GL300A Remote Controller help
Any luck with your USB board loonie?
Would you believe it, mine has totally died. I flashed it and everything worked perfect on the desk, and then when I put it back it didn't work. Then I pulled it out, and its dead. No output in the terminal program whatever I do.
Its using more than 1 amp from the power supply so something is not right with it. But then again, it was acting strange before I flashed it. It took some fiddling to get it in boot mode, and some fiddling to get it out of bootmode again, so it might have been sick from the start..
I did fix my gimbal board though :-)
You don't need any knowledge of Linux to write the commands needed. Its all here: Flashing firmware on DaVinci media processors · mefistotelis/phantom-firmware-tools Wiki · GitHub
Put the kernel file on a USB stick and plug it in the USB port of the board.
Stop the bootprocess by pressing ESC within 1 sec after powering up the board.
These are the commands you need to type into your terminal program.
See the link for more info. Also make sure your kernel really needs to be flashed.
Code:
Dji-Pro # mw.b 0x80008000 0xFF 0x460000
Dji-Pro # usb start
Dji-Pro # usb storage
Dji-Pro # fatload usb 0 0x80008000 uImage
Dji-Pro # nand erase 0x04a0000 0x460000
Dji-Pro # nand write 0x80008000 0x04a0000 0x460000
I'm using putty. Board has to powered on for putty to read the board. I think i'm getting confused on when and where to press ESC to stop the boot process.
Hmm. You need to send an ESC key to the board within 1 sec after powering it up. Maybe thats impossible when you power the board with 5V from the TTL adaptor. Im powering up the board with an external powersupply, so my terminal program is ready when the board gets power. Maybe you can use 3 AA batteries in serial to power the board.
What I end up doing is splicing my 5v connection. I've got it to the point it will read the kernel. I just cannot hit ESC in time.
Port opened at 12/12/2017 02:24:43 AM
DM36x initialization passed!
UBL Product Vesion : DJI-GSP-UBL-1.0-rc10(2014-08-15)
Dji UBL Version: 1.51(Aug 15 2014 - 17:05:12)
Booting Catalog Boot Loader
BootMode = NAND
Starting NAND Copy...
Valid magicnum, 0xA1ACED66, found in block 0x00000019.
Uboot Checksum:0x7E25B44B
Actua Checksum:0x7E25B44B
U-Boot Product Vesion : DJI-GSP-Uboot-1.0-rc4(2014-07-23)
U-Boot 2010.12-rc2-svn-Dji (Jul 23 2014 - 11:14:40)
Cores: ARM 432 MHz
DDR: 297 MHz
I2C: ready
DRAM: 128 MiB
NAND: 128 MiB
Bad block table found at page 65472, version 0x01
Bad block table found at page 65408, version 0x01
*** Warning - bad CRC, using default environment
Net: Ethernet PHY: GENERIC @ 0xff
DaVinci-EMAC
Press ESC to abort autoboot in 1 seconds
Loading from nand0, offset 0x4a0000
** Unknown image type
Wrong Image Format for bootm command
ERROR: can't get kernel image!
Loading from nand0, offset 0x900000
Image Name: Linux-2.6.32.17-davinci1
Created: 2015-02-12 3:09:59 UTC
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 3665856 Bytes = 3.5 MiB
Load Address: 80008000
Entry Point: 80008000
## Booting kernel from Legacy Image at 80700000 ...
Loading Kernel Image ... OK
OK
Starting kernel ...
