Can't connect through camera...
I recently bought a P2V and have been struggling with the FPV. Are these boards available anywhere as replacements, or are you dismantling other cameras to make the repairs? Thanks for all of the help with this widespread problem.
@J Dot has been dismantling them and has a source and sure he will help or tell you shortly . He has helped me several times .
I did say several didn't I ? :)
Welcome to the forum !
Reactions: J Dot
Thanks! I appreciate the support. It is a great flyer, but I would like to be able to use the FPV features also. The forum here seems like a great set of resources. Looking forward to learning and contributing.
Hello
Welcome to the forum, Dirk sent me.
Unfortunately these boards are not avail. When the P3 was introduced, I started buying up cheap cameras. Some broken some working. Personally I use a working camera's components to test each board. But since this epidemic, I'm nearly out of cameras and parts. I do have a friend who is a great parts guy. But you'll need to figure out what board is bad before you start buying stuff. But hard to do without working components to test with. You can test wifi board with ( android InSSIDer app )
Turn on only phantom ( with camera set to wifi on ) open app and look for ( 60:60:1f:??:??:?? ) question marks are your Mac addy numbers/letters. 6 in all.
Make sure these numbers match your box or wherever you got your numbers from. And make sure they match the numbers bound to extender ( in vision app under settings, binding ) numbers should match if they don't manually type in numbers in binding procedure click both blue checks, reconnect to phantom wifi open app check camera. If you see NO signal ( 60:60:1f:??:??:?? ) than your wifi board is bad, if you get telemetry but no FPV only spinning circle thing, than top or 3rd board is bad. I've not seen board 2 ever go bad, except for SD CARD slot wearing out or damaged by inserting card backwards. Do some of this testing and get back to me with results.
Here is a video on all this:
Take care, Fly safe
J Dot
:cool:
Reactions: dirkclod
J.Dot... Took the P2V up for her first real flight since the camera replacement. FLAWLESS flights. Went through a battery with not even a hint of a problem. Thanks yet again...
-slinger
Reactions: J Dot and dirkclod
Thanks, J Dot for your description on troubleshooting. If I understand correctly, based on what you described, I am assuming my wifi board is bad (can see telemetry info, but no live video through the vision app). Picked up a used camera and will try experimenting with swapping the wifi board.
Thanks again for the help. It seems these cameras are getting difficult to come by, and there is no formal servicing offered outside of DJI. Will update if I am able to get it working with FPV.
Does anyone know how to fix the DJI vision app on the iPhone? because it's been bricking peoples drones and we can't get FPV.
Please help me! I have always really wanted FPV and when I got my P2V+ I was so excited to use FPV and guess what.... The FPV didn't work on The DJI vision app! Ever since the update
1.0.58, the DJI vision app hasn't been working! So please does anyone know how to fix this problem? (Again, I have an iPhone... Not an android)
Hello Everyone,
Here is some info I compiled, for those of you experiencing " PROBLEMS " after updating a DJI IOS app, to your smart device!
This is a step by step " HOW-TO " downgrade ANY iOS app , through ITUNES, using Charles Proxy " Web Debugger ".
You'll first need to download Charles!
Go to:
Charlesproxy.com
Download the FREE 30 day trial, ( just uninstall when finished )
Ok
Here is the video on how to do this:
Ok
Now I've compiled the numbers and placed them with APP versions and dates for you: ( you can search the app in iTunes, and search versions, and what each version has or has added ) too much typing for me, but this will help:
Ok. ( DJI VISION APP )
Use this number for this version:
15770051 ver. 1.0.19 ( July 19, 2013 )
23233090 ver. 1.0.22 ( Sep.20,2013 )
72532642 ver.1.0.27 ( Oct.08,2013 )
88632642 ver.1.0.28 (Nov.07,2013 )
176052660 ver.1.0.30 ( Dec.01,2013 )
289042895 ver.1.0.31 ( Jan.11,2014 )
300442650 ver.1.0.32 ( Jan.14,2014 )
519392631 ver.1.0.37 ( Apr.07,2014 )
585422641 ver.1.0.41 ( June24,2014 )
596284901 ver.1.0.41 revision " B "
642542793 ver.1.0.42 (July29,2014 )
706673865 ver.1.0.43 (Oct.28,2014 )
811174353 ver.1.0.46 ( Jan.23,2015 )
811505240 ver 1.0.46 revision " B "
811660004 ver.1.0.48 ( Feb.06,2015 )
813236208 ver.1.0.52 ( Sep.09,2015 )
813583643 ver.1.0.53 ( Oct.08,2015 )
814227950 ver.1.0.54 ( Nov.12,2015 )
814272310 ver 1.0.54 revision " B "
814418297 ver.1.0.54 revision " C "
815541257 ver.1.0.56 ( Jan.14,2016 )
815587449 ver.1.0.56 revision " B "
815735194 ver.1.0.56 revision " C "
Ok ( DJI GO APP )
810766904 ver.1.0 ( Feb.11,2015 )
811778986 ver.1.0.1 ( Feb.13,2015 )
811816666 ver.1.0.2 ( Feb.26,2015 )
812042400 ver.1.0.3 ( Apr.02,2015 )
812332348 ver.1.1.1 ( May05,2015 )
812459200 ver.1.1.2 ( May27,2015 )
812643015 ver.1.2.0 ( June26,2015 )
812940093 ver.2.0.0 ( Aug04,2015 )
812752484 ver.2.0.0 revision " B "
813037514 ver.2.1.0 ( Aug13,2015 )
813098150 ver.2.2.0 ( Sep07,2015 )
813521419 ver.2.3.0 ( Oct05,2015 )
813523578 ver.2.3.0 revision " B "
813665930 ver.2.3.0 revision " C "
813502052 ver.2.3.0 revision " D "
813321065 ver.2.3.0 revision " E "
813856913 ver.2.4.0 ( Oct21,2015 )
813919876 ver.2.4.0 revision " B "
813848230 ver.2.4.0 revision " C "
813876776 ver.2.4.0 revision " D "
814414870 ver.2.4.1 ( Nov16,2015 )
814445173 ver.2.4.1 revision " B "
814493632 ver.2.4.1 revision " C "
814584509 ver.2.4.2 ( Nov25,2015 )
814566170 ver.2.4.2 revision " B "
814760906 ver.2.4.2 revision " C "
815084483 ver.2.4.3 ( Dec18,2015 )
815086904 ver.2.4.3 revision " B "
815112170 ver.2.4.3 revision " C "
815288287 ver.2.4.3 revision " D "
815611197 ver.2.5.0 ( Jan10,2016 )
815615585 ver.2.5.0 revision " B "
815764145 ver.2.5.0 revision " C "
815878759 ver.2.5.1 ( Jan15,2016 )
815949783 ver.2.5.1 revision " B "
815876501 ver.2.5.1 revision " C "
816265475 ver.2.6.0 ( Feb02,2016 )
816232239 ver.2.6.0 revision " B "
816249216 ver.2.6.0 revision " C "
816547767 ver.2.7.0 ( Mar13,2016 )
816751249 ver.2.7.1 ( Mar15,2016 )
816962519 ver.2.7.2 ( Apr13,2016 )
817118268 ver.2.8.0 ( Apr25,2016 )
817278603 ver.2.8.1 ( May09,2016 )
817508323 ver.2.8.2 ( May25,2016 )
817522546 ver.2.8.2 revision " B "
Ok hope this helps!
