Pretty sure I nailed it, but havn't tried the board in the controller yet.
This what I get now:
DM36x initialization passed!
UBL Product Vesion : DJI-GSP-UBL-1.0-rc10(2014-08-15)
Dji UBL Version: 1.51(Aug 15 2014 - 17:05:12)
Booting Catalog Boot Loader
BootMode = NAND
Starting NAND Copy...
Valid magicnum, 0xA1ACED66, found in block 0x00000019.
Uboot Checksum:0x7E25B44B
Actua Checksum:0x7E25B44B
U-Boot Product Vesion : DJI-GSP-Uboot-1.0-rc4(2014-07-23)
U-Boot 2010.12-rc2-svn-Dji (Jul 23 2014 - 11:14:40)
Cores: ARM 432 MHz
DDR: 297 MHz
I2C: ready
DRAM: 128 MiB
NAND: 128 MiB
Bad block table found at page 65472, version 0x01
Bad block table found at page 65408, version 0x01
*** Warning - bad CRC, using default environment
Net: Ethernet PHY: GENERIC @ 0xff
DaVinci-EMAC
Press ESC to abort autoboot in 1 seconds
Loading from nand0, offset 0x4a0000
Image Name: Linux-2.6.32.17-davinci1
Created: 2015-06-23 9:37:05 UTC
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 4065664 Bytes = 3.9 MiB
Load Address: 80008000
Entry Point: 80008000
## Booting kernel from Legacy Image at 80700000 ...
Loading Kernel Image ... OK
OK
Starting kernel ...
[ 0.000000] Kernel Product Vesion : DJI-GRC-Kernel-1.1-rc0(2015-06-23)
[ 0.000000] Linux version 2.6.32.17-davinci1 (root@dji) (gcc version 4.3.3 (Sourcery G++ Lite 2009q1-203) ) #6 PREEMPT Tue Jun 23 17:37:03 HKT 2015
[ 0.000000] CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053177
[ 0.000000] CPU: VIVT data cache, VIVT instruction cache
[ 0.000000] Machine: DaVinci DM36x EVM
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] DaVinci dm36x_rev1.2 variant 0x8
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping off. Total pages: 12192
[ 0.000000] Kernel command line: console=ttyS0,115200n8 rw dm365_imp.oper_mode=0 video=davincifb:vid0=0,10K:vid1=0,10K
sd0=1920x1080X16,8100K mem=48MB davinci_enc_mngr.ch0_output=COMPOSITE davinci_enc_mngr.ch0_mode=pal ubi.mtd=2,2048 root=ubi0:rootfs rootfstype=ubifs ip=off lpj=1077248
[ 0.000000] PID hash table entries: 256 (order: -2, 1024 bytes)
[ 0.000000] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.000000] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Memory: 48MB = 48MB total
[ 0.000000] Memory: 44424KB available (3672K code, 444K data, 116K init, 0K highmem)
[ 0.000000] SLUB: Genslabs=11, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] NR_IRQS:245
[ 0.000000] Console: colour dummy device 80x30
[ 0.000000] Calibrating delay loop (skipped) preset value.. 215.44 BogoMIPS (lpj=1077248)
[ 0.000000] Mount-cache hash table entries: 512
[ 0.000000] CPU: Testing write buffer coherency: ok
[ 0.000000] DaVinci: 8 gpio irqs
[ 0.000000] NET: Registered protocol family 16
[ 0.110000] bio: create slab <bio-0> at 0
[ 0.110000] DM365 IPIPE initialized in Continuous mode
[ 0.110000] SCSI subsystem initialized
[ 0.120000] usbcore: registered new interface driver usbfs
[ 0.120000] usbcore: registered new interface driver hub
[ 0.120000] usbcore: registered new device driver usb
[ 0.130000] vpss vpss: dm365_vpss vpss probed
[ 0.130000] vpss vpss: dm365_vpss vpss probe success
[ 0.130000] ch0 default output "COMPOSITE", mode "PAL"
