P3 Firmware Phantom 3 pro firmware won't update
Dear Phantom Pilots,
Help needed!
I try to update my Phantom 3 pro. It fails as following:
- I am using last firmware version P3X_FW_V01.11.0020.bin on micor SD
- I start the drone to update, the normal process starts
- but after 5 minutes of regular normal bip-bip-bip, it turns into a continuous Biiip with red continuous LED (front cemar module)
I also tried with reset button at startup (right side of camera module, near sound speaker), ending in the same result.
The P3X_FW_LOG_AB.txt log (MISC\LOG file) is as following:
[00014733]========== remo-con disconnect. boot(15) ============
[00014769]Packet [C:\P3X_FW_V01.11.0020.bin] detected, card sn [0x005fe340].
[00014801]Packet upgrade start...
[00014838]Packet checking...
[00014873]Packet vlink 01.11.0020 <-> 01.11.0020.
[00014943]Done.
[00014975]Version checking[1]...
[00015030][03 06][00] v2.4.20.50 -> v2.4.20.50
[00015090][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015137][04 00][00] v1.48.0.0 -> v1.48.0.0
[00015234][11 00][00] v1.8.0.0 -> v1.8.0.0
[00015329][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00015363][11 01][00] v1.8.0.0 -> v2.0.0.33
[00015449][12 00][00] v1.12.0.0 -> v1.12.0.0
[00015531][12 01][00] v1.12.0.0 -> v1.12.0.0
[00015603][12 02][00] v1.12.0.0 -> v1.12.0.0
[00015679][12 03][00] v1.12.0.0 -> v1.12.0.0
[00028211][15 00][00] device not detected.
[00028293][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028423][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028480][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028512][01 00][00] v1.32.5432 -> v1.32.5432
[00028547][01 01][00] v1.32.5432 -> v1.32.5432
[00041161][08 00][00] device not detected.
[00041220][09 00][00] v4.1.0.0 -> v4.1.0.0
[00041257]Packet upgrade failed at version checking.
[00014482]========== remo-con disconnect. boot(15) ============
[00014513]Packet [C:\P3X_FW_V01.11.0020.bin] detected, card sn [0x005fe340].
[00014547]Packet upgrade start...
[00014585]Packet checking...
[00014628]Packet vlink 01.11.0020 <-> 01.11.0020.
[00014691]Done.
[00014722]Version checking[1]...
[00014773][03 06][00] v2.4.20.50 -> v2.4.20.50
[00014833][03 05][00] v34.2.0.9 -> v34.2.0.9
[00014872][04 00][00] v1.48.0.0 -> v1.48.0.0
[00014973][11 00][00] v1.8.0.0 -> v1.8.0.0
[00015073][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00015110][11 01][00] v1.8.0.0 -> v2.0.0.33
[00015182][12 00][00] v1.12.0.0 -> v1.12.0.0
[00015261][12 01][00] v1.12.0.0 -> v1.12.0.0
[00015353][12 02][00] v1.12.0.0 -> v1.12.0.0
[00015428][12 03][00] v1.12.0.0 -> v1.12.0.0
[00027961][15 00][00] device not detected.
[00028038][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028147][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028203][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028239][01 00][00] v1.32.5432 -> v1.32.5432
[00028277][01 01][00] v1.32.5432 -> v1.32.5432
[00040812][08 00][00] device not detected.
[00040883][09 00][00] v4.1.0.0 -> v4.1.0.0
[00040916]Packet upgrade failed at version checking.
[00014551]========== remo-con disconnect. boot(15) ============
[00014581]Packet [C:\P3X_FW_V01.11.0020.bin] detected, card sn [0x005fe340].
[00014616]Packet upgrade start...
[00014656]Packet checking...
[00014694]Packet vlink 01.11.0020 <-> 01.11.0020.
[00014759]Done.
[00014791]Version checking[1]...
[00014861][03 06][00] v2.4.20.50 -> v2.4.20.50
[00014941][03 05][00] v34.2.0.9 -> v34.2.0.9
[00014981][04 00][00] v1.48.0.0 -> v1.48.0.0
[00015100][11 00][00] v1.8.0.0 -> v1.8.0.0
[00015225][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00015258][11 01][00] v1.8.0.0 -> v2.0.0.33
[00015456][12 00][00] v1.12.0.0 -> v1.12.0.0
[00015557][12 01][00] v1.12.0.0 -> v1.12.0.0
[00015657][12 02][00] v1.12.0.0 -> v1.12.0.0
[00015757][12 03][00] v1.12.0.0 -> v1.12.0.0
[00028292][15 00][00] device not detected.
[00028409][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028550][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028595][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028629][01 00][00] v1.32.5432 -> v1.32.5432
[00028662][01 01][00] v1.32.5432 -> v1.32.5432
[00041195][08 00][00] device not detected.
[00041257][09 00][00] v4.1.0.0 -> v4.1.0.0
[00041291]Packet upgrade failed at version checking.
[00020519]========== remo-con disconnect. boot(15) ============
[00020563]Packet [C:\P3X_FW_V01.11.0020.bin] detected, card sn [0x005fe340].
[00020596]Packet upgrade start...
[00020634]Packet checking...
