Stuff.
I thank all the mods that I have a connection with.
@clackey, I'm so impressed with these forums.
Rod ..
Hey we made to #1
Rod ..
Reactions: captainmilehigh
Hey we made to #1
Rod ..
Yeah Rod. I like a good mystery.....but this one is starting to bug me.
After reading hundreds of posts on various DJI forums, the majority of linking issues were never resolved with a positive result......at least none were posted as solutions. So, @Arkusss, maybe try this step and see what happens. With all the firmware update/downgrade tries, the default R/C wifi link might have been trashed. Here is a very quick reset for the r/c wifi just in case. Worth a shot, anyway.....
I still can connect to the wifi of the rc do you think I house first reset the rc and then do the manual linking process?
Reactions: RodPad
Maybe try it.
If your 'drone guy' has a Standard r/c in working order, he could always try to link to your aircraft......or if anybody you know in your area that has a P3 Standard, you could do the same.
Reactions: RodPad
Maybe try it.
Okay I’ll try it when I’m home tonight I’m taking it to my drone guy on Friday that’s when he’s back to his shop
Krap, I still have not been following this close enough.
Just stuff on my side.
"I still can connect to the wifi of the rc do you think I house first reset the rc and then do the manual linking process?"
This statement is wifi to remote, remote to P3S or remote to mobile device.
Rod ..
Rod ..
Remote to wifi and then connecting to the app
I gue
Where is P3S in this?
#1 P3S to Remote is linked?
#2 Remote to Mobile Device is linked?
Rod ..
Digitdrew
