I bricked my p3s with ftp range mod - let's fix it together
Just copy rcS files from etc/initd to tmp/etc/initd
Just in case people here are linux newbies...
Code:
cd /tmp/flash/ && rm -rf ./etc/init.d/rcS && cp -r /etc/init.d/rcS ./etc/init.d/ && chmod +x ./etc/init.d/rcS
Help or suggestion? Connected the Usb to Uart turn to RX to tx0, TX to Rx0 and gnd to gnd to the remote. Set the baud rate 15200. Started putty and when and press Esc, I get a lot rubbish?
What voltage is your UART? 5v or 3.3v?
I've tried an old window xp machine I get the same problem, won't allow Esc.
I see light flash on Uart when a key is pressed...
Sounds to me like a dodgy solder connection, triple check your tx cable is attached to the board!
Here stupid question the daughter board needs connected to main? No other wires are needed ie 3.3/5 volts required from Uart?
If by that, you mean "does the gimbal need to be connected to the quad", then yes. And no, no voltages are required from the UART.
Which UART TTL adapter have you got? I'll have a look at the data sheet for it and get back to you!
I can't seem to Esc in to login screen? I get the following; see image ?
1. open your putty window,
means choose com port and speed press ok (uart has to be disconnected)
2. Conect your Uart(already soldered to a drone, or remote) to the USB
3. 'switch on' remote controller or a Drone
4. immediately press escape.
5. Fallow the instruction (1st post)
(cp2102 will work rx, tx, gnd, just them three need to be connected)
I have tried this except for step 1, as the uart connected to the USB and RC, then I start putty. I move onto the drone and see if I get better success.
Help! Have missed something r doing something wrong?
I have followed the following steps:
Press ESC to abort autoboot in 1 seconds
ar7240> setenv bootargs board=DJI-WM305 console=ttyS0,115200 root=/dev/mtdblock5 init=/sbin/init mtdparts=ath-nor0:256k@0k(u-boot),64k@256k(u-boot-env),896k@320k(kernel1),3008k@1216k(rootfs1),896k@4224k(kernel2),3008k@5120k(rootfs2),64k@8128k(art),3904k@320k(firmware1),3904k@4224k(firmware2),8192k@0k(all)
And then
ar7240> bootm 0x9f420000
This will allow you to boot backup copy of system. After that you'll be able to mount main root filesystem:
mkdir /tmp/flash (pic1)
And then mount it:
mount -t jffs2 mtd3 /tmp/flash (pic2)
/tmp/flash/etc/init.d (pic3)
I enclosed 3 screen shots and the last FileZilla.
I then proceeded to connected to RC to via FileZilla
But I can't find to file to repair "RCS" (pic4)
If the RCs file missing can someone post a copy?
I enclosed putty logs:
MI124
DRAM: 32 MB
Flash: 8 MB
In: serial
Out: serial
Err: serial
ar7240> setenv bootargs board=DJI-WM305 console=ttyS0,115200 root=/dev/mtdblock5 init=/sbin/init mtdparts=ath-nor0:256k@0k(u-boot),64k@256k(u-boot-env),896k@320k(kernel1),3008k@1216k(rootfs1),896k@4224k(kernel2),3008k@5120k(rootfs2),64k@8128k(art),3904k@320k(firmware1),3904k@4224k(firmware2),8192k@0k(all) s[C[Dsetenv bootargs board=DJI-WM305 console=ttyS0,115200 root=/dev/mtdblock5 init=/sbin/init mtdparts=ath-nor0:256k@0k(u-boot),64k@256k(u-boot-env),896k@320k(kernel1),3008k@1216k(rootfs1),896k@4224k(kernel2),3008k@5120k(rootfs2),64k@8128k(art),3904k@320k(firmware1),3904k@4224k(firmware2),8192k@0k(all)
Unknown command '' - try 'help'
## Booting image at 9f420000 ...
Image Name: MIPS OpenWrt Linux-3.10.49
Created: 2015-08-20 3:19:32 UTC
Image Type: MIPS Linux Kernel Image (lzma compressed)
Data Size: 905294 Bytes = 884.1 kB
Load Address: 80060000
Entry Point: 80060000
Verifying Checksum at 0x9f420040 ...OK
Uncompressing Kernel Image ... OK
Starting kernel ...
