msinger
Approved Vendor
- Joined
- Oct 30, 2014
- Messages
- 31,962
- Reaction score
- 10,787
- Location
- Harrisburg, PA (US)
- Website
- phantomhelp.com
Jake at maxxuav.com can do everything for you. I sent him my controller and I had it back in 4 days. Great customer service and amazing workmanship.I am interested to modify my phantom 4 to get a better range.
But I do not feel comfortable to do this myself , do you know someone who does this modification nicely and how much is the charge for this
For everything including the dbs antenna, hardware, upgraded cables , battery , 2 amps, custom mount and labor for the modification the total was $ 450 and worth every penny. Jake is incredible and he's quick to respond if you have a question . I won't be shopping anywhere else ever again .How much it costs total
You can either just do the dbs itelite antenna just by itself which doesn't need any power. Or you can do the dbs antenna with dual amps which uses a 13000 mah anker battery block. The battery is located underneath the UK logo on the mount.I am confused , you said battery , I saw iLite modification without batteries , are there two different modification , and if so what is the difference in range and price , please post more pictures of the final product
I received the new short blue cables today from maxxuav and put them on.... I'll let this pic explain the difference:, wish I could change the title of this thread to say the least. I could.n't be happier with this antenna solution, I was like a little kids d dancing around
Congratulations!!! Is that one way? Or round trip?
Finally figured out how to get the antenna bases out without destroying them so this morning I took my tx back apart and installed the itelite from maxxuav non-boosted. Once I got the bases out everything went smoothly with my ifixit tweezers, hemostats and magnetic screw bowl. I came into it prepared lol.
It took about 30 minutes start to finish (I had taken the tx apart twice before but stopped by the confounded bases those times.
After buttoning everything up I proceeded to have a seat on my front porch steps where I like to fly from across a small-town residential area towards downtown or from our back patio directly over a large wooded area (edge of town). I flew thir route yesterday evening and again this morning before the mod so I could judge what I had gained by the investment.
Flying the two directions over town I can get to about 2100-2200ft out (300ft alt) before I lose rc signal and video as well, and rth kicks in). The other direction directly over wooded non-populated path I can get to about 3300ft, same altituide.
I use channel 20 and 4mb setting on video.
My flight distance on both town flights today (same as yesterday non-itelite/maxxuav) were 2170ft and 2002ft and my wooded route was 3200ft. Altitude was 300ft for all. I've actually lost some distance or about the same. I know the antenna is working as I wouldn't be flying if it was not.
Comments, thoughts? I tried to keep the routes and altitude the same and same times as yesterday. I don't mean this to be a 'bash' post but rather I'm frustrated and disappointed.
i would like to buy those blue shorter cables. Any linky?
If you do as I did and try to use the factory antenna holes instead of drilling the top of the controller, you need the pass through adapters. The only problem is the wires that come with the DBS controller are straight, and they bend against the back of the antenna. These blue cables are 90 degrees at both ends and allow the wire to be free of interference
