- Joined
- Nov 27, 2016
- Messages
- 8
- Reaction score
- 2
- Age
- 34
My video link has become perfectly fine.But the 5.8Ghz signal is truly awful. cutting out even at 200m
It's simple :Some say that the mod will increase 5.8 range other say only 2.4 range will be increased. Best to try yourself
FCC 5.8 is the best configuration but wifi Channel 13 is not allowed contrary to BO... So papatita add the choice in Magic Power 5.3 to set 5.8ghz settings to FCC...And what is the difference between settings BO and US in Magic Power 5.3?
Sent from my HUAWEI P7-L10 using PhantomPilots mobile app
you know why my litchi doesn't connect now that i runned papatita's mod ?
i am in EU, distance has a great improvement with DJI go
So you have exactly FCC mod (choose US area)+ 2.4ghz Link boost...
Hi , so the ones that are in CE area with poor 5.8Ghz , and have installed already Magic Power 5.2,
we better to apply Magic Power 5.3 (straight away , without any revert?)
and select USA area + 2.4ghz Link boost at any wifi channel ?
Thanks,
Hi again, I applied Magic Power 5.3 directily (without revert) on top of Magic Power 5.2 . I applied just step 1 , chaning area CE to USA , and no problem at all. It really changes the area, confirmed by Telnet, changed from B0...-> FCC . But I still measured exactly the same peak RF output value on the 5.8 Ghz, (using in 2,4 Ghz wifi channel 10). But I need to confirm if there is any range difference due to any unknown modulation parameter optimization. I will report it later.
i can see 5.1v is no longer available on google drive, fw 1.5.7 can be modded with magic power 5.3v ? im already done 27 dbm in djiupdater 3.8. do i need revert back to ce before run step 1 in version 5.3 ? thank you.The regional comparison of US and BO, not much difference in distance, but in US region is more good in quality transmission of images.
P3S FW 1.7.9 with stock antenna + Windsurfer + Magic v5.3. Same day, same location. (Beauty of Toraja)
Yes, you can update with v5.3, no need to "revert back to ce"i can see 5.1v is no longer available on google drive, fw 1.5.7 can be modded with magic power 5.3v ? im already done 27 dbm in djiupdater 3.8. do i need revert back to ce before run step 1 in version 5.3 ? thank you.
As just 200 distance difference, I don't feel that there is improvement in the flying distance between BO and US.The regional comparison of US and BO, not much difference in distance, but in US region is more good in quality transmission of images.
Sent from my LG-F350K using PhantomPilots mobile app
