Important lesson learned
Long Island, NY
I was asked to photograph a company event with my drone, so a few days beforehand I decided to run through some of the camera and flight settings like I usually do in preparation for a job -- only to find that I had no video feed in either DJI Go4 or Litchi. Not only that, but I get the message "Warning: The MC connection to the center board has failed. Solution: Restart the drone. If the problem persists contact DJI Support." Plus, in the DJI Go4 settings I see "Gimbal Disconnected" even though the gimbal is obviously reacting to me tilting the drone side to side. In addition, I get a "Strong WiFi interference" warning in DJI Go4, I'm unable to change my camera settings, the whining sound of the drone fan pulsates every 2 seconds, and my battery button ring flashes 10 times before it shuts down. The battery shuts down normally when not installed in the drone, and driving a distance from my house did not eliminate the Strong WiFi interference warning. So WHAT THE HECK IS GOING ON!!!??
I shipped my drone off to DroneTed, and it's a good thing that I had left my SDcard in the drone. Believe it or not, Ted discovered that it was my SDcard that was causing all of these issues. It had worked fine during a previous flight, and Ted could see the past photos and videos when the card was inserted into his laptop. But as soon as he put it back into my drone, the drone's video feed shut down. Inserting a new SDcard resolved all of the problems.
It's crazy that a bad SDcard can cause this many glitches - and all at once. Why would my P4P warn about high wifi interference when it doesn't even use wifi? And how is a bad SD card able to affect the behavior of a battery?? My wife did remind me that this particular SDcard had accidentally gone through the washer and dryer in my jeans pocket, so maybe that had something to do with it. Seemed fine at the time.
So the lesson is, if you experience ANY problem with your drone be sure to try a different SDcard before panicking. Apparently, you won't always just get a simple "No SDcard" message when your card goes bad. Oh, and don't put one through a wash cycle either.
WOW!!
Yes, if you had not sent the SD card. :rolleyes:.
That is crazy story and the problem is, I believe it.👍👌
OMG!
Rod ..
Glad to hear the issue was resolved and lucky you left the SD card inserted. Good troubleshooting @Droneted !
This is not the first time I have seen or heard of a damaged SD card causing flaky issues. The damaged card causes the system to get bogged down trying to access the card for read/write cycles. The system gets so overloaded with the priority given to the SD card read/write that other services get skipped such as the video feed (which is transmitted over a form of Wi-Fi communication.
Good to know.
Keep in mind that developers write software. So it is often imperfect. So, while they attempt to self troubleshoot during the bootup process, they don't always trap for every scenario. For example, no video feed is USUALLY due to WiFi interference. So the software says, "Look...no video feed. We must have WiFi issues." And, thus, issues the warning.
It's been my experience that, in the scale of all the P.O.S.T. firmware and troubleshooting programs I have seen in my life, the DJI offerings are average at best, often netting either cryptic or erroneous errors.
D
Reactions: RodPad
Thanks for sharing. It is information like this that helps everyone!
Reactions: RodPad
@Harleydude
I was hoping you would post your thoughts!!
My self being into programming, which was nothing like this, so many platforms today!
I Just did data base level, POS for our business. I liked it a lot.
Litchi Hub is the fun now.👍
Just knew that story was real.
You made the connection for me!
Rod ..
Jerry P
