Fly away, crash, and burn.
Liverpool, NY
I launched my new P3P after about half dozen or so successful flights. It hovered after auto take off, I gave it some altitude (30ft or so) as I searched for the waypoints path I wanted to run. That's when I saw my drone come tumbling down to the ground. I uploaded the flight record to healthydrones and it just shows I briefly lost GPS signal. Which files should I be looking at to determine if it was an internal error, or something else? Given my history with DJI repair, I'm skeptical to send it in.
Were all of the props attached when you found it?
What firmware version does the aircraft have?
gonna guess something hit it.. A bird, big bug, or a leaf from a tree, seriously it takes just a small thing to hit it for it to crash.
Doubtful it just fell
Reactions: Double_DoubleG
Perhaps one of your motors died then. Since Healthy Drones does not reveal much information, it's not going to be possible to determine what happened from the data displayed there.
Please try uploading your TXT flight log here. If you can see data displayed after uploading your log, then please post a link here so we can check it out. DJI recently started encrypting the log information, but I think it was after the DJI GO 2.8.3 release (which is what you're using).
Reactions: Lefty63
I don't remember what version it was. The battery was smoked, so I can't connect it to the RC.
You can remove the microSD card and view it with your pc. Open the MISC/LOG/and open the file P3X_FW_LOG_AB .
See images below. Once in file search for FW version which should be listed near the top.
I have demolished some large bugs, etc with my p3p and have never seen even a slight loss of control. Never heard of a leaf or anything like that causing a drone to drop.
Reactions: Lefty63
It would take quite a substantial object to cause a Phantom to go down.
Bugs or bees would just be squashed but the drone would not even notice it. I regularly need to wipe off stains and specks from bug strikes from my Phantom and have never noticed the slightest loss of control.
Birds would most likely avoid the drone unless they are deliberately try to attack it. You would definitely know that if it was the case, attacking birds tend to make quite a racket.
I would assume thay your crash was caused by a malfunction in one of the motors or in the ESC controller board.
// Tom
Reactions: Lefty63
It was in a wide open area, so no tree or wire interference, and unlikely a bird strike.
I'll check out the tips listed above when I get home from work.
Thanks.
msinger -
Here's the link from my flight log - Phantom Log Viewer - PhantomHelp.com
That's not gonna work, as I format my card after retrieving the photos and videos from each flight.
I download a copy of your flight log and converted it to view. You had App version 2.8.3. Looking everything over now. I need to go back and see what you said on this flight. It is a very short flight.
Reactions: Lefty63
Short, and sudden decent. All I did was auto takeoff, then raise it up a little to hover while I picked my waypoint path. Never snapped a photo or started a video. Next thing I know, it's tumbling rapidly to the ground.
From your description of the event you were trying to find a waypoint path but it seems you launched in GO app.... Had you opened litchi or another app or where you trying to open a saved waypoint mission in GO?
Your log shows no indication of a battery failure. It also shows your Phantom was rolling over and over as it fell from the sky. Since you confirmed you did not lose a prop and you did not see anything come into contact with your Phantom, I can only assume the crash was caused by either a motor or ESC failure. The internal DAT flight log contains data for each individual motor. Unless you can obtain that data, you're not going to be able to confirm any of the motors failed.
Reactions: Ross Marshall
Reactions: Lefty63
I use only the GO app, so Litchi isn't an issue. And no, my hands were just holding the RC, while I tried to load the waypoint route.
msinger, how would I obtain that data? The battery was smoking when I retrieved the unit. I'm leery about using another battery to retrieve data. Could it possibly be a warranty issue? DJI could retrieve the data, correct?
tpren3
