I bought my P4 refurbished and the front sensors work but I dont think the bottom works. If i use the controller to land, it will not stop or avoid objects below. Does the bottom sensors only work for RTH or a bad refurbished?
Thanks, I thought I a bad unit.The bottom sensors are not used to avoid obstacles. That's working as designed.
Bott is vps front obstical advoidsorry vps is vision positioning systemBottom sensors? What are they used for? I have used the front sensor several times but not the bottom ones.
Thanks,
Jim
WA5TEF
I heard the phantom 4 had 2 different sensors, one forward and one downward. I guess the downward sensor is for better stability.Bottom sensors? What are they used for? I have used the front sensor several times but not the bottom ones.
Thanks,
Jim
WA5TEF
I bought my P4 refurbished and the frint sensors worj but I dont think the bottom works. If i use the controller to land, it will not stop or avoid objects below. Does the bottom sensors only work for RTH or a bad refurbished?
Hi i never checked that with mine and some fast flights are half metre above the ground,got BIG flat feilds here,,i be a bit cautious nowYeah, I remember reading about that but had forgot it. So the drone should have accurate altitude readings using these systems rather than relying on GPS? My Phantom 4's altitude is off by 10 to 15 feet on most every flight. I am afraid to fly it as low as I would like to because of this. I believe several more have posted about having this same problem with altitude readout. I've tried it in DJI GO and Litchi with the same error.
Thanks,
Jim
WA5TEF