[ 0.000000] Kernel Product Vesion : DJI-GRC-Kernel-1.0-rc8(2014-11-21)
[ 0.000000] Linux version 2.6.32.17-davinci1 (u@dji) (gcc version 4.3.3 (Sourcery G++ Lite 2009q1-203) ) #1 PREEMPT Thu Feb 12 11:09:57 HKT 2015
[ 0.000000] CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053177
[ 0.000000] CPU: VIVT data cache, VIVT instruction cache
[ 0.000000] Machine: DaVinci DM36x EVM
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] DaVinci dm36x_rev1.2 variant 0x8
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping off. Total pages: 12192
[ 0.000000] Kernel command line: console=ttyS0,115200n8 rw dm365_imp.oper_mode=0 video=davincifb:vid0=0,10K:vid1=0,10K:osd0=1920x1080X16,8100K mem=48MB davinci_enc_mngr.ch0_output=COMPOSITE davinci_enc_mngr.ch0_mode=pal ubi.mtd=2,2048 root=ubi0:rootfs rootfstype=ubifs ip=off lpj=1077248
[ 0.000000] PID hash table entries: 256 (order: -2, 1024 bytes)
[ 0.000000] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.000000] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Memory: 48MB = 48MB total
[ 0.000000] Memory: 44836KB available (3304K code, 409K data, 108K init, 0K highmem)
[ 0.000000] SLUB: Genslabs=11, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] NR_IRQS:245
[ 0.000000] Console: colour dummy device 80x30
[ 0.000000] Calibrating delay loop (skipped) preset value.. 215.44 BogoMIPS (lpj=1077248)
[ 0.000000] Mount-cache hash table entries: 512
[ 0.000000] CPU: Testing write buffer coherency: ok
[ 0.000000] DaVinci: 8 gpio irqs
[ 0.000000] NET: Registered protocol family 16
[ 0.080000] bio: create slab <bio-0> at 0
[ 0.080000] SCSI subsystem initialized
[ 0.090000] usbcore: registered new interface driver usbfs
[ 0.090000] usbcore: registered new interface driver hub
[ 0.090000] usbcore: registered new device driver usb
[ 0.100000] cfg80211: Using static regulatory domain info
[ 0.100000] cfg80211: Regulatory domain: US
[ 0.100000] (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 0.100000] (2402000 KHz - 2472000 KHz @ 40000 KHz), (600 mBi, 2700 mBm)
[ 0.100000] (5170000 KHz - 5190000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
[ 0.100000] (5190000 KHz - 5210000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
[ 0.100000] (5210000 KHz - 5230000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
[ 0.100000] (5230000 KHz - 5330000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
[ 0.100000] (5735000 KHz - 5835000 KHz @ 40000 KHz), (600 mBi, 3000 mBm)
[ 0.100000] cfg80211: Calling CRDA for country: US
[ 0.100000] Switching to clocksource timer0_1
[ 0.110000] musb_hdrc: version 6.0, pio, host, debug=0
[ 0.130000] musb_hdrc: USB Host mode controller at fec64000 using PIO, IRQ 12
[ 0.130000] musb_hdrc musb_hdrc: MUSB HDRC host driver
[ 0.130000] musb_hdrc musb_hdrc: new USB bus registered, assigned bus number 1
[ 0.130000] usb usb1: configuration #1 chosen from 1 choice
[ 0.130000] hub 1-0:1.0: USB hub found
[ 0.130000] hub 1-0:1.0: 1 port detected
[ 0.130000] NET: Registered protocol family 2
[ 0.130000] IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.130000] TCP established hash table entries: 2048 (order: 2, 16384 bytes)
[ 0.130000] TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.130000] TCP: Hash tables configured (established 2048 bind 2048)
[ 0.130000] TCP reno registered
[ 0.130000] NET: Registered protocol family 1
[ 0.130000] RPC: Registered udp transport module.
[ 0.130000] RPC: Registered tcp transport module.
[ 0.130000] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.140000] kfile init
[ 0.140000] JFFS2 version 2.2. (NAND) ?? 2001-2006 Red Hat, Inc.
