How to Update Tx-Power with Magic Power v5.0
Question about the auto channel option. After take off and fly several mintues. Will it change automaticly if got interference in the sky?
Thanks.
Not like that, with version 4.0 no need to raise too high because the boost to 27 dbm only run when needed
I got the meaning of Magic Power now. It looks awesome! Does any risk to brick the drone using this app?
Becasue i know there is no risk if mod rc only. :)
I saw you select a channel scan, this option is not all devices running properly ... but I know the solution and then you select reset wifi, that become a new problem.
Try this:
1. Turn on the RC (drone off)
2. Run my application, select the menu "Revert Back to CE", click STEP 1
3. When finish, restart RC
In this condition, whether wifi active again?
If yes, turn on the drone, it connected?
I did that process today, but my RC did not work well.
As you see it, still my RC and phone wasn't connected properly. Wifi symbol was missing on status bar. So, my phone didn't connect to wifi automatically. And it was disconnected sometimes.
Could you save my drone? ;(
iOS won't show wifi icon when you connected a non-internet device. You have sucess connected already.
If you still can't connect in app. You may try
1. reinstall DJI go app.
2. reset all network setting in iOS
Hope it can help. :)
No, only changed when start
Sent from my Redmi Note 2 using PhantomPilots mobile app
So this actually can explain why interference has a different effect for everyone right? I also thought that the channel will be changed during flight if there is much interference.
But it seems that if you take off from a low interference spot and head to a higher in theory the channel scanning is useless, do I get it correctly?
Sent from my Nexus 7 using PhantomPilots mobile app
yes
Hey Papatita, i tried the set chanel manually via telnet as you told me. I can set all chanel from 1 to 10 but 12 and 13 are not working led stay red on the RC. Do you have an idea why ?
This mod is patch CE to FCC already
Yes but Guchino want to know if a mod for the control exist.
Papatita mod only applu t the video transmission2.4 ghz
Guchino: in papatita app in donate their is another name :-) this person was workin on the 5.8 ghz mod but he decided to leave the forum after some stupid comments by some users.
So so far no mod available ..... No easy mod let say.
Reactions: Philltayl
Litchi app has option ch13 for transmission channel.
Is this same thing?
Also, bird RTH at 5.8ghz signal loss yes?
Guchino: in papatita app in donate their is another name :) this person was workin on the 5.8 ghz mod but he decided to leave the forum after some stupid comments by some users.
OK another person worked.
I checked Power by ImmersionRC Power meter.
2.4ghz 200mw each antenna side.
5.8ghz 10mw.
Is this OK?
hayato reply :This mod is patch CE to FCC already.
Anyway Seem to be due elsewhere, Power Module,,,?
DJI according your location to set CE or FCC mode
This patch is using a fake location force in FCC mode
You can see the first option is [Patch to FCC - RC only Recommend]
If you want to more extra power you need a 5.8g amplifier. :)
Thanks suggestion.
I ordered 5.8gh power amp.
Russianman92
