Camera display on iPhone is now black
  • Been there, here's the solution
  • Good luck, no idea
Results are only viewable after voting.
Everything was working fine, but 3 flights ago, display on phone was fine, but was unable to take pictures or start a video. 2 flights ago, the display was just black, but the controls for taking a photo, or a video, or for adjusting the camera angle all seemed to be working ok. Then this last flight, the display was black again, and when I clicked the photo button, I got an error: Network connection lost. Will enjoy hearing any advice.
Reactions: Cajun Pilot
Once again...
Try on another device first.
Does the disconnection happen when you move the phantom around? Try shaking the phantom and see if you get the connection lost. If you do read further.
if you have crashed then its most likely the 3 cables that come down from phantom to the gimbal board. The culprit is the 4 pin clip in cable. Pull all three out and clearly inspect them and then carefully reinsert and make sure all 3 are seated firmly...
If you have never crashed and notice that your fpv is degrading then it could be wifi module degrading.
Don carlos
