Mountain altitude change
Pennsylvania
I tried searching but did not see this question answered. If you're flying up in the mountains and your max altitude is set to 150m/400ft, once you fly over a cliff and your altitude all of the sudden doubles, comparing to the ground at that level vs level of where you started, will the Phantom platform make itself "drop below max altitude"?
The altitude will not change and your Phantom will not drop when you fly over the cliff. The altitude is measured from the takeoff point (not the ground below your Phantom).
It will only display a negative altitude after you fly below the original home point.
Suprspooky
