PhantomHelp Logviewer Question
Upper Canada Village
Trying to understand what I see through the PhantomHelp Logviewer versus that what I see in the csv that created it. Specifically, when I open the csv file and look at the columns "downlinkSignalQuality" and "uplinkSignalQuality" for the flight linked below I see "100%" for down and "0-100%" for uplink. But when I view this same csv file within the logviewer I see the odd "Downlink restored" and even "Downlink lost" messages. How can this be when the downlinkSignalQuality is 100% for every row in the csv file. Further more, I see nothing in the Logviewer indication a problem with the uplink but the csv file has numerous rows (several minutes) of 0% signal.
What am I missing here. Am I reading this wrong??? Anyway, here is a link to the flight in question
Phantom Log Viewer - PhantomHelp.com
How is that different from what I linked above??? As far as I can see its the same and my questions are related to what I see in this viewer vs what I see in the csv file that created it.
Well if I knew the answer, I would have replied with answer.
To me I thought you should have posted in this thread,
Free online DJI GO & Litchi flight log viewer
from the beginning.
Maybe the creator would most likely have an answer to your question. :rolleyes:
This also is why I included his name in my reply. ;)
Rod
from the beginning.
Rod
Sorry o_O Totally misunderstood your intent
The CSV file was created by Litchi. You'll have to ask them how they are determining the signal quality.
Reactions: RodPad
It is not important to me how they determine signal quality. It is what is reported in the logviewer I am trying to understand. For instance, in the flightlog linked above, at 7m 21.6s, Logviewer reports "Downlinl Lost" shortly followed by 2 messages "Downlink restored". When I look at the same timeframe within csv file I cannot find anything in the data that corresponds to this downlink lost. What am I missing???/
Here are the two areas in your Litchi log where my log viewer is showing the downlink was lost:
Aha... got it.... I see there is 1 second in between the first two highlighted rows and 5.1 between the next two. Do you check for up signal was well???
LIke I said, you'll need to contact Litchi about that. I don't know how they are determining the signal strength.
tpren3
