CRASH: P3Pro fell out of sky while in follow me mode.
Is that likely at night? Either way, it looks like I hit *something*. What I don't like is the disparity between the djilogs.KML and the HealthyDrones KML. If anyone has any insight on this I'm all ears.
DAT files update information at a different rate than the txt files in the tablet. There is far more data in the txt file (that we currently have access to).
here are the last 10 data points from the HealthyDrones KML. III% Streve can you show the last 10 from the KML you used?
-72.8666659396516,41.5224519878078,87.336377
-72.8667154996282,41.5223607525654,87.336377
-72.867083405733,41.5215142599319,87.436377
-72.8671259614371,41.5213926439304,87.436377
-72.8671699927971,41.521269988364,87.336377
-72.867221787014,41.5211308417789,87.336377
-72.8672766910178,41.5209751480216,87.336377
-72.8672953109449,41.520939965827,79.036377
-72.8672822647792,41.5209119456161,61.836377
-72.8672754330742,41.5208789361114,42.036377
ummmm... Sure. If you tell me how to get that out of the KML
-72.8672737433 41.5208887919 6.3
-72.8672752372 41.520883517 4.2
-72.8672754331 41.5208789361 2.0
-72.8672728696 41.5208796204 -0.1
-72.8672732916 41.5208788295 -2.3
-72.867266866 41.5208766101 -4.6
-72.8672668345 41.5208774827 -7.0
-72.8672619121 41.5208773516 -9.4
-72.8672568414 41.520877946 -11.9
-72.8672534941 41.5208831306 -17.0
There was a guy on the forum a week or so ago warning of the danger of altitude when using the follow me mode. The bird will stay "level" and hold its altitude from the original set point and will hit anything in its path if there is an elevation change.
It has come up a lot of times. People dont realize how much the what looks to be level really isnt. Easy mistake to make. And easy to avoid!
Those are from the txt log in the tablet
What was the peak height in your file? My guess is that HealthyDrones logs the raw height in meters, and the site you use converts to feet, which would explain the height discrepancy in Google Earth.
From your top coordinate I found that same coordinate in my log.. I have 97 lines of coordinates below that point in time
I peak at 47.6
At this log point: 11/15/2015 1:00:08 AM There is a switch to ATTI mode and "SPEED_ERROR _LARGE" and it goes down after that. Would this happen from a strike?
OK... this data is extracted from DJILogs.com after converting the txt file from the tablet. I found the first and last coords in your records to what I have and get this
-72.8666659397 41.5224519878 47.3
-72.8666704438 41.5224436722 47.3
-72.8666749669 41.5224353335 47.3
-72.8666794656 41.5224270603 47.3
-72.866684033 41.5224187176 47.3
-72.8666885143 41.522410436 47.3
-72.8666929142 41.522402173 47.3
-72.8666974078 41.5223938953 47.3
-72.8667019314 41.5223855959 47.3
-72.8667064853 41.5223772771 47.3
-72.8667154996 41.5223607526 47.3
-72.86671998 41.5223524053 47.3
-72.8667244392 41.5223440824 47.3
-72.8667288818 41.5223357525 47.3
-72.8667333614 41.5223274269 47.3
-72.8667378302 41.5223190149 47.3
-72.866746903 41.5223022849 47.2
-72.8667515272 41.522293911 47.2
-72.8669815967 41.5217907933 47.3
-72.8670621649 41.5215748034 47.4
-72.8670834057 41.5215142599 47.4
-72.8670895132 41.5214968761 47.4
-72.8670925292 41.5214882157 47.4
-72.8670986764 41.5214709203 47.4
-72.8671017244 41.521462186 47.4
-72.8671047636 41.5214535078 47.4
-72.8671078696 41.5214448455 47.4
-72.8671108878 41.521436161 47.4
-72.8671139705 41.52142751 47.4
-72.8671200239 41.5214100562 47.4
-72.8671259614 41.5213926439 47.4
-72.8671351174 41.521366522 47.4
-72.8671381874 41.5213577978 47.3
-72.8671445329 41.521340202 47.3
-72.8671475926 41.5213314487 47.3
-72.8671508102 41.521322645 47.3
-72.8671540459 41.5213138717 47.2
-72.8671572413 41.5213051063 47.2
-72.8671638036 41.5212874786 47.2
-72.8671668607 41.5212787372 47.3
-72.8671699928 41.5212699884 47.3
-72.8671733048 41.5212612242 47.3
-72.8671862639 41.5212264038 47.3
-72.8671895116 41.5212177541 47.3
-72.8671926623 41.5212090818 47.3
-72.8671960199 41.5212004213 47.3
-72.8672025874 41.5211830271 47.4
-72.8672091114 41.5211655792 47.4
-72.867212228 41.5211568797 47.4
-72.867218713 41.5211395494 47.3
-72.867221787 41.5211308418 47.3
-72.8672281719 41.5211133375 47.3
-72.8672437577 41.5210698082 47.4
-72.8672497531 41.5210524119 47.4
-72.8672527928 41.5210437482 47.4
Sorry its soo long, but it is what it is. And in that, I still have 97 lines of coords remaining after the point that your data stops
Which file are you using? I'm using the one the OP posted originally. Did I miss one somewhere? Also, what is the max height from your entire set of data points?
well I'm officially confused.
Max height from all points was 47.6
Using this data, from post #7
Interesting. What is the height at point 0? Are you subtracting that height from the max height in your file? Your max height is approximately my max height minus the starting height of 40.03. (This would be so much easier if those other log sites weren't blocked by my employer :()
Start height is 0
apktuti