[ 0.140000] msgmni has been set to 87
[ 0.150000] alg: No test for stdrng (krng)
[ 0.150000] io scheduler noop registered (default)
[ 0.210000] Serial: 8250/16550 driver, 2 ports, IRQ sharing disabled
[ 0.210000] serial8250.0: ttyS0 at MMIO 0x1c20000 (irq = 40) is a 16550A
[ 0.580000] console [ttyS0] enabled
[ 0.590000] serial8250.0: ttyS1 at MMIO 0x1d06000 (irq = 41) is a 16550A
[ 0.600000] brd: module loaded
[ 0.610000] NAND device: Manufacturer ID: 0x2c, Chip ID: 0xf1 (Micron NAND 128MiB 3,3V 8-bit)
[ 0.620000] Creating 4 MTD partitions on "davinci_nand.0":
[ 0.620000] 0x000000000000-0x0000004a0000 : "bootloader"
[ 0.630000] 0x0000004a0000-0x000000e00000 : "kernel"
[ 0.640000] 0x000000e00000-0x000007f00000 : "filesystem"
[ 0.650000] 0x000000000000-0x000008000000 : "all"
[ 0.660000] davinci_nand davinci_nand.0: controller rev. 2.3
[ 0.670000] UBI: attaching mtd2 to ubi0
[ 0.670000] UBI: physical eraseblock size: 131072 bytes (128 KiB)
[ 0.680000] UBI: logical eraseblock size: 126976 bytes
[ 0.680000] UBI: smallest flash I/O unit: 2048
[ 0.690000] UBI: sub-page size: 512
[ 0.690000] UBI: VID header offset: 2048 (aligned 2048)
[ 0.700000] UBI: data offset: 4096
[ 0.820000] usb 1-1: new high speed USB device using musb_hdrc and address 2
[ 0.970000] usb 1-1: configuration #1 chosen from 1 choice
[ 0.970000] hub 1-1:1.0: USB hub found
[ 0.990000] hub 1-1:1.0: 2 ports detected
[ 1.210000] UBI: attached mtd2 to ubi0
[ 1.210000] UBI: MTD device name: "filesystem"
[ 1.220000] UBI: MTD device size: 113 MiB
[ 1.230000] UBI: number of good PEBs: 904
[ 1.230000] UBI: number of bad PEBs: 0
[ 1.230000] UBI: max. allowed volumes: 128
[ 1.240000] UBI: wear-leveling threshold: 4096
[ 1.240000] UBI: number of internal volumes: 1
[ 1.250000] UBI: number of user volumes: 1
[ 1.250000] UBI: available PEBs: 0
[ 1.260000] UBI: total number of reserved PEBs: 904
[ 1.260000] UBI: number of PEBs reserved for bad PEB handling: 9
[ 1.270000] UBI: max/mean erase counter: 56/1
[ 1.270000] UBI: image sequence number: 85601955
[ 1.280000] UBI: background thread "ubi_bgt0d" started, PID 272
[ 1.290000] console [netcon0] enabled
[ 1.290000] netconsole: network logging started
[ 1.290000] Initializing USB Mass Storage driver...
[ 1.300000] usbcore: registered new interface driver usb-storage
[ 1.310000] USB Mass Storage support registered.
[ 1.310000] usbcore: registered new interface driver usbtest
[ 1.320000] i2c /dev entries driver
[ 1.320000] watchdog watchdog: heartbeat 1 sec
[ 1.330000] TCP cubic registered
[ 1.330000] NET: Registered protocol family 17
[ 1.340000] lib80211: common routines for IEEE802.11 drivers
[ 1.340000] ksocket init
[ 1.370000] encrypt device:atsha204 found
[ 1.460000] mfi_i2c_client addr:17
[ 1.470000] Clocks: disable unused vpss_master
[ 1.470000] Clocks: disable unused mmcsd0
[ 1.470000] Clocks: disable unused mmcsd1
[ 1.470000] Clocks: disable unused spi0
[ 1.470000] Clocks: disable unused spi1
[ 1.470000] Clocks: disable unused spi2
[ 1.470000] Clocks: disable unused spi3
[ 1.470000] Clocks: disable unused spi4
[ 1.470000] Clocks: disable unused pwm0
[ 1.470000] Clocks: disable unused pwm1
[ 1.470000] Clocks: disable unused pwm2
[ 1.470000] Clocks: disable unused pwm3
[ 1.470000] Clocks: disable unused timer1
[ 1.470000] Clocks: disable unused timer3
[ 1.470000] Clocks: disable unused emac
[ 1.470000] Clocks: disable unused voice_codec
[ 1.470000] Clocks: disable unused asp0
[ 1.470000] Clocks: disable unused rto
[ 1.470000] Clocks: disable unused mjcp
[ 1.550000] davinci_emac_probe: using random MAC addr: ae:89:fc:99:f3:cc
[ 1.560000] emac-mii: probed
[ 1.600000] UBIFS: recovery needed
[ 1.650000] UBIFS: recovery completed
[ 1.650000] UBIFS: mounted UBI device 0, volume 0, name "rootfs"
[ 1.660000] UBIFS: file system size: 110342144 bytes (107756 KiB, 105 MiB, 869 LEBs)
[ 1.670000] UBIFS: journal size: 9023488 bytes (8812 KiB, 8 MiB, 72 LEBs)
[ 1.670000] UBIFS: media format: w4/r0 (latest is w4/r0)
[ 1.680000] UBIFS: default compressor: lzo
[ 1.680000] UBIFS: reserved for root: 0 bytes (0 KiB)
[ 1.690000] VFS: Mounted root (ubifs filesystem) on device 0:13.