[ 0.000000] Linux version 3.10.49 (yello@ubuntu) (gcc version 4.8.3 (OpenWrt/Linaro GCC 4.8-2014.04 r2635) ) #14 Thu Aug 20 11:19:19 CST 2015
[ 0.000000] bootconsole [early0] enabled
[ 0.000000] CPU revision is: 0001974c (MIPS 74Kc)
[ 0.000000] SoC: Atheros AR9342 rev 2
[ 0.000000] Clocks: CPU:560.000MHz, DDR:450.000MHz, AHB:225.000MHz, Ref:40.000MHz
[ 0.000000] Determined physical RAM map:
[ 0.000000] memory: 02000000 @ 00000000 (usable)
[ 0.000000] User-defined physical RAM map:
[ 0.000000] Initrd not found or empty - disabling initrd
[ 0.000000] Zone ranges:
[ 0.000000] Normal [mem 0x00000000-0x01ffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x00000000-0x01ffffff]
[ 0.000000] Primary instruction cache 64kB, VIPT, 4-way, linesize 32 bytes.
[ 0.000000] Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 32 bytes
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 8128
[ 0.000000] Kernel command line: board=DJI-WM305 console=ttyS0,115200 root=/dev/mtdblock5 init=/sbin/init mtdparts=ath-nor0:256k@0k(u-boot),64k@256k(u-boot-env),896k@320k(kernel1),3008k@1216k(rootfs1),896k@4224k(kernel2),3008k@5120k(rootfs2),64k@8128k(art),3904k@320k(firmware1),3904k@4224k(firmware2),8192k@0k(all) mem=32M rootfstype=squashfs,jffs2 noinitrd
[ 0.000000] PID hash table entries: 128 (order: -3, 512 bytes)
[ 0.000000] Dentry cache hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Inode-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Writing ErrCtl register=00000000
[ 0.000000] Readback ErrCtl register=00000000
[ 0.000000] Memory: 29180k/32768k available (2102k kernel code, 3588k reserved, 363k data, 220k init, 0k highmem)
[ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] NR_IRQS:51
[ 0.000000] Calibrating delay loop... 278.93 BogoMIPS (lpj=1394688)
[ 0.070000] pid_max: default: 32768 minimum: 301
[ 0.070000] Mount-cache hash table entries: 512
[ 0.080000] NET: Registered protocol family 16
[ 0.080000] MIPS: machine is DJI WM305
[ 0.290000] ath_usb_init: id: 1122
[ 0.360000] bio: create slab <bio-0> at 0
[ 0.360000] Switching to clocksource MIPS
[ 0.370000] NET: Registered protocol family 2
[ 0.370000] TCP established hash table entries: 512 (order: 0, 4096 bytes)
[ 0.380000] TCP bind hash table entries: 512 (order: -1, 2048 bytes)
[ 0.390000] TCP: Hash tables configured (established 512 bind 512)
[ 0.390000] TCP: reno registered
[ 0.390000] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.400000] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.410000] NET: Registered protocol family 1
[ 0.430000] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.430000] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[ 0.440000] msgmni has been set to 56
[ 0.450000] io scheduler noop registered
[ 0.450000] io scheduler deadline registered (default)
[ 0.460000] Serial: 8250/16550 driver, 1 ports, IRQ sharing disabled
[ 0.480000] serial8250.0: ttyS0 at MMIO 0x18020000 (irq = 11) is a 16550A
[ 0.490000] console [ttyS0] enabled, bootconsole disabled
[ 0.500000] ar934x-hs-uart.0: ttyATH0 at MMIO 0x18500000 (irq = 14) is a AR934X UART
[ 0.510000] ath79-spi ath79-spi: master is unqueued, this is deprecated
[ 0.520000] m25p80 spi0.0: found s25fl064k, expected m25p80
[ 0.530000] m25p80 spi0.0: s25fl064k (8192 Kbytes)
[ 0.530000] 10 cmdlinepart partitions found on MTD device ath-nor0
