RTH
I’ve just bought a DJI 4 drone after crashing my old one, I am using the original controller the problem is when I command RTH the drone goes up to 120mtrs. The setting for avoiding trees is set at 40mtrs.
How can I change this?
Welcome to the forum!
"The setting for avoiding trees is set at 40mtrs."
Where do see this setting at?
"when I command RTH the drone goes up to 120mtrs."
How do you know it goes up to120mtrs?
Rod ..
Hi I use my mobile phone, the 40mtr setting is to clear the trees beside my garden and the 120mtrs is the maximum height setting. Someone suggested it might be something to do with the drone code? not sure he meant on that one.
The drone is a replacement for my original one it is “linked” ok
Not sure why it's overriding your 40m RTH setting but could the 40 meters be showing up as 120 feet on screen? If not, try clearing the cache or even delete then reinstall GO 4 then afterwards set a new RTH height in settings. If you find the solution let us know, could help others.
It has nothing to do with the drone code.
Before deleting or reinstalling anything, the best way to find out the reason the drone is ascending further than you expect, post your flight data for someone to investigate.
The explanation will be in there somewhere.
To post your flight data there are a couple of options ...
1. Go to DJI Flight Log Viewer | Phantom Help
That will give you a detailed report on the flight data.
Come back and post a link to the report it provides and someone might be able to analyse it and give you an understanding of the cause of the incident.
or
2. Just post the .txt file here
or
3. If you use Airdata, you can view the flight data on Airdata and post a link for the Airdata report
I have tried everything suggested and the drone still climbs to 120mtrs, which is maximum height setting the only way to bring it down is to ignore RTH and fly it home manually.
There must be a reason for this, the controller is my prisoner and the. Drone is a replacement which has the
Ok, thanks I’ll let you know.
I have now tried everything suggested with settings nothing seems to work I have set the RTH high at 30mtrs and the max height to 100 mtrs.
I then fly for 5 mins away from the take off point press RTH and it climbs up to 100mtrs and stay there, probably until the battery goes flat.
No idea where to go from here.
@Falcoray, the link that @Meta4 shared?
You won't believe what is in the data.
We have been here a while, look at our number of posts, etc.
If you need help obtaining, the info, many here will help.
The pay is not good here, its helping somebody and we still learn as we go.
@Meta4, is my list of the top 10 on the flight data provided. I can easily come up with 25 top members.
Rod ..
BTW, its your turn. :) 👍👌
Reactions: captainmilehigh
Rod ..
Rod ..
Hi Rod I’m sorry I’ve got a bit lost on this forum!
In answer to your question, the 40mtr RTH setting doesn’t seem to have any effect whereas the max height setting of 120mtrs is the height, as shown on my screen, where the drone goes to when I set RTH. I think this has happened to other drones it’s just a question of can this be corrected.
My original drone which is the same model as the new one, although the camera and a few other parts are broken, still works with the RTH setting
Reactions: RodPad
@Falcoray , I'm happy I didn't scare you off. 👍
Sharing the flight data would have a lot of facts, reality it is going to be something new for you to learn.
My thoughts now, take a screen shot of where you see any of these RTH settings. Then post them here.
Are you using a PC on this forum if so, Windows or Mac?
Rod ..
Rod ..
Hi Rod I’m using my iPad which I attach to my controller to record my flights. Can I download a short video on this forum?
Just pics, a simple screen shot, picture is a good start.
Videos, you need upload etc, then share the link, could be on, one drive, gdrive, dropbox, YouTube, vimeo.
You use the attach files to do that.
"Are you using a PC on this forum if so, Windows or Mac?"
That was the most important question for myself.
Rod ..
Rod ..
Just had another thought I still have my
I don’t use a pc I only use my iPhone or iPad.
I’ve just had another thought I flew my old broken camera less drone yesterday, it is the same model as the new one, and it behaved perfectly. It was about 400 mtrs away at a height of 100 mtrs hit RTH and it came back landed very close to where it took off.
Question is can I download all info from that one and transfer it to the new one?? Just a thought!
Reactions: RodPad
"Question is can I download all info from that one and transfer it to the new one?? Just a thought!"
I have not a clue what your thought is.
I need,
#1 "Are you using a PC on this forum if so, Windows or Mac?"
#2 Can you provide a screen shot of where these RTH settings are, what is set on mobile device.
Rod ..
