- Joined
- Apr 14, 2015
- Messages
- 3,534
- Reaction score
- 2,041
- Age
- 47
Yea what is with the .
3.7 volt
That's how much voltage my battery still has per cell
3.7 volt
That is with that little piece of foam for a spacer. with a little work , better spacers to insure correct space it would work even better.View attachment 60651
P4 w/ CCP's boosted
Used the P4 tonight for the boosted run because I wanted to try my 6.6 split battery.
The battery didn't produce as much flight time as I would've liked, but I did go 40,000 with the CCP's boosted and the only signal problems was because I was flying too low for that far out, I raise it up slightly and go back to full bars. The trip back had perfect signal, unlike the unboosted trip earlier. I did the tests you guys be the critics[emoji41]
Would have to say well wreath the money paid for them.
So really they would go farther. How low where you flying at when you lost signal.
Great test and good range. I think I payed about 35 or 36 dollars for thous. That is cheep.Do I think this panel is as good as the terminator NO!!
I've done a couple 50,000 foot flights UNboosted with the terminator lately. The CCP did not do that great Unboosted, The preview was a little laggy at times. But I can now say from experience, a boosted CCP can be a cheap alternative and a decent antenna
Agree, sounds like the CCP's aren't consistant and reliable like the Terminator. With the Termi it sounds like you always know what to expect and the CCP's you have to worry which isnst good when are out that far...Do I think this panel is as good as the terminator NO!!
I got mine for $12.99 each free shipping.....the connectors and time are worth more the panels!Great test and good range. I think I payed about 35 or 36 dollars for thous. That is cheep.
I did ok with them boosted, but a little heavy,and very directional..Glad to see they did so well.
So at 45000 ft you were losing signal or turned round because of battery and how did the battery do also.I know you guys are probably getting bored with this, but I took the P4 out again with the CCP's boosted, simply because I wanted to test out that 6.6 battery. Took it to my famous flight path where I did the 19.5 mile run and so many other huge runs. 45,000 feet signal only dipped once, because I was about 170 foot high at 30,000 feet, bumped it up to 200 and it was fine. So basically perfect signal there and backView attachment 60684
as for boring I can't speak for everyone I'm hooked on. Keep them coming. Thank you sir may I have anotherI know you guys are probably getting bored with this, but I took the P4 out again with the CCP's boosted, simply because I wanted to test out that 6.6 battery. Took it to my famous flight path where I did the 19.5 mile run and so many other huge runs. 45,000 feet signal only dipped once, because I was about 170 foot high at 30,000 feet, bumped it up to 200 and it was fine. So basically perfect signal there and backView attachment 60684
smart man My last long flight it turned around at 53% that extra 4% would of made it all the way maybe for me.No,the signal was perfect. That screenshot is two seconds before I turned around, you can see for bars. I turned around when I got down to 55% battery
Db I was going some mod for the extra battery on the P2 I have not look at me P3 see if it will work. Would like your in put. look at the pictures. I'm thinking even add a mount for the connector.No the 6.6 is kind of a disappointment. As a single battery it gave me 39 minutes on the standard, now that it's been split I can't get more than 30 minutes out of it! With extra cables and wires when you split a battery, yeah it may ride nice on the saddles, but there's a lot more electrical resistance now reducing the flight time. It's too bad I had I hopes for that one
