- Joined
- Jun 12, 2017
- Messages
- 5
- Reaction score
- 0
- Age
- 43
Hello friends,
I have a couple of questions on how Litchi works with Waypoints recording. I mean flying the drone at-place, adjusting the gimbal and recording the waypoint there for you to come back later and do the mission.
1. Does Litchi record X,Y,Z parameters with "actual" altitude? I mean, if you take of from a different home point and execute the mission, will it go at the same spot or will it use the relative altitude (e.g. 30m) that it had compared to your initial home point when recorded?
2. After you record the waypoint, you may want to add curves in the mission. How does Litchi cope with the curve at a point that you've recorded before, since it won't be at the same place when passing by? Same altitude and gimbal angle, just different X,Y?
I hope the questions are clear enough, not sure!
PS: I'm flying a Phantom 4.