[ 0.540000] Creating 10 MTD partitions on "ath-nor0":
[ 0.540000] 0x000000000000-0x000000040000 : "u-boot"
[ 0.550000] 0x000000040000-0x000000050000 : "u-boot-env"
[ 0.560000] 0x000000050000-0x000000130000 : "kernel1"
[ 0.560000] 0x000000130000-0x000000420000 : "rootfs1"
[ 0.570000] 0x000000420000-0x000000500000 : "kernel2"
[ 0.580000] 0x000000500000-0x0000007f0000 : "rootfs2"
[ 0.580000] 0x0000007f0000-0x000000800000 : "art"
[ 0.590000] 0x000000050000-0x000000420000 : "firmware1"
[ 0.600000] 0x000000420000-0x0000007f0000 : "firmware2"
[ 0.600000] 0x000000000000-0x000000800000 : "all"
[ 0.610000] g_ether gadget: using random self ethernet address
[ 0.610000] g_ether gadget: using random host ethernet address
[ 0.620000] usb0: MAC 16:12:d2:3b:75:4e
[ 0.630000] usb0: HOST MAC ba:0b:2a:e6:26:a7
[ 0.630000] g_ether gadget: Ethernet Gadget, version: Memorial Day 2008
[ 0.640000] g_ether gadget: g_ether ready
[ 0.640000] TCP: cubic registered
[ 0.650000] NET: Registered protocol family 17
[ 0.650000] 8021q: 802.1Q VLAN Support v1.8
[ 1.440000] jffs2: notice: (1) jffs2_build_xattr_subsystem: complete building xattr subsystem, 0 of xdatum (0 unchecked, 0 orphan) and 0 of xref (0 dead, 0 orphan) found.
[ 1.460000] VFS: Mounted root (jffs2 filesystem) readonly on device 31:5.
[ 1.470000] Freeing unused kernel memory: 220K (802c9000 - 80300000)
init started: BusyBox v1.22.1 (2015-06-29 19:28:31 CST)
starting pid 219, tty '': '/etc/init.d/rcS'
[ 2.430000] Loading modules backported from Linux version master-2014-05-22-0-gf2032ea
[ 2.440000] Backport generated by backports.git backports-20140320-37-g5c33da0
[ 2.670000] cfg80211: Calling CRDA to update world regulatory domain
[ 2.700000] cfg80211: World regulatory domain updated:
[ 2.700000] cfg80211: DFS Master region: unset
[ 2.700000] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 2.710000] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 2.720000] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 2.730000] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 2.740000] cfg80211: (5170000 KHz - 5250000 KHz @ 160000 KHz), (N/A, 2000 mBm), (N/A)
[ 2.750000] cfg80211: (5250000 KHz - 5330000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 2.760000] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 2.760000] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 2.770000] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 3.580000] cfg80211: Calling CRDA for country: US
[ 3.600000] ieee80211 phy0: Atheros AR9340 Rev:0 mem=0xb8100000, irq=47
[ 3.630000] cfg80211: Regulatory domain changed to country: US
[ 3.630000] cfg80211: DFS Master region: FCC
[ 3.640000] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 3.650000] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 3000 mBm), (N/A)
[ 3.660000] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 1700 mBm), (N/A)
[ 3.670000] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2300 mBm), (0 s)
[ 3.670000] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 3000 mBm), (N/A)
[ 3.680000] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 4000 mBm), (N/A)
Thu Aug 20 03:19:55 UTC 2015
now in bacup partitions,no restore firmware2
[ 4.530000] cfg80211: Calling CRDA for country: GB
[ 4.550000] cfg80211: Regulatory domain changed to country: GB