[00020670]Packet vlink 01.11.0020 <-> 01.11.0020.
[00020740]Done.
[00020773]Version checking[1]...
[00020856][03 06][00] v2.4.20.50 -> v2.4.20.50
[00020941][03 05][00] v34.2.0.9 -> v34.2.0.9
[00020980][04 00][00] v1.48.0.0 -> v1.48.0.0
[00021096][11 00][00] v1.8.0.0 -> v1.8.0.0
[00021220][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00021255][11 01][00] v1.8.0.0 -> v2.0.0.33
[00021350][12 00][00] v1.12.0.0 -> v1.12.0.0
[00021450][12 01][00] v1.12.0.0 -> v1.12.0.0
[00021534][12 02][00] v1.12.0.0 -> v1.12.0.0
[00021629][12 03][00] v1.12.0.0 -> v1.12.0.0
[00034162][15 00][00] device not detected.
[00034251][17 00][00] v1.1.1.7 -> v1.1.1.7
[00034366][17 01][00] v1.0.2.7 -> v1.0.2.7
[00034417][19 00][00] v1.0.8.96 -> v1.0.8.96
[00034453][01 00][00] v1.32.5432 -> v1.32.5432
[00034487][01 01][00] v1.32.5432 -> v1.32.5432
[00047021][08 00][00] device not detected.
[00047077][09 00][00] v4.1.0.0 -> v4.1.0.0
[00047110]Packet upgrade failed at version checking.
[00012565]========== remo-con disconnect. boot(15) ============
[00012601]Packet [C:\P3X_FW_V01.08.0080.bin] detected, card sn [0x005fe340].
[00012716]Packet upgrade start...
[00012757]Packet checking...
[00012793]Packet vlink 01.08.0080 <-> 01.07.0060.
[00012864]Done.
[00012896]Version checking[1]...
[00012971][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013050][03 06][00] v2.4.20.50 -> v2.4.14.5
[00013090][04 00][00] v1.48.0.0 -> v1.44.0.0
[00013216][11 00][00] v1.8.0.0 -> v1.7.15.1
[00013310][12 00][00] v1.12.0.0 -> v1.10.0.0
[00013420][12 01][00] v1.12.0.0 -> v1.10.0.0
[00013499][12 02][00] v1.12.0.0 -> v1.10.0.0
[00013598][12 03][00] v1.12.0.0 -> v1.10.0.0
[00026134][15 00][00] device not detected.
[00026219][17 00][00] v1.1.1.7 -> v1.1.1.7
[00026340][17 01][00] v1.0.2.7 -> v1.0.2.7
[00026391][19 00][00] v1.0.8.96 -> v1.0.8.96
[00026425][01 00][00] v1.32.5432 -> v1.30.5036
[00026459][01 01][00] v1.32.5432 -> v1.30.5036
[00038991][08 00][00] device not detected.
[00039050][09 00][00] v4.1.0.0 -> v3.0.0.10
[00039084]Packet upgrade failed at version checking.
[00012678]========== remo-con disconnect. boot(15) ============
[00012713]Packet [C:\P3X_FW_V01.11.0020.bin] detected, card sn [0x005fe340].
[00012750]Packet upgrade start...
[00012794]Packet checking...
[00012835]Packet vlink 01.11.0020 <-> 01.11.0020.
[00012900]Done.
[00012933]Version checking[1]...
[00013020][03 06][00] v2.4.20.50 -> v2.4.20.50
[00013098][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013141][04 00][00] v1.48.0.0 -> v1.48.0.0
[00013258][11 00][00] v1.8.0.0 -> v1.8.0.0
[00013378][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00013413][11 01][00] v1.8.0.0 -> v2.0.0.33
[00013522][12 00][00] v1.12.0.0 -> v1.12.0.0
[00013624][12 01][00] v1.12.0.0 -> v1.12.0.0
[00013702][12 02][00] v1.12.0.0 -> v1.12.0.0
[00013800][12 03][00] v1.12.0.0 -> v1.12.0.0
[00026336][15 00][00] device not detected.
[00026426][17 00][00] v1.1.1.7 -> v1.1.1.7
[00026573][17 01][00] v1.0.2.7 -> v1.0.2.7
[00026635][19 00][00] v1.0.8.96 -> v1.0.8.96
[00026669][01 00][00] v1.32.5432 -> v1.32.5432
[00026703][01 01][00] v1.32.5432 -> v1.32.5432
[00039337][08 00][00] device not detected.
[00039395][09 00][00] v4.1.0.0 -> v4.1.0.0
[00039433]Packet upgrade failed at version checking.
[00098508]========== remo-con disconnect. boot(15) ============
[00098548]Packet [C:\P3X_FW_V01.11.0020.bin] detected, card sn [0x005fe340].
[00098583]Packet upgrade start...
[00098626]Packet checking...
[00098667]Packet vlink 01.11.0020 <-> 01.11.0020.
[00098732]Done.
[00098767]Version checking[1]...
