new version is out
- the tool should be able to convert incomplete flightlogs
- 8 new columns added: motor1EscmState .. motor8EscmState (most probably for Mavic only)
that file is either corrupt or it has different number-type in CUSTOM.distanceHi,
Something there is left! Check the log, which producing this output! I can test the tool well. I have more then 4000 logs
schach: real world altitude isn't present neither in TXT logs nor DAT logs
I believe that as soon as Phantom gets first GPS fix, it sets homepoint's height to that obtained altitude and that's all, it never resets it again during the flight - then it uses barometric sensor only
so that's the reason why the altitude is always off by so much
at least that offset is constant during the flight
I don't know about any easy way to get the correct altitude data
and nobody asked for it until now you do
maybe in the future I'll come with something, if there are more requests
First of all, a big thanks to ferraript and everybody else who contributed to this project, this converter is exactly what I was looking for! I'm a big fan and long-time user of Dashware and I just joined the DJI family, so of course I was very curious to see what logs could be extracted from my Phantom 3 Standard. Pretty amazing, I have to say... 10HZ and 200+ parameters... wow... a Dashware dream!
I might be missing something, but my converted log doesn't seem to provide any compass-related info. I know the heading can be derived from GPS coordinates, but I was wondering if the aircraft compass reading is logged somewhere, maybe under an not-so-obvious name. Thanks!
All the data is there, it just has different terminology. Yaw is your compass reading. Btw, you might try not making it a habit of asking what each data column refers to because I don't think anyone knows the answer to all of them.
Also on the Yaw there is a 360 degree option you can select from a check box. If not checked the column will display as 180 degree type setup.
In case you don't know...but there is a somewhat similar setup for the .dat flight log files.
Impressive stuff, no doubts, the amount of data that the Phantom dumps into those logs is really amazing. I'm working on my own Dashware Data Profile, matching the TXTlogToCSVtool output and tailored for the P3S (and my needs), will definitely post it once it's ready for public consumption.
Great tool, but I cannot find the "meters above sea level". Any hint?
