Just a thought, but am unsure if this is correct. I know that P4's ( At least on IOS ) create .dat files on the device, and I am assuming along with .txt files ( Could be wrong there ). It might be worth taking a look see for any .dat files on your device dated the same as the .txt log file.
Off the top of my head, I do not recall the difference in supplied data between the two, but they are slightly different. It is possible to at least get a few more bit's of data that were not in the .txt file. As I said, this could be IOS only and if you are using the built in monitor the .txt files may be all you have. Just something to look at for possible additional data.
The DAT files are always created on the mobile device. They contain far more data fields than the txt but the sample rate is still 10 Hz.
EDIT: Apologies for the silly smilies - the forum software seems to be unable to ignore certain character combinations.
3.3.0-Tablet
aircraft_condition:fsm_state
aircraft_condition:int_fsm
aircraft_condition:land_state
aircraft_condition:last_fsm
aircraft_condition:near_gnd
aircraft_condition:safe_fltr
aircraft_condition:UP_acc_t
aircraft_condition:UP_state
aircraft_condition:UP_TF_t
ATTI_MINI0:s_agz0
ATTI_MINI0:s_cnt0
ATTI_MINI0:s_pgz0
ATTI_MINI0:s_qw0
ATTI_MINI0:s_qx0
ATTI_MINI0:s_qy0
ATTI_MINI0:s_qz0
ATTI_MINI0:s_rsv00
ATTI_MINI0:s_rsv10
ATTI_MINI0:s_vgz0
Attribute|Value
battery_info:ad_v
battery_info:ave_I
battery_info:cap_per
battery_info:dyna_cnt
battery_info:f_cap
battery_info:I
battery_info:l_cell
battery_info
battery_info
battery_info
battery_info:r_cap
battery_info:r_time
battery_info:right
battery_info:temp
battery_info:vol_t
Controller:act_act_id
Controller:act_req_id
Controller:cmd_mod
Controller:ctrl_level
Controller:ctrl_mode
Controller:ctrl_pitch
Controller:ctrl_roll
Controller:ctrl_thr
Controller:ctrl_tick
Controller:ctrl_yaw
Controller
Controller
Controller:fw_flag
Controller:max_height
Controller:max_radius
Controller:mod_req_id
Controller:mode_switch
Controller:mot_sta
Controller:motor_state
Controller:OH_take
Controller:rc_cnt
Controller:sig_level
Controller:sim_model
Controller:sup_rc
ConvertDatV3
ctrl_acc_vert_debug:acc_cmd
ctrl_acc_vert_debug:acc_fdbk
ctrl_acc_vert_debug:acc_tag
ctrl_acc_vert_debug:thr_cmd
ctrl_horiz_ang_vel_debug:gyro_cmdx
ctrl_horiz_ang_vel_debug:gyro_cmdy
ctrl_horiz_ang_vel_debug:gyro_cmdz
ctrl_horiz_ang_vel_debug:gyro_fbkx
ctrl_horiz_ang_vel_debug:gyro_fbky
ctrl_horiz_ang_vel_debug:gyro_fbkz
ctrl_horiz_ccpm_debug:fix_lift
ctrl_horiz_ccpm_debug:fix_tilt_x
ctrl_horiz_ccpm_debug:fix_tilt_y
ctrl_horiz_ccpm_debug:fix_tor
ctrl_horiz_ccpm_debug:raw_lift
ctrl_horiz_ccpm_debug:raw_tilt_x
ctrl_horiz_ccpm_debug:raw_tilt_y
ctrl_horiz_ccpm_debug:raw_tors
ctrl_horiz_ccpm_debug:thr_max
ctrl_horiz_ccpm_debug:thr_min
ctrl_horiz_debug:AL_avoid
ctrl_horiz_debug:AL_bat
ctrl_horiz_debug:AL_final
ctrl_horiz_debug:AL_gmb_pri
ctrl_horiz_debug:AL_gmb_typ
ctrl_horiz_debug:ao_workable
ctrl_horiz_debug:ap_os_F
ctrl_horiz_debug:avd_ob_os_F
ctrl_horiz_debug:avoid_en
ctrl_horiz_debug:CL_tors
ctrl_horiz_debug:emg_brk_F
ctrl_horiz_debug:flw_gmb_F
ctrl_horiz_debug:G_tgt_gyro
ctrl_horiz_debug:GF_cur_yaw
ctrl_horiz_debug:GF_tgt_yaw
