Mountain altitude change
Discussion in 'General Discussion' started by Ramphex, Mar 24, 2016.
  1. Ramphex
    Pennsylvania
    I tried searching but did not see this question answered. If you're flying up in the mountains and your max altitude is set to 150m/400ft, once you fly over a cliff and your altitude all of the sudden doubles, comparing to the ground at that level vs level of where you started, will the Phantom platform make itself "drop below max altitude"?
  2. msinger
    Approved Vendor
    Harrisburg, PA (US)
    The altitude will not change and your Phantom will not drop when you fly over the cliff. The altitude is measured from the takeoff point (not the ground below your Phantom).
  3. Ramphex
    Pennsylvania
    Will it then display negative altitude if I perhaps want to land or cruise near the bottom of this cliff/altitude change area?
  4. msinger
    Approved Vendor
    Harrisburg, PA (US)
    It will only display a negative altitude after you fly below the original home point.
  5. Ramphex
    Pennsylvania
    Thank you sir
Similar Threads - Mountain altitude change Forum Date
Rocky Mountains, high altitude drone flight. Photos and Video Oct 27, 2016
RTH altitude in the mountains Pro/Adv Discussion Aug 22, 2016
flying in the mountains with Litchi - relative altitude issues Pro/Adv Discussion Jul 8, 2016
Mountain Peak Flight Altitudes Pro/Adv Discussion Dec 10, 2015
Crashed my Phantom 3 in Nepal mountains flying at altitudes up to 4000m, video General Discussion Dec 7, 2015
