I made this setup up on the cheap...It was Made to Beat my Stock P3P "P3PKiller ":)
It is a Highly modded Phantom 3 Standard I call this my P3Pkiller!!
Everything But the ArgTek can be bought for less than $100
Happy Flying everyone!! #BoostedP3S
Reactions: PapaTita
Holly S**t, that looks like some kind of weapon lol,
Would love you to post a quick post of the run down of what you have done, how you did it etc.
Darren
Ken ... can I ask why you need 5S on a setup that a 3S - 4S is indicated (the 5.8Ghz unit) ... The voltage input is stated as 12 - 15V as I see in the pictures.
What I find interesting is the seller does not restrict the antenna as I see on most to 7dbi ...
The 2.4Ghz is same unit as I have coming ... auto switching Tx / Rx on 2W ... and up to 5.5V
My plan is to have :
2.4G Extend Range Signal Booster Amplifier Device For DJI Phantom Vision FPV NEW | eBay
Mini 5.8G Signal Booster amp for DJI Phantom RC Quadcopters Flight Models HOT JS | eBay
Life 2S battery with 2.4 unit fed by Sbec and 5.8 unit direct. I also have plenty spare 3S LiPo's that are at end of life for high demand flight use that can be used without problem. I am hoping that I can slot the LiXX inside the RC case.
I have a 14dbi panel 5.8 antenna coming but I have been warned about its use with the 5.8 booster.
Will be interesting once I get all fitted out and see what difference I have to yours ... reasonably similar kit .... and of course with Argtec antenna setup.
Nigel
Reactions: KennethMcNutt
Nigel
Say what now ha ha lol
Life's for living !!
I'm sure Ken will update on all findings and results ... as I will ....
Nigel
This is the next step.. Birdside Mod!!
FPV Transmitter RF Signal Amplifier Booster for DJI Phantom Airplane Models WT | eBay
SMA Male Plug Center Straight to IPX U.FL Female Pigtail Jumper 1.13 Cable 20cm | eBay
Nigel[/QUOTE
The 5S battery... Well it was just that is was concerned about battery life.. It as Test there^^ was running 5V and 12V out from the BEC... Not knowing for sure what all Ah draw was.. I optioned for the cheapest highest Volt (5S) battery that would work, with My "Dual Output" Bec.. So I found that one.. "Short, not to fat, Cheap!" seemed to fit the bill.. The Bec was also overkill.. I did not now what I was going to end up with.. So a Mutli-Volt Dual output, Fit that bill.. It was all cheap.. But it was also designed as a test bed.. Plug and Play ;) Any antenna, any Amp, Any volt need was meet this way.. With the other 5.8 amp pictured.. (no fan) All amps are 5v then... So with a 4amp 5v bec any 2S battery would run them..
This is what She'll Do in the around the house.. Keep in mind there is hundreds of wifi sources below me.. I don't give up the first time ;)... But as you might be able to tell I have a RTH issue in both video's??? I had it fight to get it home?? :(