[ 0.130000] pinmux1:0x00145555
[ 0.130000] VPBE Encoder Initialized
[ 0.130000] cfg80211: Using static regulatory domain info
[ 0.130000] cfg80211: Regulatory domain: US
[ 0.130000] (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 0.130000] (2402000 KHz - 2472000 KHz @ 40000 KHz), (600 mBi, 2700 mBm)
[ 0.130000] (5170000 KHz - 5190000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
[ 0.140000] (5190000 KHz - 5210000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
[ 0.140000] (5210000 KHz - 5230000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
[ 0.140000] (5230000 KHz - 5330000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
[ 0.140000] (5735000 KHz - 5835000 KHz @ 40000 KHz), (600 mBi, 3000 mBm)
[ 0.140000] cfg80211: Calling CRDA for country: US
[ 0.140000] Switching to clocksource timer0_1
[ 0.140000] musb_hdrc: version 6.0, pio, host, debug=0
[ 0.160000] musb_hdrc: USB Host mode controller at fec64000 using PIO, IRQ 12
[ 0.160000] musb_hdrc musb_hdrc: MUSB HDRC host driver
[ 0.160000] musb_hdrc musb_hdrc: new USB bus registered, assigned bus number 1
[ 0.160000] usb usb1: configuration #1 chosen from 1 choice
[ 0.160000] hub 1-0:1.0: USB hub found
[ 0.160000] hub 1-0:1.0: 1 port detected
[ 0.160000] NET: Registered protocol family 2
[ 0.160000] IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.160000] TCP established hash table entries: 2048 (order: 2, 16384 bytes)
[ 0.160000] TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.160000] TCP: Hash tables configured (established 2048 bind 2048)
[ 0.160000] TCP reno registered
[ 0.160000] NET: Registered protocol family 1
[ 0.160000] RPC: Registered udp transport module.
[ 0.160000] RPC: Registered tcp transport module.
[ 0.160000] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.170000] kfile init
[ 0.170000] JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[ 0.170000] msgmni has been set to 86
[ 0.180000] alg: No test for stdrng (krng)
[ 0.180000] io scheduler noop registered (default)
[ 0.210000] davincifb davincifb.0: dm_osd0_fb: Initial window configuration is invalid.
[ 0.220000] davincifb davincifb.0: dm_osd0_fb: 1920x1080x16@0,0 with framebuffer size 8100KB
[ 0.220000] davincifb davincifb.0: dm_vid0_fb: 0x0x16@0,0 with framebuffer size 10KB
[ 0.230000] davincifb davincifb.0: dm_osd1_fb: Initial window configuration is invalid.
[ 0.240000] davincifb davincifb.0: dm_osd1_fb: 1920x1080x4@0,0 with framebuffer size 4050KB
[ 0.240000] davincifb davincifb.0: dm_vid1_fb: 0x0x16@0,0 with framebuffer size 10KB
[ 0.300000] venc off init
[ 0.300000] hdmi status init
[ 0.300000] DM365 IPIPEIF probed
[ 0.310000] imp serializer initialized
[ 0.310000] davinci_previewer initialized
[ 0.310000] davinci_resizer initialized
[ 0.310000] Serial: 8250/16550 driver, 2 ports, IRQ sharing disabled
[ 0.310000] serial8250.0: ttyS0 at MMIO 0x1c20000 (irq = 40) is a 16550A
[ 0.780000] console [ttyS0] enabled
[ 0.780000] serial8250.0: ttyS1 at MMIO 0x1d06000 (irq = 41) is a 16550A
[ 0.790000] brd: module loaded
[ 0.800000] NAND device: Manufacturer ID: 0x2c, Chip ID: 0xf1 (Micron NAND 128MiB 3,3V 8-bit)