[00098849][03 06][00] v2.4.20.50 -> v2.4.20.50
[00098931][03 05][00] v34.2.0.9 -> v34.2.0.9
[00098974][04 00][00] v1.48.0.0 -> v1.48.0.0
[00099089][11 00][00] v1.8.0.0 -> v1.8.0.0
[00099212][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00099250][11 01][00] v1.8.0.0 -> v2.0.0.33
[00099349][12 00][00] v1.12.0.0 -> v1.12.0.0
[00099442][12 01][00] v1.12.0.0 -> v1.12.0.0
[00099545][12 02][00] v1.12.0.0 -> v1.12.0.0
[00099641][12 03][00] v1.12.0.0 -> v1.12.0.0
[00112181][15 00][00] device not detected.
[00112274][17 00][00] v1.1.1.7 -> v1.1.1.7
[00112399][17 01][00] v1.0.2.7 -> v1.0.2.7
[00112465][19 00][00] v1.0.8.96 -> v1.0.8.96
[00112499][01 00][00] v1.32.5432 -> v1.32.5432
[00112533][01 01][00] v1.32.5432 -> v1.32.5432
[00125070][08 00][00] device not detected.
[00125125][09 00][00] v4.1.0.0 -> v4.1.0.0
[00125159]Packet upgrade failed at version checking.
[00054532]========== remo-con disconnect. boot(15) ============
[00054568]Packet [C:\P3X_FW_V01.11.0020.bin] detected, card sn [0x005fe340].
[00054603]Packet upgrade start...
[00054651]Packet checking...
[00054692]Packet vlink 01.11.0020 <-> 01.11.0020.
[00054760]Done.
[00054801]Version checking[1]...
[00054875][03 06][00] v2.4.20.50 -> v2.4.20.50
[00054958][03 05][00] v34.2.0.9 -> v34.2.0.9
[00055002][04 00][00] v1.48.0.0 -> v1.48.0.0
[00055141][11 00][00] v1.8.0.0 -> v1.8.0.0
[00055263][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00055302][11 01][00] v1.8.0.0 -> v2.0.0.33
[00055469][12 00][00] v1.12.0.0 -> v1.12.0.0
[00055549][12 01][00] v1.12.0.0 -> v1.12.0.0
[00055635][12 02][00] v1.12.0.0 -> v1.12.0.0
[00055730][12 03][00] v1.12.0.0 -> v1.12.0.0
[00068268][15 00][00] device not detected.
[00068366][17 00][00] v1.1.1.7 -> v1.1.1.7
[00068490][17 01][00] v1.0.2.7 -> v1.0.2.7
[00068536][19 00][00] v1.0.8.96 -> v1.0.8.96
[00068571][01 00][00] v1.32.5432 -> v1.32.5432
[00068605][01 01][00] v1.32.5432 -> v1.32.5432
[00081160][08 00][00] device not detected.
[00081216][09 00][00] v4.1.0.0 -> v4.1.0.0
[00081252]Packet upgrade failed at version checking.
[00014563]========== remo-con disconnect. boot(15) ============
[00014605]Packet [C:\P3X_FW_V01.11.0020.bin] detected, card sn [0x005fe340].
[00014643]Packet upgrade start...
[00014685]Packet checking...
[00014727]Packet vlink 01.11.0020 <-> 01.11.0020.
[00014798]Done.
[00014835]Version checking[1]...
[00014912][03 06][00] v2.4.20.50 -> v2.4.20.50
[00014990][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015041][04 00][00] v1.48.0.0 -> v1.48.0.0
[00015152][11 00][00] v1.6.0.0 -> v1.8.0.0 need upgrade.
[00015270][11 01][00] v1.6.0.0 -> v2.0.0.33, firmware v1.6.0.0 not support.
[00015306][11 01][00] v1.6.0.0 -> v2.0.0.33
[00015410][12 00][00] v1.12.0.0 -> v1.12.0.0
[00015519][12 01][00] v1.12.0.0 -> v1.12.0.0
[00015599][12 02][00] v1.12.0.0 -> v1.12.0.0
[00015700][12 03][00] v1.12.0.0 -> v1.12.0.0
[00028235][15 00][00] device not detected.
[00028327][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028460][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028512][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028548][01 00][00] v1.32.5432 -> v1.32.5432
[00028582][01 01][00] v1.32.5432 -> v1.32.5432
[00041120][08 00][00] device not detected.
[00041172][09 00][00] v4.1.0.0 -> v4.1.0.0
[00041208]Done.
[00043245]Waiting for user confirm...
[00053278]Timeout, start upgrade automatically.
[00053361]Firmware upgrading[1]...
[00053409][11 00] Firmware upgrade start...
[00100356][11 00] Firmware upgrade finished successfully.
[00100486]Done.
[00100530]Version checking[2]...
[00100615][03 06][00] v2.4.20.50 -> v2.4.20.50
[00100697][03 05][00] v34.2.0.9 -> v34.2.0.9
[00100750][04 00][00] v1.48.0.0 -> v1.48.0.0
[00100875][11 00][05] v1.8.0.0 -> v1.8.0.0
[00100995][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00101041][11 01][00] v1.8.0.0 -> v2.0.0.33
[00101129][12 00][00] v1.12.0.0 -> v1.12.0.0
[00101231][12 01][00] v1.12.0.0 -> v1.12.0.0
[00101330][12 02][00] v1.12.0.0 -> v1.12.0.0
[00101434][12 03][00] v1.12.0.0 -> v1.12.0.0
[00113970][15 00][00] device not detected.
