Top Phantom 4 accessories for June 2019 (by DDH)
msinger
Approved Vendor
Harrisburg, PA (US)
Website
phantomhelp.com
I've compiled a list of the top Phantom 4 accessories for June 2019. These accessories were chosen based on their sales volume on Amazon over the past month. If you're looking for some new accessories to add to your kit, this list will give you an idea of what other Phantom 4 owners are buying and using.
Homga Landing Pad
Notable features:
  • 30 inches wide
  • Made of a waterproof nylon material
  • Includes stakes to ensure the landing pad stays in place
  • Fold up and store in the included storage bag
More details can be found here on Amazon or here in the DJI Store.
SanDisk 64GB Micro SD Memory Card
Notable features:
  • U3 memory card
  • Fast enough to record any type of photos/video produced by the Phantom
  • Plenty of storage space to capture all of the needed photos/video
More details can be found here on Amazon.
ENGPOW Fireproof LiPo Bag
Notable features:
  • Made of silicon coated fiberglass with heat blocking aluminum foil inside
  • Large enough to hold multiple Phantom batteries
  • Keeps batteries safe while charging, traveling, and storing
DJI High Capacity Phantom 4 Battery
Notable features:
  • Created, designed, and extensively tested by DJI
  • Guaranteed to work well with your Phantom since the battery is an OEM DJI accessory
DJI Goggles
Notable features:
  • Dual 1920 x 1080 HD screens
  • Integrated touchpad to navigate through menus within the goggles
  • HDMI input and 3.5mm audio jack
  • Up to 6 hours of battery life
More details can be found here on Amazon or here in the DJI Store. And if you want to save a few bucks, you can purchase refurbished DJI goggles here.
DJI Low-Noise Props
Notable features:
  • Guaranteed to work well with your Phantom since the props are an OEM DJI accessory
  • Slightly quieter prop noise
HUL Aluminum Carrying Case
Notable features:
  • Aluminum frame construction with ABS plastic panels
  • Can store the Phantom with the props attached
DJI Props
Notable features:
DJI Sunshade
Notable features:
  • Shades your mobile device screen from sunlight
  • Collapsible and easy to carry
Yx Parallel Battery Charger
Notable features:
  • Charges 3 batteries simultaneously in about 80 minutes
  • Able to charge the remote controller
  • Anodized aluminum case offers a non-conductive layer
  • Ground earth connection for safety
RCGEEK Sunshade
Notable features:
  • Folds up for easy storage
  • Small magnets hold the sunshade closed when folded
PGYTECH Drone Landing Pad
Notable features:
  • 20 inches wide
  • Weighted to keep it in place in windy conditions
DJI Battery Charging Hub
Notable features:
  • Charges three batteries (one at a time) in 3.5 hours
  • Toggle the switch to discharge batteries down to the storage level
  • Connects to power cable from the OEM DJI battery charger
Hooshion Lanyard
Notable features:
  • Made of high tenacity nylon
  • Adjustable length
Ultimaxx Backpack
Notable features:
  • High quality water resistant nylon exterior
  • High density EVA foam interior to shield your gear from impact-related damage
  • Can hold the Phantom, remote controller, 3 batteries, charger, and other small accessories
CamKix Extended Landing Gear
Notable features:
  • Increases width of landing gear to make landings more stable
  • Quickly snaps onto the bottom of the Phantom landing gear
  • Included gimbal guard protects the camera and gimbal
DJI Prop Guards
Notable features:
  • Guaranteed to work well with your Phantom 4 since the guard is an OEM DJI accessory
  • See them in action here
DJI Car Battery Charger
Notable features:
DJI HDMI Output Module
Notable features:
  • Output 720p live HD video stream to an HDMI device
  • Commonly used to display video on goggles or a second screen
  • Includes Mini-HDMI output port, Micro-USB port, USB port, and a CAN expansion port
Hooshion Antenna Range Extender
Notable features:
  • Boosts the remote controller signal to increase its range
  • Folds closed for storage
Reactions: DroneB
