Cheap China Panels (Liehuo) vs. any Antenna!
P4 w/ CCP's boosted
Used the P4 tonight for the boosted run because I wanted to try my 6.6 split battery.
The battery didn't produce as much flight time as I would've liked, but I did go 40,000 with the CCP's boosted and the only signal problems was because I was flying too low for that far out, I raise it up slightly and go back to full bars. The trip back had perfect signal, unlike the unboosted trip earlier. I did the tests you guys be the critics[emoji41]
Reactions: Digdat0 and Mikepoo
**** man thats crazy!!! I dont even know what to say...........
sent from my POS Samsung Galaxy
So for under $32 you can have some **** good distance!!!!! But you still gotta try one more to see if messing with the inside will make it a 10+ mile antenna!!!
Im still at a loss about that distance knowing that its pretty much lopsided in there facing god knows which direction lol
P4 w/ CCP's boosted
That is with that little piece of foam for a spacer. with a little work , better spacers to insure correct space it would work even better.
Db you know how to get the most out of it.
Reactions: Digdat0
Do I think this panel is as good as the terminator NO!!
I've done a couple 50,000 foot flights UNboosted with the terminator lately. The CCP did not do that great Unboosted, The preview was a little laggy at times. But I can now say from experience, a boosted CCP can be a cheap alternative and a decent antenna
Great test and good range. I think I payed about 35 or 36 dollars for thous. That is cheep.
I did ok with them boosted, but a little heavy,and very directional..Glad to see they did so well.
Reactions: Digdat0
Agree, sounds like the CCP's aren't consistant and reliable like the Terminator. With the Termi it sounds like you always know what to expect and the CCP's you have to worry which isnst good when are out that far...
I got my set super safe packed for the trip out to corn country...going out tmrw morning with a spare bracket.. so hopefully it will get there by the weekend.
I got mine for $12.99 each free shipping.....the connectors and time are worth more the panels!
Reactions: Digdat0
I know you guys are probably getting bored with this, but I took the P4 out again with the CCP's boosted, simply because I wanted to test out that 6.6 battery. Took it to my famous flight path where I did the 19.5 mile run and so many other huge runs. 45,000 feet signal only dipped once, because I was about 170 foot high at 30,000 feet, bumped it up to 200 and it was fine. So basically perfect signal there and back
Reactions: Digdat0
I know you guys are probably getting bored with this, but I took the P4 out again with the CCP's boosted, simply because I wanted to test out that 6.6 battery. Took it to my famous flight path where I did the 19.5 mile run and so many other huge runs. 45,000 feet signal only dipped once, because I was about 170 foot high at 30,000 feet, bumped it up to 200 and it was fine. So basically perfect signal there and backView attachment 60684
So at 45000 ft you were losing signal or turned round because of battery and how did the battery do also.
Reactions: Digdat0
as for boring I can't speak for everyone I'm hooked on. Keep them coming. Thank you sir may I have another;)
Reactions: Digdat0
No,the signal was perfect. That screenshot is two seconds before I turned around, you can see for bars. I turned around when I got down to 55% battery
No the 6.6 is kind of a disappointment. As a single battery it gave me 39 minutes on the standard, now that it's been split I can't get more than 30 minutes out of it! With extra cables and wires when you split a battery, yeah it may ride nice on the saddles, but there's a lot more electrical resistance now reducing the flight time. It's too bad I had I hopes for that one
smart man My last long flight it turned around at 53% that extra 4% would of made it all the way maybe for me.
Db I was going some mod for the extra battery on the P2 I have not look at me P3 see if it will work. Would like your in put. look at the pictures. I'm thinking even add a mount for the connector.
YvetteMarl