[00114065][17 00][00] v1.1.1.7 -> v1.1.1.7
[00114200][17 01][00] v1.0.2.7 -> v1.0.2.7
[00114277][19 00][00] v1.0.8.96 -> v1.0.8.96
[00114314][01 00][00] v1.32.5432 -> v1.32.5432
[00114350][01 01][00] v1.32.5432 -> v1.32.5432
[00126897][08 00][00] device not detected.
[00126957][09 00][00] v4.1.0.0 -> v4.1.0.0
[00126994]Packet upgrade failed at version checking.
[00015824]========== remo-con disconnect. boot(15) ============
[00015865]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0xdafac7bd].
[00015910]Packet upgrade start...
[00015960]Packet checking...
[00016002]Packet vlink 01.03.0020 <-> 01.01.0009.
[00016072]Done.
[00016113]Version checking[1]...
[00016192][03 05][00] v34.2.0.9 -> v34.2.0.9
[00016266][03 06][00] v2.4.20.50 -> v2.2.6.19
[00016312][04 00][00] v1.48.0.0 -> v1.40.0.0
[00016370][09 00][00] v4.1.0.0 -> v1.7.0.3
[00016491][11 00][00] v1.8.0.0 -> v1.7.0.0
[00016594][12 00][00] v1.12.0.0 -> v1.8.0.0
[00016674][12 01][00] v1.12.0.0 -> v1.8.0.0
[00016766][12 02][00] v1.12.0.0 -> v1.8.0.0
[00016854][12 03][00] v1.12.0.0 -> v1.8.0.0
[00029408][15 00][00] device not detected.
[00029495][17 00][00] v1.1.1.7 -> v1.1.1.7
[00029637][17 01][00] v1.0.2.7 -> v1.0.2.7
[00029692][19 00][00] v1.0.8.96 -> v1.0.8.96
[00029742][01 00][00] v1.32.5432 -> v1.23.3419
[00029783][01 01][00] v1.32.5432 -> v1.23.3419
[00042398][08 00][00] device not detected.
[00042447]Packet upgrade failed at version checking.
[00016434]========== remo-con disconnect. boot(15) ============
[00016477]Packet [C:\P3X_FW_V01.11.0020.bin] detected, card sn [0xdafac7bd].
[00016519]Packet upgrade start...
[00016569]Packet checking...
[00016619]Packet vlink 01.11.0020 <-> 01.11.0020.
[00016696]Done.
[00016741]Version checking[1]...
[00016831][03 06][00] v2.4.20.50 -> v2.4.20.50
[00016911][03 05][00] v34.2.0.9 -> v34.2.0.9
[00016968][04 00][00] v1.48.0.0 -> v1.48.0.0
[00017110][11 00][00] v1.8.0.0 -> v1.8.0.0
[00017255][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00017299][11 01][00] v1.8.0.0 -> v2.0.0.33
[00017412][12 00][00] v1.12.0.0 -> v1.12.0.0
[00017519][12 01][00] v1.12.0.0 -> v1.12.0.0
[00017625][12 02][00] v1.12.0.0 -> v1.12.0.0
[00017726][12 03][00] v1.12.0.0 -> v1.12.0.0
[00030276][15 00][00] device not detected.
[00030380][17 00][00] v1.1.1.7 -> v1.1.1.7
[00030526][17 01][00] v1.0.2.7 -> v1.0.2.7
[00030587][19 00][00] v1.0.8.96 -> v1.0.8.96
[00030628][01 00][00] v1.32.5432 -> v1.32.5432
[00030672][01 01][00] v1.32.5432 -> v1.32.5432
[00043222][08 00][00] device not detected.
[00043289][09 00][00] v4.1.0.0 -> v4.1.0.0
[00043334]Packet upgrade failed at version checking.
[00016659]========== remo-con disconnect. boot(15) ============
[00016706]Packet [C:\P3X_FW_V01.11.0020.bin] detected, card sn [0xdafac7bd].
[00016752]Packet upgrade start...
[00016802]Packet checking...
[00016847]Packet vlink 01.11.0020 <-> 01.11.0020.
[00016928]Done.
[00016971]Version checking[1]...
[00017054][03 06][00] v2.4.20.50 -> v2.4.20.50
[00017138][03 05][00] v34.2.0.9 -> v34.2.0.9
[00017186][04 00][00] v1.48.0.0 -> v1.48.0.0
[00017313][11 00][00] v1.8.0.0 -> v1.8.0.0
[00017454][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00017499][11 01][00] v1.8.0.0 -> v2.0.0.33
[00017609][12 00][00] v1.12.0.0 -> v1.12.0.0
[00017813][12 01][00] v1.12.0.0 -> v1.12.0.0
[00017901][12 02][00] v1.12.0.0 -> v1.12.0.0
[00018001][12 03][00] v1.12.0.0 -> v1.12.0.0
[00030547][15 00][00] device not detected.
[00030642][17 00][00] v1.1.1.7 -> v1.1.1.7
[00030789][17 01][00] v1.0.2.7 -> v1.0.2.7
[00030849][19 00][00] v1.0.8.96 -> v1.0.8.96
[00030894][01 00][00] v1.32.5432 -> v1.32.5432
[00030941][01 01][00] v1.32.5432 -> v1.32.5432
[00043484][08 00][00] device not detected.
