- Joined
- Nov 2, 2016
- Messages
- 632
- Reaction score
- 233
- Age
- 78
So many threads with this question already asked. Don't be lazy to do your own research.
Tab A 8"Phil2 and CleethorpesKid, did you have to change any settings for the micro usb input on your Samsungs to get it to work? Do you have the 8" or the 9.7", and does it have the latest Samsung updates? Sorry for all the questions, but I had read about Samsung Tab S2 issues. I'm running the Pro+ with the built in screen, but am considering an xtra P4P controller to use my Samsung S2 for bigger screen and other software options. Thanks in advance.
Your noble effort to put someone in their place can be easily done without name calling. I agreed with you, reading your DH comment, but you just have to use acceptable words, DH isn't. The mods have to draw the line somewhere, and name calling is stepping over the line.I will NOT apologize for calling out A-holes when I see them. This is supposed to be a forum for HELPING people and NOT making them feel like idiots for asking questions!
If it works with 10.3 you're wise to stick with that until DJI works out the issues with iOS11. Tahoe Ed with DJI has mentioned there are problems with iOS11 and DJI G04 latest version recently, but didn't provide details about what they are. There are many in this forum already using iOS11 without compelling issues, so I'm unsure of the problems Ed is talking about. One thing that did cause problems is flying P4P with iPad Wifi on, not connected to an access point. The hunting for access point would mess up the Lightbridge video feed from the craft, apparently from pinging the channel all the time, hunting for an access point. This only happened when flying on 2.4Ghz band, and didn't exhibit this problem with 5.89Ghz band. You can try this yourself to confirm, just fly on the 2.4Ghz band with your P4P and turn on your iPad Wifi with no connection to an access point. You'll likely see lots of green screen interference, regardless of range.Seems solid and no hiccups on Go App or Netflix on iOS 10.3. I will not update unless I hear good stuff from people who have..
That actually happened a couple of times. I had "Bad radio transmission". Figured it was the WiFi so turned it off.. no worries.If it works with 10.3 you're wise to stick with that until DJI works out the issues with iOS11. Tahoe Ed with DJI has mentioned there are problems with iOS11 and DJI G04 latest version recently, but didn't provide details about what they are. There are many in this forum already using iOS11 without compelling issues, so I'm unsure of the problems Ed is talking about. One thing that did cause problems is flying P4P with iPad Wifi on, not connected to an access point. The hunting for access point would mess up the Lightbridge video feed from the craft, apparently from pinging the channel all the time, hunting for an access point. This only happened when flying on 2.4Ghz band, and didn't exhibit this problem with 5.89Ghz band. You can try this yourself to confirm, just fly on the 2.4Ghz band with your P4P and turn on your iPad Wifi with no connection to an access point. You'll likely see lots of green screen interference, regardless of range.
I suggest if you're happy with what you have, don't change anything without a really really, I mean really compelling reason. Keep the same OS and app version, and disable auto update for the GO4 app. However, if you really need a screen recorder sometime in the future, iOS11 has one built in, and it works good. But wait for the issues to be resolved with GO4, whatever they are.
Sorry, I can't help much since I don't upgrade. I'm still using GO4 version 4.0.8. However, I've seen the latest GO4 app work OK on an iPadMini4, flying a P4P with older 1.3.509 firmware, from the MAY/JUNE timeframe. I can attest to that.Has the Go App gotten worse? I was on 4.1.3 on the iPhone, which actually seemed more stable, than the 4.1.18 I am using on the iPad.
I hope my 600 nit ipad can do the job on a tropical summer sun. I am taking my bird on a trip. So far its been ok on California winter sun at below 50% brightness.The ultimate at this point in time is the DJI Crystalsky 7.85in Ultra, technically an android tablet with a 2000 nit screen, in comparison a Ipad Mini 4 is 450nits.
I find in the australian sun that the Crystalsky works perfectly, while I was always struggling to see the Mini 4, even with a hood there is an issue when you look up and your eyes need to adjust
That's a nice feature. IOS 11 has that now also for iPads. Competition is great, eh?
If you're running iOS 11, you can use the built-in screen recorder like this.How would I record my flight in real time with the iPad mini 4?
As a rule of thumb, iPad's with A7 CPU may struggle with today's Go4 app. Anything older than that will absolutely not work. A8 based iPads should work OK with Go4 today but I'd suggest not running IOS11 (released in Sept) on iPad with A8 right now until Go4 has been tuned for it. I don't think that's been done yet. Some are using IOS11 OK with Go4, but there have been reports of issues (Tahoe Ed with DJI).Ipad Mini 4 .....works great for me.... ....I was trying to make an older ipad work and finally gave up and my Iphone 6 plus is nice but I like a larger screen because there is so much information coming at you while in flight to keep up with!