ctrl_horiz_debug:gmb_mode
ctrl_horiz_debug:gmb_on
ctrl_horiz_debug:gmb_pos
ctrl_horiz_debug:gmb_refYaw
ctrl_horiz_debug:h_api_frm
ctrl_horiz_debug:h_api_mode
ctrl_horiz_debug:H_fence_os_F
ctrl_horiz_debug:h_lmt_os_F
ctrl_horiz_debug:horiz_mode
ctrl_horiz_debug:hov_brk_T
ctrl_horiz_debug:hov_cfrm_T
ctrl_horiz_debug:hov_flag
ctrl_horiz_debug:hov_px
ctrl_horiz_debug:hov_py
ctrl_horiz_debug:hov_state
ctrl_horiz_debug:in_flw_gmb
ctrl_horiz_debug:near_bnd
ctrl_horiz_debug:nearest_ob
ctrl_horiz_debug
ctrl_horiz_debug
ctrl_horiz_debug:R_os_F
ctrl_horiz_debug:tilt_cmd_x
ctrl_horiz_debug:tilt_cmd_y
ctrl_horiz_debug:track_en
ctrl_horiz_debug:trck_yaw_v
ctrl_horiz_debug:trs_f_flg
ctrl_horiz_debug:trs_f_req
ctrl_horiz_debug:trs_lck_st
ctrl_horiz_debug:trs_lck_T
ctrl_horiz_debug:trs_mod
ctrl_horiz_debug:trs_p_cmd
ctrl_horiz_debug:trs_p_lck
ctrl_horiz_debug:trs_v_cmd
ctrl_horiz_debug:true_rad_lmt
ctrl_horiz_debug:v_ctrl_mod
ctrl_horiz_debug:vel_cmdx
ctrl_horiz_debug:vel_cmdy
ctrl_horiz_debug:watch_mode
ctrl_horiz_motor_debug
ctrl_vert_debug:ap_high_os_F
ctrl_vert_debug:gnd_os_F
ctrl_vert_debug:high_os_F
ctrl_vert_debug:hit_gnd
ctrl_vert_debug:landing_tyoe
ctrl_vert_debug:low_os_F
ctrl_vert_debug:near_bound
ctrl_vert_debug:rf_os_F
ctrl_vert_debug:takeoff_T
ctrl_vert_debug:true_h_lmt
ctrl_vert_debug:v_lmt_os_F
ctrl_vert_debug:vert_brk_T
ctrl_vert_debug:vert_flag
ctrl_vert_debug:vert_mode
ctrl_vert_debug:vert_pos
ctrl_vert_debug:vert_state
err_code:gcm0_act
err_code:gcm0_break
err_code:gcm0_dev
err_code:gcm0_err
err_code:gcm0_fault
err_code:gcm1_act
err_code:gcm1_break
err_code:gcm1_dev
err_code:gcm1_err
err_code:gcm1_fault
err_code:gcm2_act
err_code:gcm2_break
err_code:gcm2_dev
err_code:gcm2_err
err_code:gcm2_fault
err_code:imu_stat
err_code:imu0_act
err_code:imu0_dev
err_code:imu0_err
err_code:imu0_fault
err_code:imu1_act
err_code:imu1_break
err_code:imu1_dev
err_code:imu1_err
err_code:imu1_fault
err_code:imu2_act
err_code:imu2_break
err_code:imu2_dev
err_code:imu2_err
err_code:imu2_fault
err_code:mag_stat
err_code:mc_act
err_code:mc_dev
err_code:mc_err
err_code:mc_fault
esc_data:cnt_1
esc_data:cnt_2
esc_data:cnt_3
esc_data:cnt_4
esc_data:cnt_5
esc_data:cnt_6
esc_data:cnt_7
esc_data:debug0_1
esc_data:debug0_2
esc_data:debug0_3
esc_data:debug0_4
esc_data:debug0_5
esc_data:debug0_6
esc_data:debug0_7
esc_data:debug0_8
esc_data:debug1_1
esc_data:debug1_2
esc_data:debug1_3
esc_data:debug1_4
esc_data:debug1_5
esc_data:debug1_6
esc_data:debug1_7
esc_data:debug1_8
esc_data:debug2_1
esc_data:debug2_2
esc_data:debug2_3
esc_data:debug2_4
esc_data:debug2_5
esc_data:debug2_6
esc_data:debug2_7
esc_data:debug2_8
esc_data:I_1
esc_data:I_2
esc_data:I_3
esc_data:I_4
esc_data:I_5
esc_data:I_6
esc_data:I_7
esc_data:I_8
esc_data
esc_data
esc_data
esc_data
esc_data
esc_data
esc_data
esc_data
esc_data
esc_data
esc_data
esc_data
esc_data
esc_data
esc_data
esc_data
esc_data
esc_data:speed_1
esc_data:speed_2
esc_data:speed_3
esc_data:speed_4
esc_data:speed_5
esc_data:speed_6
esc_data:speed_7
esc_data:speed_8
esc_data:status_2
esc_data:status_3
esc_data:status_4
esc_data:status_5
esc_data:status_6
esc_data:status_7
esc_data:status_8
esc_data:status1
esc_data:temp_1
esc_data:temp_2
