WiFi Wireless Repeater 2.4GHz 4W Signal Extender Range Booster Amplifier Antenna | eBay
Those are the ones.
Battery is this.Rechargeable Li-ion Battery 12V 3000mAh DC Power w/US plug charger ysd-12300 T | eBay
I cut the power supply for the amps and soldered onto the lines coming off the battery. There are also adapters you could get.
O.K. Now I am confused. I have the exact same amps, I think? I got mine from e-Bay and they were advertised as 4 watts each. I not only didn't get any more distance but found when I lost signal it look a LONG time to get it back. Usually 1.5-4 minutes into the automatic return to home flight. These work well for you? Have you tested them against other amps? I tried using them with my wireless home router and they did nothing for it either so I am baffled now.
I tested them with 3 different antennas BTW.
I messaged you back. I am in for testing. I also bought a MAXXUAV DBS-02 antenna that works great (best distance was 2.6miles) but I have not tried amps with it yet. I can test it against your panels and see what works better. I can also test with and without the black amps to see what difference it makes.Yeah, i use the exact same amps and they work great! I hate to say it, but i think part is the antennas you are running. The Alfa ones are not great .. and neither are the Rubber duck ones. Those all broadcast the signal 360° around you and not very far IMO (the dbi is low on those). They will help fight interference like tree's/bushes, but not get you distance. For that, you need a directional linear antenna like the CCP's or MaxxRange which is 14dbi+. I've also never heard (on a phantom atleast) that you would need an attenuator at all. Just amps and the antenna should work. I think its your antenna to be honest.
I mean, i used these amps and aCCP built panel antenna and I was able to get out to 71k and back with 100% signal score on HealthyDrones. If they work for me out to 13+miles, they should work for others! I think procharged97 was running these black amps for a bit as well. HealthyDrones.com - Innovative flight data analysis that matters
Ive not tested these against other amps, but they worked quite well enough that i didn't feel the need to invest in "good" amps like the Sunhaus.
I've an extra CCP build panel antenna if you wanna borrow it and test with your setup? Just gotta promise to ship it back eventually!![]()
That is a lot of money for some small antenna's. Kasper1 I've used the ( and a few others here too) the CCP's (your gray antenna's). I've gotten 22000 ft (4.16 miles) un boosted. If you did the connect right that make a big different for me. Lately I've been using the stock rabbit ears with a wind surfer. yesterday pushed it out to 21000 ft. Problem I'm having now it I can't see the dark red % of battery with my tinted glasses. I have an other controller with a DBSo2 on it. I keep running out of battery before I loss signal. I know DB I need to do a battery mod on the P3a. But it's newhttps://www.ebay.com/itm/321734496544
They are quite stiff, but works OK
Have also ordered those cheap 4 watt amps from e-bay.
First I was thinking of this: DJI Lightbridge Long Range Antenna Mod for 5-10KM flight (4 watt)
Maybe later...[emoji106]
Where did you get the parts to make those metal brackets from?https://www.ebay.com/itm/321734496544
RF Coax Pigtail Cable Convertor RG402 15cm 6in RP-SMA Male to RP SMA Male M/M | eBay
I figured it would be something like that. It is packaged nicely though. My best antenna so far is still the DBS02 I got from you. I did hook up my pair of black e-Bay amps and did seem to get just a little more distance. I Used my P3P in the woods this weekend to try and map out my friends hunting property and I learned real fast how much trees kill signal. Even at 500' I couldn't get more than 3,000' feet away before signal was lost and I got RTH several times. The real problem is I was having to aim up through trees.That "kit" just has two of the cheap eBay black boosters inside. Agreed it is all packaged up into a small "kit" which can be appealing but nothing special inside unfortunately.
For those interested in the nice pretty one like Dig has, I am working on a batch of them
Sent from my SM-G900V using PhantomPilots mobile app
Hi there, i do still do them upon requestOld post i know, but did you ever finish these? Or have any others available?
