- Joined
- Mar 8, 2016
- Messages
- 48
- Reaction score
- 12
- Age
- 29
the solder point for u2 is not more on main board. It got off. So I asked if u1 also works.I believe it has connect u2 see beshanoe post
Unfortunately no, when I tried to find proper pins I first connected to U1 point and got this rubbish stuff in terminal as well, then I tried u2 and the output became meaningful. I believe you still can try to connect to it somehowthe solder point for u2 is not more on main board. It got off. So I asked if u1 also works.
i found someone selling the module but is in china.If anybody has a spare wifi module, then send me a message
Do you have anything like an Arduino lying around?Hi
Can anyone post detail a step by step guide to unbricking the Drone & RC.
I hav done basically solder it to the WiFi board, but from that step..... i dono how.
All you help is needed. TQ.
i don hav, but my fren do hav. need an Arduino?Do you have anything like an Arduino lying around?
You can use it as a USB UART TTL.i don hav, but my fren do hav. need an Arduino?
i hav the USB UART TTL . but whats the program to run it? & steps?You can use it as a USB UART TTL.
i think you use wrong tty speedthe solder point u2_rx torred off. it is not more on platine. I do not know how. Can I use instead U2 solder points the U1 solder points on upper left corner? When I use the u1 solder points PUTTY can read something but the characters are weird/strange, so i can not read. Look at the picture, that shows the terminal. It is an example. But the same appears to me when I connect to U1 solder points.
Im using mac. Whats the program to use? Driver? I hav windows system also.i hav the USB UART TTL . but whats the program to run it? & steps?
I've also got the same issue - anyone managed to find an alternative yet? Using the U1 points would be great!
Already on it, I'll let you know how it goes ;-)I can only suggest using a multi meter for continuity to find where u2 goto and connect a wire to other location