esc_data:temp_3
esc_data:temp_4
esc_data:temp_5
esc_data:temp_6
esc_data:temp_7
esc_data:temp_8
esc_data:V_1
esc_data:V_2
esc_data:V_3
esc_data:V_4
esc_data:V_5
esc_data:V_6
esc_data:V_7
esc_data:V_8
esc_data:v_out_1
esc_data:v_out_2
esc_data:v_out_3
esc_data:v_out_4
esc_data:v_out_5
esc_data:v_out_6
esc_data:v_out_7
esc_data:v_out_8
IMU_ATTI_0:agx0
IMU_ATTI_0:agy0
IMU_ATTI_0:agz0
IMU_ATTI_0:alti0
IMU_ATTI_0:atti_cnt0
IMU_ATTI_0:ax0
IMU_ATTI_0:ay0
IMU_ATTI_0:az0
IMU_ATTI_0:filter_stat0
IMU_ATTI_0:gbx0
IMU_ATTI_0:gby0
IMU_ATTI_0:gbz0
IMU_ATTI_0:lati0
IMU_ATTI_0:long0
IMU_ATTI_0:mx0
IMU_ATTI_0:my0
IMU_ATTI_0:mz0
IMU_ATTI_0
IMU_ATTI_0:qw0
IMU_ATTI_0:qx0
IMU_ATTI_0:qy0
IMU_ATTI_0:qz0
IMU_ATTI_0:sensor_stat0
IMU_ATTI_0:svn0
IMU_ATTI_0:tx0
IMU_ATTI_0:ty0
IMU_ATTI_0:tz0
IMU_ATTI_0:vgx0
IMU_ATTI_0:vgy0
IMU_ATTI_0:wx0
IMU_ATTI_0:wy0
IMU_ATTI_0:wz0
IMU_EX_0:ex_cnt0
IMU_EX_0:flag_err0
IMU_EX_0:flag_navi0
IMU_EX_0:flag_rsv0
IMU_EX_0:rtk_alti0
IMU_EX_0:rtk_lati0
IMU_EX_0:rtk_long0
IMU_EX_0:us_p0
IMU_EX_0:us_v0
IMU_EX_0:vo_px0
IMU_EX_0:vo_py0
IMU_EX_0:vo_pz0
IMU_EX_0:vo_vx0
IMU_EX_0:vo_vy0
IMU_EX_0:vo_vz0
new_mvo_feedback:height
new_mvo_feedback:heightUncertainty
new_mvo_feedback:hoverPointUncertainty1
new_mvo_feedback:hoverPointUncertainty2
new_mvo_feedback:hoverPointUncertainty3
new_mvo_feedback:hoverPointUncertainty4
new_mvo_feedback:hoverPointUncertainty5
new_mvo_feedback:hoverPointUncertainty6
new_mvo_feedback
new_mvo_feedback
new_mvo_feedback
new_mvo_feedback:reserved1
new_mvo_feedback:reserved2
new_mvo_feedback:reserved3
new_mvo_feedback:reserved4
new_mvo_feedback:Vel_X
new_mvo_feedback:Vel_Y
new_mvo_feedback:Vel_Z
new_mvo_feedback:velocityUncertainty1
new_mvo_feedback:velocityUncertainty2
new_mvo_feedback:velocityUncertainty3
new_mvo_feedback:velocityUncertainty4
new_mvo_feedback:velocityUncertainty5
new_mvo_feedback:velocityUncertainty6
new_mvo_feedback:visionObservationCount
ns_data_component:ns_cmpnt
ns_data_debug:d00
ns_data_debug:d01
ns_data_debug:d02
ns_data_debug:d03
ns_data_debug:d04
ns_data_debug:d05
ns_data_debug:d06
ns_data_debug:d07
ns_data_debug:d08
ns_data_debug:d09
ns_data_debug:d10
ns_data_debug:d11
ns_data_debug:d12
ns_data_debug:d13
ns_data_debug:d14
ns_data_debug:d15
ns_data_debug:d16
ns_data_debug:d17
ns_data_debug:d18
ns_data_debug:d19
offsetTime
serial_api_inputs:avoid_E
serial_api_inputs:bit_S
serial_api_inputs:cmd_ack
serial_api_inputs:cmd_req
serial_api_inputs:ctrl_dev
serial_api_inputs:f_test
serial_api_inputs:fact_cnt
serial_api_inputs
serial_api_inputs
serial_api_inputs:sdk_fdfd_x
serial_api_inputs:sdk_fdfd_y
serial_api_inputs:sdk_pitch_y
serial_api_inputs:sdk_roll_x
serial_api_inputs:sdk_thr_z
serial_api_inputs:sdk_yaw
serial_api_inputs:sub_mode
smart_battery_info:fly_t_for_gh
smart_battery_info:fly_t_for_land
smart_battery_info:gh_level
smart_battery_info:go_home_cmd
smart_battery_info:go_home_cnt
smart_battery_info:land_level
svo_avoid:AL_WF
svo_avoid:AO_EN
svo_avoid:AO_WF
svo_avoid:AO_WF_1
svo_avoid:Boundary_F
svo_avoid:Brake_WF
svo_avoid:FL_F
svo_avoid:GHA_EN
svo_avoid:HGL_WF
svo_avoid:Overshoot_F
svo_avoid:RL_F
svo_avoid:RL_WF
svo_avoid:UA_EN
svo_avoid:V_AL_WF
svo_avoid:V_LL_WF
Tick#
usonic:usonic_h[meters]