[ 1.700000] Freeing init memory: 108K
Filesystem Product Vesion : DJI-Filesystem-1.0-rc2
Runing /etc/init.d/rcS
[ 3.440000] CMEMK module: built on Jul 30 2014 at 10:21:45
[ 3.440000] Reference Linux version 2.6.32
[ 3.460000] File /home/u/work/svn/dec_grc/src/dvsdk/dvsdk_dm368_4_02_00_06/linuxutils_2_26_01_02/packages/ti/sdo/linuxutils/cmem/src/module/cmemk.c
[ 3.480000] allocated heap buffer 0xc7000000 of size 0x4400000
[ 3.500000] heap fallback enabled - will try heap if pool buffer is not available
[ 3.520000] CMEM Range Overlaps Kernel Physical - allowing overlap
[ 3.520000] CMEM phys_start (0x1000) overlaps kernel (0x80000000 -> 0x83000000)
[ 3.530000] cmemk initialized
[ 3.560000] IRQK module: built on Jul 30 2014 at 10:21:09
[ 3.560000] Reference Linux version 2.6.32
[ 3.580000] File /home/u/work/svn/dec_grc/src/dvsdk/dvsdk_dm368_4_02_00_06/linuxutils_2_26_01_02/packages/ti/sdo/linuxutils/irq/src/module/irqk.c
[ 3.600000] irqk initialized
[ 3.650000] EDMAK module: built on Jul 30 2014 at 10:19:34
[ 3.650000] Reference Linux version 2.6.32
[ 3.670000] File /home/u/work/svn/dec_grc/src/dvsdk/dvsdk_dm368_4_02_00_06/linuxutils_2_26_01_02/packages/ti/sdo/linuxutils/edma/src/module/edmak.c
[ 3.890000] exFAT: Version 1.2.9
settime failed
* daemon not running. starting it now on port 5037 *
* daemon started successfully *
[ 11.490000] usbcore: registered new interface driver usb_applehid
[ 11.520000] usb applehid module init ok
[ 11.570000] usbcore: registered new interface driver usb_68013
[ 11.600000] usb 68013 module init ok
sulogin: no password entry for root
login[407]: root login on 'ttyS0' #Process /etc/profile...
root@Dji-Pro:~# encrypt check ok
init libusb successed!!!
usbmuxd disabled
usbsocket_init OK
usbsocket_create_handle ok, port:22345, bCanRecv:1
usbsocket_create_handle ok, port:22346, bCanRecv:0
watchdog timeout:5
DummyRead68013 0.000000kb
umount: can't umount /mnt/usb: No such file or directory
rmdir: '/mnt/usb': No such file or directory
[ 15.740000] davinci_interrDM36x initialization passed!
BootMode = NAND
Well this is what I did.
Ok. Looks good. Before it was booting the recovery kernel. Try now, and see if it boots the correct kernel!
Code:
That should hopefully change, so it now boots from 0x4a0000
Got this now
Created: 2015-06-23 9:37:05 UTC
Data Size: 4065664 Bytes = 3.9 MiB
  • OK