[00043555][09 00][00] v4.1.0.0 -> v4.1.0.0
[00043598]Packet upgrade failed at version checking.
[00016083]========== remo-con disconnect. boot(15) ============
ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ [00015809]========== remo-con disconnect. boot(15) ============
[00015861]Packet [C:\P3X_FW_V01.11.0020.bin] detected, card sn [0xdafac7bd].
[00015905]Packet upgrade start...
[00015953]Packet checking...
[00016001]Packet vlink 01.11.0020 <-> 01.11.0020.
[00016079]Done.
[00016124]Version checking[1]...
[00016216][03 06][00] v2.4.20.50 -> v2.4.20.50
[00016311][03 05][00] v34.2.0.9 -> v34.2.0.9
[00016368][04 00][00] v1.48.0.0 -> v1.48.0.0
[00016491][11 00][00] v1.8.0.0 -> v1.8.0.0
[00016611][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00016659][11 01][00] v1.8.0.0 -> v2.0.0.33
[00016770][12 00][00] v1.12.0.0 -> v1.12.0.0
[00016862][12 01][00] v1.12.0.0 -> v1.12.0.0
[00016959][12 02][00] v1.12.0.0 -> v1.12.0.0
[00017059][12 03][00] v1.12.0.0 -> v1.12.0.0
[00029603][15 00][00] device not detected.
[00029700][17 00][00] v1.1.1.7 -> v1.1.1.7
[00029845][17 01][00] v1.0.2.7 -> v1.0.2.7
[00029913][19 00][00] v1.0.8.96 -> v1.0.8.96
[00029956][01 00][00] v1.32.5432 -> v1.32.5432
[00030001][01 01][00] v1.32.5432 -> v1.32.5432
[00042554][08 00][00] device not detected.
[00042633][09 00][00] v4.1.0.0 -> v4.1.0.0
[00042676]Packet upgrade failed at version checking.
[00015860]Packet [C:\P3X_FW_V01.11.0020.bin] detected, card sn [0xdafac7bd].
[00015989]Packet upgrade start...
[00016046]Packet checking...
[00016092]Packet vlink 01.11.0020 <-> 01.11.0020.
[00016167]Done.
[00016213]Version checking[1]...
[00016302][03 06][00] v2.4.20.50 -> v2.4.20.50
[00016383][03 05][00] v34.2.0.9 -> v34.2.0.9
[00016449][04 00][00] v1.48.0.0 -> v1.48.0.0
[00016583][11 00][00] v1.8.0.0 -> v1.8.0.0
[00016723][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00016768][11 01][00] v1.8.0.0 -> v2.0.0.33
[00016871][12 00][00] v1.12.0.0 -> v1.12.0.0
[00016971][12 01][00] v1.12.0.0 -> v1.12.0.0
[00017071][12 02][00] v1.12.0.0 -> v1.12.0.0
[00017173][12 03][00] v1.12.0.0 -> v1.12.0.0
[00029726][15 00][00] device not detected.
[00029832][17 00][00] v1.1.1.7 -> v1.1.1.7
[00029972][17 01][00] v1.0.2.7 -> v1.0.2.7
[00030041][19 00][00] v1.0.8.96 -> v1.0.8.96
[00030086][01 00][00] v1.32.5432 -> v1.32.5432
[00030131][01 01][00] v1.32.5432 -> v1.32.5432
[00042677][08 00][00] device not detected.
[00042759][09 00][00] v4.1.0.0 -> v4.1.0.0
[00042802]Packet upgrade failed at version checking.
[00013824]========== remo-con disconnect. boot(15) ============
[00013874]Packet [C:\P3X_FW_V01.11.0020.bin] detected, card sn [0xdafac7bd].
[00013922]Packet upgrade start...
[00013971]Packet checking...
[00014025]Packet vlink 01.11.0020 <-> 01.11.0020.
[00014100]Done.
[00014145]Version checking[1]...
[00014248][03 06][00] v2.4.20.50 -> v2.4.20.50
[00014343][03 05][00] v34.2.0.9 -> v34.2.0.9
[00014402][04 00][00] v1.48.0.0 -> v1.48.0.0
[00014543][11 00][00] v1.8.0.0 -> v1.8.0.0
[00014683][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00014734][11 01][00] v1.8.0.0 -> v2.0.0.33
[00014826][12 00][00] v1.12.0.0 -> v1.12.0.0
[00014931][12 01][00] v1.12.0.0 -> v1.12.0.0
[00015031][12 02][00] v1.12.0.0 -> v1.12.0.0
[00015132][12 03][00] v1.12.0.0 -> v1.12.0.0
[00027674][15 00][00] device not detected.
[00027788][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028021][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028100][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028146][01 00][00] v1.32.5432 -> v1.32.5432
[00028192][01 01][00] v1.32.5432 -> v1.32.5432
[00040745][08 00][00] device not detected.
[00040807][09 00][00] v4.1.0.0 -> v4.1.0.0
[00040853]Packet upgrade failed at version checking.