[ 0.810000] Creating 4 MTD partitions on "davinci_nand.0":
[ 0.820000] 0x000000000000-0x0000004a0000 : "bootloader"
[ 0.830000] 0x0000004a0000-0x000000e00000 : "kernel"
[ 0.830000] 0x000000e00000-0x000007f00000 : "filesystem"
[ 0.840000] 0x000000000000-0x000008000000 : "all"
[ 0.850000] davinci_nand davinci_nand.0: controller rev. 2.3
[ 0.860000] UBI: attaching mtd2 to ubi0
[ 0.860000] UBI: physical eraseblock size: 131072 bytes (128 KiB)
[ 0.870000] UBI: logical eraseblock size: 126976 bytes
[ 0.880000] UBI: smallest flash I/O unit: 2048
[ 0.880000] UBI: sub-page size: 512
[ 0.890000] UBI: VID header offset: 2048 (aligned 2048)
[ 0.890000] UBI: data offset: 4096
[ 1.060000] usb 1-1: new high speed USB device using musb_hdrc and address 2
[ 1.210000] usb 1-1: configuration #1 chosen from 1 choice
[ 1.210000] hub 1-1:1.0: USB hub found
[ 1.230000] hub 1-1:1.0: 2 ports detected
[ 1.410000] UBI: attached mtd2 to ubi0
[ 1.410000] UBI: MTD device name: "filesystem"
[ 1.420000] UBI: MTD device size: 113 MiB
[ 1.420000] UBI: number of good PEBs: 904
[ 1.430000] UBI: number of bad PEBs: 0
[ 1.430000] UBI: max. allowed volumes: 128
[ 1.430000] UBI: wear-leveling threshold: 4096
[ 1.440000] UBI: number of internal volumes: 1
[ 1.440000] UBI: number of user volumes: 1
[ 1.450000] UBI: available PEBs: 0
[ 1.450000] UBI: total number of reserved PEBs: 904
[ 1.460000] UBI: number of PEBs reserved for bad PEB handling: 9
[ 1.460000] UBI: max/mean erase counter: 115/1
[ 1.470000] UBI: image sequence number: 268688541
[ 1.470000] UBI: background thread "ubi_bgt0d" started, PID 342
[ 1.480000] console [netcon0] enabled
[ 1.490000] netconsole: network logging started
[ 1.490000] Initializing USB Mass Storage driver...
[ 1.500000] usbcore: registered new interface driver usb-storage
[ 1.500000] USB Mass Storage support registered.
[ 1.510000] usbcore: registered new interface driver usbtest
[ 1.510000] i2c /dev entries driver
[ 1.520000] Linux video capture interface: v2.00
[ 1.530000] vpfe-capture: vpss clock vpss_master enabled
[ 1.540000] vpfe-capture vpfe-capture: v4l2 device registered
[ 1.540000] vpfe-capture vpfe-capture: video device registered
[ 1.550000] No sub devices registered
[ 1.560000] Trying to register davinci display video device.
[ 1.560000] layer=c17f7000,layer->video_dev=c17f7164
[ 1.570000] Trying to register davinci display video device.
[ 1.570000] layer=c17f7400,layer->video_dev=c17f7564
[ 1.580000] davinci_init
aVinci V4L2 Display Driver V1.0 loaded
[ 1.590000] watchdog watchdog: heartbeat 1 sec
[ 1.590000] usbcore: registered new interface driver usbmouse
[ 1.600000] usbmouse: v1.6:USB HID Boot Protocol mouse driver
[ 1.600000] TCP cubic registered
[ 1.610000] NET: Registered protocol family 17
[ 1.610000] lib80211: common routines for IEEE802.11 drivers
[ 1.620000] ksocket init
[ 1.640000] encrypt device:atsha204 found
[ 1.740000] mfi_i2c_client addr:17
[ 1.740000] Clocks: disable unused mmcsd0
[ 1.740000] Clocks: disable unused mmcsd1
[ 1.740000] Clocks: disable unused spi0
[ 1.740000] Clocks: disable unused spi1
[ 1.740000] Clocks: disable unused spi2
