what setting would make the phantom rotate slower ?
Discussion in 'General Discussion' started by izzydrone, Aug 12, 2015.
  1. izzydrone
    what setting would make the phantom rotate slower ? Ive followed a few other threads recommendation to turn down braking and tilt, which worked well... but how can I get it to turn slower ? is that possible ? I am talking about when you push the left knob either left or right. How can i get that sensitivity down ?
  2. DreamsHD
    Just barely put pressure on the stick
  3. izzydrone
    haha yea, its really hard to get it smooth ... it will be all smooth.... and then it speeds up ever so slightly messes the shot up. trying to get a consistency with less room for user error. am i dreaming ?
    I wish there was a sensitivity knob on the controller you could easily adjust...
  4. dirkclod
    dirkclod Moderator
    Staff Member
    Amory Mississippi
    Ya'll talking P3 ?
  5. izzydrone
    yes p3
  6. dirkclod
    dirkclod Moderator
    Staff Member
    Amory Mississippi
    OK ..Someone should me were you could slow down the yaw in the app . I don't have it as I don't have the P3 but bet I could find it for you .
  7. izzydrone
    i did slow the yaw... i guess i didn't slow it enough... ok ill play around with it next flight and update... anyone have a recommended yaw setting ?
  8. dirkclod
    dirkclod Moderator
    Staff Member
    Amory Mississippi
    Sorry I jumped in izzy but no one had what they have in their signature and I do have a switch for the P2 that cuts it down .
    Good luck :)
  9. msinger
    Approved Vendor
    Harrisburg, PA (US)
    izzydrone, you'll only be able to do this with practice. There is no switch, setting, etc. that'll do this work for you.
    jryser likes this.
  10. Zerone
    S.Wales, UK
    When I need a slower Yaw control I lengthen the sticks. The sticks on the P3P are adjustable, not sure on the other versions. I just screw the top part of the stick out to the required length and screw the lower section up to lock it in place.
  11. IflyinWY
    Where the deer and the antelope play
  12. Mako79
    Sydney Australia
  13. Cyclone
    Essex, UK
    Buying some Phantom knobs might help with better control.
    Or, unscrew the sticks so they stick out further.
    dirkclod likes this.
  14. izzydrone
    I lengthened the sticks... Don't think it helped too much...what's a good setting for the yaw?
  15. timmer
    New Orleans
    Izzy,
    Here is something I made out of an old Hotel key card:
    [​IMG]
    You can "pinch" the part of the card, on the left side of the controller, to make easy, slow, left and right yaw:
    [​IMG]
    I just used some scissors and a hole punch on an old hotel key card.
  16. wotblake
    Awesome idea
  17. izzydrone
    that seems like it would work... im leaning to trying that solution.
  18. wotblake
    I really wish DJI would build a solution into DJI Go. If I could take the P3 up to 400 feet and hit a button in the app for a slow 360 yaw - that would be awesome.
  19. izzydrone
    ImageUploadedByPhantomPilots1439594173.306203.jpg wow found a old cvs key card perfect fit hehe.
Similar Threads - setting phantom rotate Forum Date
Phantom 3 Pro Photos In 960X540 - Can't Find Settings To Change It Pro/Adv Discussion Oct 22, 2017
Settings camera for phantom 4 pro Phantom 4 Pro Help Oct 16, 2017
Need help setting up new phantom 4 pro remote General Discussion Oct 11, 2017
Phantom 4 Pro "Color, Style, LUTs and general setting" tips? (Help) Phantom 4 Pro Discussion Jul 14, 2017
PolarPro Aurora LUTs for Phantom 4 Pro: settings? Phantom 4 Pro Discussion Jul 13, 2017