[00015822]========== remo-con disconnect. boot(15) ============
[00015872]Packet [C:\P3X_FW_V01.11.0020.bin] detected, card sn [0xdafac7bd].
[00015917]Packet upgrade start...
[00015971]Packet checking...
[00016018]Packet vlink 01.11.0020 <-> 01.11.0020.
[00016102]Done.
[00016147]Version checking[1]...
[00016235][03 06][00] v2.4.20.50 -> v2.4.20.50
[00016310][03 05][00] v34.2.0.9 -> v34.2.0.9
[00016490][11 00][00] v1.8.0.0 -> v1.8.0.0
[00016610][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00016755][12 00][00] v1.12.0.0 -> v1.12.0.0
[00016860][12 01][00] v1.12.0.0 -> v1.12.0.0
[00016938][12 02][00] v1.12.0.0 -> v1.12.0.0
[00017029][12 03][00] v1.12.0.0 -> v1.12.0.0
[00029574][15 00][00] device not detected.
[00029679][17 00][00] v1.1.1.7 -> v1.1.1.7
[00029801][17 01][00] v1.0.2.7 -> v1.0.2.7
[00029881][19 00][00] v1.0.8.96 -> v1.0.8.96
[00029926][01 00][00] v1.32.5432 -> v1.32.5432
[00029975][01 01][00] v1.32.5432 -> v1.32.5432
[00042522][08 00][00] device not detected.
[00042600][09 00][00] v4.1.0.0 -> v4.1.0.0
[00042650]Packet upgrade failed at version checking.
[00013822]========== remo-con disconnect. boot(15) ============
[00013873]Packet [C:\P3X_FW_V01.11.0020.bin] detected, card sn [0xdafac7bd].
[00013921]Packet upgrade start...
[00013972]Packet checking...
[00014027]Packet vlink 01.11.0020 <-> 01.11.0020.
[00014102]Done.
[00014147]Version checking[1]...
[00026704][03 06][00] device not detected.
[00039250][03 05][00] device not detected.
[00039305][04 00][00] v1.48.0.0 -> v1.48.0.0
[00051935][11 00][00] device not detected.
[00064480][11 01][00] device not detected.
[00077025][12 00][00] device not detected.
[00089570][12 01][00] device not detected.
[00102123][12 02][00] device not detected.
[00114669][12 03][00] device not detected.
[00127215][15 00][00] device not detected.
[00139763][17 00][00] device not detected.
[00152309][17 01][00] device not detected.
[00164866][19 00][00] device not detected.
[00164912][01 00][00] v1.32.5432 -> v1.32.5432
[00164958][01 01][00] v1.32.5432 -> v1.32.5432
[00177523][08 00][00] device not detected.
[00177607][09 00][00] v0.0.0.0 -> v4.1.0.0 need upgrade.
[00177659]Done.
[00179709]Waiting for user confirm...
[00189756]Timeout, start upgrade automatically.
[00189855]Firmware upgrading[1]...
[00189933][09 00] Firmware upgrade start...
[00242067][09 00] Firmware upgrade finished successfully.
[00242121]Done.
[00242167]Version checking[2]...
[00242253][03 06][00] v2.4.20.50 -> v2.4.20.50
[00242353][03 05][00] v34.2.0.9 -> v34.2.0.9
[00242407][04 00][00] v1.48.0.0 -> v1.48.0.0
[00242554][11 00][00] v1.8.0.0 -> v1.8.0.0
[00242693][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00242737][11 01][00] v1.8.0.0 -> v2.0.0.33
[00242846][12 00][00] v1.12.0.0 -> v1.12.0.0
[00242949][12 01][00] v1.12.0.0 -> v1.12.0.0
[00243046][12 02][00] v1.12.0.0 -> v1.12.0.0
[00243172][12 03][00] v1.12.0.0 -> v1.12.0.0
[00255728][15 00][00] device not detected.
[00255838][17 00][00] v1.1.1.7 -> v1.1.1.7
[00255962][17 01][00] v1.0.2.7 -> v1.0.2.7
[00256029][19 00][00] v1.0.8.96 -> v1.0.8.96
[00256075][01 00][00] v1.32.5432 -> v1.32.5432
[00256126][01 01][00] v1.32.5432 -> v1.32.5432
[00268675][08 00][00] device not detected.
[00268749][09 00][05] v4.1.0.0 -> v4.1.0.0
[00268799]Packet upgrade failed at version checking.
[00013848]========== remo-con disconnect. boot(15) ============
[00013899]Packet [C:\P3X_FW_V01.11.0020.bin] detected, card sn [0xdafac7bd].
[00014033]Packet upgrade start...
[00014084]Packet checking...
[00014135]Packet vlink 01.11.0020 <-> 01.11.0020.
[00014212]Done.
[00014263]Version checking[1]...
[00026807][03 06][00] device not detected.
[00039356][03 05][00] device not detected.
[00039416][04 00][00] v1.48.0.0 -> v1.48.0.0
[00051965][11 00][00] device not detected.
[00064511][11 01][00] device not detected.
[00077058][12 00][00] device not detected.
[00089608][12 01][00] device not detected.
[00102157][12 02][00] device not detected.
[00114705][12 03][00] device not detected.
