Not like that, with version 4.0 no need to raise too high because the boost to 27 dbm only run when needed
I saw you select a channel scan, this option is not all devices running properly ... but I know the solution and then you select reset wifi, that become a new problem.
Try this:
1. Turn on the RC (drone off)
2. Run my application, select the menu "Revert Back to CE", click STEP 1
3. When finish, restart RC
In this condition, whether wifi active again?
If yes, turn on the drone, it connected?
I did that process today, but my RC did not work well.
As you see it, still my RC and phone wasn't connected properly. Wifi symbol was missing on status bar. So, my phone didn't connect to wifi automatically. And it was disconnected sometimes.
Could you save my drone? ;(
No, only changed when startQuestion about the auto channel option. After take off and fly several mintues. Will it change automaticly if got interference in the sky?
Thanks.
Hi,Papatita,Thanks convenient patch file.
BTW, how to power up RC(5.8ghz) CE14dbm to FCC 19dbm.
This mod is patch CE to FCC already
OK another person worked.Yes but Guchino want to know if a mod for the control exist.
Papatita mod only applu t the video transmission2.4 ghz
Guchino: in papatita app in donate their is another name this person was workin on the 5.8 ghz mod but he decided to leave the forum after some stupid comments by some users.
So so far no mod available ..... No easy mod let say.
hayato reply :This mod is patch CE to FCC already.10mW in 5.8ghz is very poor power rate. This mod in only for 2.4ghz
Anyway Seem to be due elsewhere, Power Module,,,?
Thanks suggestion.DJI according your location to set CE or FCC mode
This patch is using a fake location force in FCC mode
You can see the first option is [Patch to FCC - RC only Recommend]
If you want to more extra power you need a 5.8g amplifier.
