Update 1.4fw, unstable straight line fly...
Well gentleman....it seems we and a few users on RCgroups, are complain about a small "drifting" on the machines....and im talking about some experienced users coming from P1 and Inspire machines...
Guys:
Are you shure when recording and going just forward, it doesn`t drift a little?
Check with your eyes and records....use a road on the ground as reference....
Today I've calibrated the rc and next flight I'll try. I will calibrate also the compass because I've a mod value of 1450~
1450 seems ok...maybe just a little down.....but im not expert on this department...
Share with us your flights opinions.....
Waiting this weekend for more tests.....
Yes but I'm looking for a perfect straight flight and so before to say that it's not the compass the cause i would like to have it as close as possible to 1500.
Imu check return that is all ok so i will not calibrate imu.
Reactions: Mordor
The weird thing is that i made a IMU before my first fly when i did buy the drone.
After that....just normal compass calibrations, even in places with some metal.....and 0 problems.
Now, after this update, some users report all values are ok, everything check and re.checked, and still it sometimes drifts a little....witch is bad, dangerous if near obstacles and ruins a good moving shoot....
I need tests.....but i have a feeling.....
Yes i notice the same, i hope it will be not necessary to downgrade the firmware. Anyway in that case I'll flash the developers firmware that i had before, works perfectly and I've all the flight modes enabled too.
Unfortunately i can't fly so often in this period because of little time.
Thanks for your contribute. So i presume you`re a beta tester? cool!
I just try here at my room the Litchi software....seems to be very stable. If i don`t succed, i will return to 1.1.9fw, and use for POI the Litchi option...so i will have the best of the 2 worlds...
If i knew it, i would stay on 1.1.9 factory mode and use 3º party software....oh heell, always learning!
Lets hope for the best! Keep the feedback ;-)
Reactions: StevenQX
To use poi with litchi you need the developer firmware 1.4.005 or the latest 1.4.010 for everyone
Reactions: Mordor
Ah! I did presume it wouldn`t bee needed.....lolol
Another door closed.....POI or Stable flights, thats the question! ;-)
Tested today, well after a compass calibration it seems to fly fine and perfectly straight. Tested 2 batteries in a strong windy condition. My compass mod value now is 1500~ before was 1450.
Reactions: Mordor
Some update:
- Warming warning, at the beginning, seems gone.
- At certains points of filmage i notice drifting, but also the use of the forward joystick, incorrectly...
Need more tests......maybe its starting "learning"....and stabilization...
Reactions: StevenQX
Another flight yesterday and again it doesn't seem that the bird fly straight. I've to investigate again wtf
Stick input is correct but not the result.
Reactions: Mordor
Same s*** here.....i have some good movie plans ruined thanks to this piece of crap firwmare....
Reactions: Goldni
I'm asking also on RC Group about this problem and someone told me that DJI know about this issue and a fix will come. I've not yet done an IMU cal, is the only thing i miss to do but i remember that you've done it more than one time...
PS: have you reduced active braking setting? I was wondering if this could be a reason, i've active braking set at 70%...
No i haven`t....maybe gonna try a RC calibration this afternoon.....
Yes i made some posts about this isse on RC and a few users report it too and confirm same problem..
I made 2 IMU so far.....
Reactions: StevenQX
I've noticed the same thing. Doesn't fly in a straight line and drifts bigtime when it is supposed to be in a GPS stabilized hover. Done IMU/gimble/compass calibration numerous times. It used to be rock solid.
Reactions: StevenQX
I've opened a thread on DJI Forum too and happens on both P3A and P3P.
DJI Forum|P3A do not fly straight after latest 1.4.010 firmware update
Great!
Later i will give my contribute, since im one of the first to notive it!
Good idea!
drifting problem here also, will not fly a straight line anymore, always did before the update…thought it was just me..will try a new IMU cal and RC cal and see what happens…hopefully DJI fixes this fast
Reactions: Mordor
I doubt about new calibrations.....but please keep us informed and i hope it solves the problem!
apktuti