[00127254][15 00][00] device not detected.
[00139817][17 00][00] device not detected.
[00152366][17 01][00] device not detected.
[00164912][19 00][00] device not detected.
[00164958][01 00][00] v1.32.5432 -> v1.32.5432
[00165013][01 01][00] v1.32.5432 -> v1.32.5432
[00177560][08 00][00] device not detected.
[00177635][09 00][00] v0.0.0.0 -> v4.1.0.0 need upgrade.
[00177688]Done.
[00179735]Waiting for user confirm...
[00189782]Timeout, start upgrade automatically.
[00189888]Firmware upgrading[1]...
[00189960][09 00] Firmware upgrade start...
[00242115][09 00] Firmware upgrade finished successfully.
[00242163]Done.
[00242210]Version checking[2]...
[00242297][03 06][00] v2.4.20.50 -> v2.4.20.50
[00242377][03 05][00] v34.2.0.9 -> v34.2.0.9
[00242440][04 00][00] v1.48.0.0 -> v1.48.0.0
[00242556][11 00][00] v1.8.0.0 -> v1.8.0.0
[00242682][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00242729][11 01][00] v1.8.0.0 -> v2.0.0.33
[00242820][12 00][00] v1.12.0.0 -> v1.12.0.0
[00242911][12 01][00] v1.12.0.0 -> v1.12.0.0
[00243000][12 02][00] v1.12.0.0 -> v1.12.0.0
[00243080][12 03][00] v1.12.0.0 -> v1.12.0.0
[00255634][15 00][00] device not detected.
[00255725][17 00][00] v1.1.1.7 -> v1.1.1.7
[00255862][17 01][00] v1.0.2.7 -> v1.0.2.7
[00255933][19 00][00] v1.0.8.96 -> v1.0.8.96
[00255980][01 00][00] v1.32.5432 -> v1.32.5432
[00256032][01 01][00] v1.32.5432 -> v1.32.5432
[00268746][09 00][05] v4.1.0.0 -> v4.1.0.0
[00015861]========== remo-con disconnect. boot(15) ============
[00015908]Packet [C:\P3X_FW_V01.11.0020.bin] detected, card sn [0xdafac7bd].
[00015960]Packet upgrade start...
[00016011]Packet checking...
[00016069]Packet vlink 01.11.0020 <-> 01.11.0020.
[00016146]Done.
[00016198]Version checking[1]...
[00016273][03 06][00] v2.4.20.50 -> v2.4.20.50
[00016362][03 05][00] v34.2.0.9 -> v34.2.0.9
[00016424][04 00][00] v1.48.0.0 -> v1.48.0.0
[00016538][11 00][00] v1.8.0.0 -> v1.8.0.0
[00016653][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00016706][11 01][00] v1.8.0.0 -> v2.0.0.33
[00016801][12 00][00] v1.12.0.0 -> v1.12.0.0
[00016922][12 01][00] v1.12.0.0 -> v1.12.0.0
[00017002][12 02][00] v1.12.0.0 -> v1.12.0.0
[00017103][12 03][00] v1.12.0.0 -> v1.12.0.0
[00029651][15 00][00] device not detected.
[00029738][17 00][00] v1.1.1.7 -> v1.1.1.7
[00029858][17 01][00] v1.0.2.7 -> v1.0.2.7
[00029923][19 00][00] v1.0.8.96 -> v1.0.8.96
[00029974][01 00][00] v1.32.5432 -> v1.32.5432
[00030024][01 01][00] v1.32.5432 -> v1.32.5432
[00042581][08 00][00] device not detected.
[00042665][09 00][00] v4.1.0.0 -> v4.1.0.0
[00042725]Packet upgrade failed at version checking.
Anyone can help with this?
Thank you so much.
Marcooo
Why Updating? Did you get a prompt when opening the DJI Go app?
When I start the drone (SD out) and the remote controller, both of them are flashing red/green. I have no choice but updating I guess.
I can t start the drone..
Here is the LOG_LAB
[00012479]========== remo-con disconnect. boot(15) ============
[00012524]Packet [C:\P3X_FW_V01.11.0020.bin] detected, card sn [0x005fe340].
[00012555]Packet upgrade start...
[00012594]Packet checking...
[00012633]Packet vlink 01.11.0020 <-> 01.11.0020.
[00012779]Done.
[00012815]Version checking[1]...
[00012904][03 06][00] v2.4.20.50 -> v2.4.20.50
[00012959][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012997][04 00][00] v1.48.0.0 -> v1.48.0.0
[00013109][11 00][00] v1.8.0.0 -> v1.8.0.0
[00013224][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00013260][11 01][00] v1.8.0.0 -> v2.0.0.33
[00013332][12 00][00] v1.12.0.0 -> v1.12.0.0
[00013407][12 01][00] v1.12.0.0 -> v1.12.0.0
[00013504][12 02][00] v1.12.0.0 -> v1.12.0.0
[00013578][12 03][00] v1.12.0.0 -> v1.12.0.0
[00026115][15 00][00] device not detected.