[ 4.550000] cfg80211: DFS Master region: ETSI
[ 4.560000] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 4.570000] cfg80211: (2402000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 1700 mBm), (N/A)
[ 4.570000] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 4.580000] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2000 mBm), (0 s)
[ 4.590000] cfg80211: (5490000 KHz - 5710000 KHz @ 80000 KHz), (N/A, 2700 mBm), (0 s)
[ 4.600000] cfg80211: (57240000 KHz - 65880000 KHz @ 2160000 KHz), (N/A, 4000 mBm), (N/A)
## Error: "frq" not defined
sed -i "s/^hw_mode=.*/hw_mode=g/g" /var/run/hostapd-phy0.conf
## Error: "ht" not defined
best chn = 6
sed -i "s/^bssid=.*/bssid=60:60:1f:05:e0:38/g" /var/run/hostapd-phy0.conf
## Error: "ssid" not defined
Configuration file: /var/run/hostapd-phy0.conf
[ 7.260000] device wlan0 entered promiscuous mode
Using interface wlan0 with hwaddr 60:60:1f:05:e0:38 and ssid "PHANTOM3_05e038"
[ 7.620000] br-lan: port 1(wlan0) entered forwarding state
[ 7.630000] br-lan: port 1(wlan0) entered forwarding state
wlan0: interface state UNINITIALIZED->ENABLED
wlan0: AP-ENABLED
[ 7.680000] device usb0 entered promiscuous mode
brctl: bridge br-lan: Device or resource busy
starting pid 540, tty '/dev/ttyS0': '/bin/ash --login'
BusyBox v1.22.1 (2015-06-29 19:28:31 CST) built-in shell (ash)
Enter 'help' for a list of built-in commands.
root@dji:/# mkdir /tmp/flash
root@dji:/# mount -t jffs2 mtd3 /tmp/flash[ 22.640000] br-lan: port 1(wlan0) entered forwarding state
mount: mounting mtd3 on /tmp/flash/tmp/flash/etc/init.d failed: No such file or directory
[ 62.110000] jffs2: notice: (3184) jffs2_build_xattr_subsystem: complete building xattr subsystem, 0 of xdatum (0 unchecked, 0 orphan) and 0 of xref (0 dead, 0 orphan) found.
root@dji:/#
Help, I thought I had solution to fix, now I won't go past the following command:
bootm 0x9f420000
I think my RC stuck in a boot loop
How I got into this situation was viewing the files in vim, and then exit vim, then I used FileZilla to access the RC and using notepad++ to view file to make sure there was no corruption within the file as the RC was bricked at the time. Made no changes to file just exit notepad++ and discounted FileZilla. I am little stumped how I managed to get it into a boot loop!
see rcS: applet not found below?
U-Boot 1.1.4 (Mar 24 2016 - 12:37:01)
MI124
DRAM: 32 MB
Flash: 8 MB
In: serial
Out: serial
Err: serial
ar7240> setenv bootargs board=DJI-WM305 console=ttyS0,115200 root=/de¶©–c½[Õ init=/sbin/init mtdparts=ath-nor0:256k@0k(u-boot),64k@256k(u-boot-env),896k@320k(kernel1),3008k@1216k(rootfs1),896k@4224k(kernel2),3008k@5120k(rootfs2),64k@8128k(art),3904k@320k(firmware1),3904k@4224k(firmware2),8192k@0k(all)
ar7240>
ar7240>
Starting kernel ...
[ 0.620000] usb0: MAC 06:eb:10:2f:af:e0
[ 0.630000] usb0: HOST MAC fa:06:18:1a:10:4b
can't open /dev/ttyS0: No such file or directory
process '/bin/ash --login' (pid 220) exited. Scheduling for restart.
process '/bin/ash --login' (pid 221) exited. Scheduling for restart.
process '/bin/ash --login' (pid 222) exited. Scheduling for restart.
process '/bin/ash --login' (pid 223) exited. Scheduling for restart.
process '/bin/ash --login' (pid 224) exited. Scheduling for restart.
^C
process '/bin/ash --login' (pid 225) exited. Scheduling for restart.
any suggestion?
Russianman92