[ 1.740000] Clocks: disable unused spi3
[ 1.740000] Clocks: disable unused spi4
[ 1.740000] Clocks: disable unused pwm0
[ 1.740000] Clocks: disable unused pwm1
[ 1.740000] Clocks: disable unused pwm2
[ 1.740000] Clocks: disable unused pwm3
[ 1.740000] Clocks: disable unused timer1
[ 1.740000] Clocks: disable unused timer3
[ 1.740000] Clocks: disable unused emac
[ 1.740000] Clocks: disable unused voice_codec
[ 1.740000] Clocks: disable unused asp0
[ 1.740000] Clocks: disable unused rto
[ 1.740000] Clocks: disable unused mjcp
[ 1.820000] davinci_emac_probe: using random MAC addr: 9a:41:11:0a:e0:4d
[ 1.830000] emac-mii: probed
[ 1.870000] UBIFS: recovery needed
[ 1.950000] UBIFS: recovery completed
[ 1.950000] UBIFS: mounted UBI device 0, volume 0, name "rootfs"
[ 1.960000] UBIFS: file system size: 110342144 bytes (107756 KiB, 105 MiB, 869 LEBs)
[ 1.960000] UBIFS: journal size: 9023488 bytes (8812 KiB, 8 MiB, 72 LEBs)
[ 1.970000] UBIFS: media format: w4/r0 (latest is w4/r0)
[ 1.980000] UBIFS: default compressor: lzo
[ 1.980000] UBIFS: reserved for root: 0 bytes (0 KiB)
[ 1.990000] VFS: Mounted root (ubifs filesystem) on device 0:13.
[ 1.990000] Freeing init memory: 116K
Filesystem Product Vesion : DJI-Filesystem-1.0-rc2
Runing /etc/init.d/rcS
[ 3.790000] CMEMK module: built on Jul 30 2014 at 10:21:45
[ 3.790000] Reference Linux version 2.6.32
[ 3.800000] File /home/u/work/svn/dec_grc/src/dvsdk/dvsdk_dm368_4_02_00_06/linuxutils_2_26_01_02/packages/ti/sdo/linuxutils/cmem/src/module/cmemk.c
[ 3.840000] allocated heap buffer 0xc7000000 of size 0x4400000
[ 3.840000] heap fallback enabled - will try heap if pool buffer is not available
[ 3.850000] CMEM Range Overlaps Kernel Physical - allowing overlap
[ 3.860000] CMEM phys_start (0x1000) overlaps kernel (0x80000000 -> 0x83000000)
[ 3.860000] cmemk initialized
[ 3.890000] IRQK module: built on Jul 30 2014 at 10:21:09
[ 3.910000] Reference Linux version 2.6.32
[ 3.910000] File /home/u/work/svn/dec_grc/src/dvsdk/dvsdk_dm368_4_02_00_06/linuxutils_2_26_01_02/packages/ti/sdo/linuxutils/irq/src/module/irqk.c
[ 3.930000] irqk initialized
[ 3.980000] EDMAK module: built on Jul 30 2014 at 10:19:34
[ 4.000000] Reference Linux version 2.6.32
[ 4.000000] File /home/u/work/svn/dec_grc/src/dvsdk/dvsdk_dm368_4_02_00_06/linuxutils_2_26_01_02/packages/ti/sdo/linuxutils/edma/src/module/edmak.c
[ 4.230000] exFAT: Version 1.2.9
settime failed
* daemon not running. starting it now on port 5037 *
* daemon started successfully *
[ 11.850000] usbcore: registered new interface driver usb_applehid
[ 11.870000] usb applehid module init ok
[ 11.910000] usbcore: registered new interface driver usb_68013
[ 11.940000] usb 68013 module init ok
sulogin: no password entry for root
login[494]: root login on 'ttyS0'
#Process /etc/profile...
root@Dji-Pro:~# encrypt check ok
init libusb successed!!!
usbmuxd disabled
usbsocket_init OK
usbsocket_create_handle ok, port:22345, bCanRecv:1
usbsocket_create_handle ok, port:22346, bCanRecv:0
watchdog timeout:5
DummyRead68013 0.000000kb
umount: can't umount /mnt/usb: No such file or directory
rmdir: '/mnt/usb': No such file or directory
encrypt chip exist