[00026193][17 00][00] v1.1.1.7 -> v1.1.1.7
[00026339][17 01][00] v1.0.2.7 -> v1.0.2.7
[00026392][19 00][00] v1.0.8.96 -> v1.0.8.96
[00026427][01 00][00] v1.32.5432 -> v1.32.5432
[00026463][01 01][00] v1.32.5432 -> v1.32.5432
[00038993][08 00][00] device not detected.
[00039054][09 00][00] v4.1.0.0 -> v4.1.0.0
[00039086]Packet upgrade failed at version checking.
[00014943]Done.
[00014691]Done.
[00014759]Done.
[00020740]Done.
[00012864]Done.
[00012900]Done.
[00098732]Done.
[00054760]Done.
[00014798]Done.
[00041208]Done.
[00100486]Done.
[00016072]Done.
[00016696]Done.
[00016928]Done.
[00016079]Done.
[00016167]Done.
[00014100]Done.
[00016102]Done.
[00014102]Done.
[00177659]Done.
[00242121]Done.
[00014212]Done.
[00177688]Done.
[00242163]Done.
[00016146]Done.
[00015866]========== remo-con disconnect. boot(15) ============
[00015911]Packet [C:\P3X_FW_V01.11.0020.bin] detected, card sn [0xdafac7bd].
[00015969]Packet upgrade start...
[00016036]Packet checking...
[00016087]Packet vlink 01.11.0020 <-> 01.11.0020.
[00016177]Done.
[00016227]Version checking[1]...
[00016297][03 06][00] v2.4.20.50 -> v2.4.20.50
[00016377][03 05][00] v34.2.0.9 -> v34.2.0.9
[00016437][04 00][00] v1.48.0.0 -> v1.48.0.0
[00016562][11 00][00] v1.8.0.0 -> v1.8.0.0
[00016683][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00016735][11 01][00] v1.8.0.0 -> v2.0.0.33
[00016907][12 00][00] v1.12.0.0 -> v1.12.0.0
[00017031][12 01][00] v1.12.0.0 -> v1.12.0.0
[00017138][12 02][00] v1.12.0.0 -> v1.12.0.0
[00017228][12 03][00] v1.12.0.0 -> v1.12.0.0
[00029777][15 00][00] device not detected.
[00029868][17 00][00] v1.1.1.7 -> v1.1.1.7
[00030008][17 01][00] v1.0.2.7 -> v1.0.2.7
[00030071][19 00][00] v1.0.8.96 -> v1.0.8.96
[00030120][01 00][00] v1.32.5432 -> v1.32.5432
[00030178][01 01][00] v1.32.5432 -> v1.32.5432
[00015828]========== remo-con disconnect. boot(15) ============
[00015875]Packet [C:\P3X_FW_V01.11.0020.bin] detected, card sn [0xdafac7bd].
[00015926]Packet upgrade start...
[00015984]Packet checking...
[00016035]Packet vlink 01.11.0020 <-> 01.11.0020.
[00016114]Done.
[00016169]Version checking[1]...
[00016247][03 06][00] v2.4.20.50 -> v2.4.20.50
[00016334][03 05][00] v34.2.0.9 -> v34.2.0.9
[00016389][04 00][00] v1.48.0.0 -> v1.48.0.0
[00016532][11 00][00] v1.8.0.0 -> v1.8.0.0
[00016648][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00016697][11 01][00] v1.8.0.0 -> v2.0.0.33
[00016903][12 01][00] v1.12.0.0 -> v1.12.0.0
[00017101][12 03][00] v1.12.0.0 -> v1.12.0.0
[00029660][15 00][00] device not detected.
[00029757][17 00][00] v1.1.1.7 -> v1.1.1.7
[00029897][17 01][00] v1.0.2.7 -> v1.0.2.7
[00029973][19 00][00] v1.0.8.96 -> v1.0.8.96
[00030025][01 00][00] v1.32.5432 -> v1.32.5432
[00030077][01 01][00] v1.32.5432 -> v1.32.5432
[00042625][08 00][00] device not detected.
[00042714][09 00][00] v4.1.0.0 -> v4.1.0.0
[00042763]Packet upgrade failed at version checking.
Well, one step at a time.. Have you flown this aircraft in the past? or is it newly acquired? Most time, updating will be last option..
need more info on what has led to this problem..
I first would try to link the remote to the aircraft.
I got this from my brother in law, who bought an orher one as he was unable to start this on any more. This drone has worked in the past.
Try Re linking first..
By the way: many thanks for support!
no big deal.. try re linking first.. Are you deleting & re installing DJI GO app?
I don't manage to connect. I start controller, then aircraft, then link moile to controler...
Are you trying to re link thru the app?
Your aware that the re link button is on the opposite side of the aircraft from SD card side? right side looking at battery tunnel.
I did push this button as well. Small LED at aircraft front keep on alternating green / red
Yes. Is that correct?
Yes..correct open the app.. press the aircraft icon at the top.. that opens screen.. press RC icon.. you can now see link aircraft & RC
you getting that far?
Here is what I see on the app. Not sure connection to remote is ok.
Here is what I see on the app. Not sure connection to remote is ok.View attachment 109425
OK... your in the wrong area... When this happens to me.. I turn EVERYTHING off completely.. The I pad etc.. Then start up again, so you see the Phantom on the page where you touch"camera"
Reactions: Recoveryone
shimuafeni fredrik