J Dot
:cool:
Take Care, Fly Safe!
I use ( 1.0.48 ) first version to add vision plus. But feel free to experiment.
I wanted to also add fixing the app will not fix FPV if you upgraded the extender through the app.
( most likely gimbal mainboard ( plus models ), or board 3 is fried ( vision non plus models ). Will require repair or replace. The mods are working on a sticky on not to upgrade extender, as not to brick your FPV, in old app version 1.0.56, this version had a serious bug, causing all this CRAP!
Good luck to you ALL!
Reactions: dirkclod
Hello Everyone,
Go to:
Charlesproxy.com
Ok
Ok
Ok ( DJI GO APP )
Ok hope this helps!
J Dot
:cool:
Okay thanks, do you need to connect your iOS device and your computer with a USB cable to do this ?
Yes
Once older app is on iTunes, then just delete old app from phone, ( always good to power cycle phone ),
Hook to iTunes and load reverted app, via USB to iPhone cord.
Hope this helps!
J Dot
Added: phone does not have to be hooked to PC while reverting, only to load reverted app to iPhone from iTunes.
Reactions: dirkclod
Yes
Hope this helps!
J Dot
THANK YOU SO MUCH! I would give you $1,000,000 if I could! You would not believe how bad I wanted FPV! You give this advice to everyone who has an iOS device and a phantom 2 vision plus!
Reactions: J Dot
Either the wifi module or most likely gimbal mainboard is bad! You can test the wifi module with ( InSSIDer app ( android )) look for
( 60:60:1f:??:??:??)
If you get this signal than wifi module is good ( mainboard of gimbal is bad ) if no signal than module had failed!
Does it say connection to phantom failed?
J Dot
Hope this helps!
Reactions: dirkclod
J Dot
Hope this helps!
Yes
J Dot
Hope this helps!
On The DJI vision FPV, it says that. It also has the signal you were talking about, 60:60:1f:??.??.??
Than you have a bad mainboard in your gimbal, I've seen it time and time again!
Search " DJI vision gimbal mainboard " to find a replacement.
Hope this helps,
J Dot
:cool:
Reactions: dirkclod
Even though the DJI vision downgrade didn't work, I still want to thank you for helping me. Hopefully after I replace the gimbal mainboard... My drone will work!
Reactions: J Dot
Hope this helps,
J Dot
:cool:
Base on all the info I read from you Im almost sure my 3rd board of my fc200 camera is bad it has "most recently ( #3 board ) burnt. Not 100% sure what that board does? ( I'm guessing a processing board for FPV as I was getting telemetry but no live feed, same as cam board burnout" Note: camera working excepted FPV has no live view. I can take pictures and video blind. I've taken the camera apart looking for something burn or broke. If you have a good board 3 let me know. I like this camera over the new ones. Also I've taken pictures of all the broads just not sur of the rules of uploading images. If members like I will up load the picture. Can you post a picture of a bad board 3? Thanks All! ( The board question is to member J Dot )
Ok
Here is a breakdown of a fc200 p2v non-plus camera
This is a picture with top plate, and rear cover removed! From here out boards are in order top to bottom ( even though camera is upside-down ) top board #1 board, bottom #4! Ect.
Ok
1st thing you remove are the 2 screws holding the camera lens unit and board on. Located 1 each side of camera base, Phillips screws. ( must lift clip on board #1 to remove ribbon cable )
Camera lens unit
Ok now remove 4 small Phillips screws ( 1 on each corner of board )
Carefully pry board straight upwards to unlock, and set aside.
Board #1 camera board
Next remove 2 small Phillips screws opposite side of board #2, ( power board ) carefully pry up and away ( be extremely careful with this board, as the cooling fan leads attach to it, and can break easily ) gently lay over the side of camera for now.
Board 2 ( I removed fan, fan good, board is bad ) but only for picture purpose
Ok
Next is board #3 ( culprit )
This requires a small flat screwdriver, as they are special screws, remove 2 post screws, pry board up and away!
Board #3 ( this is board that fries )
I believe the processing board?
Ok
You should not need to go further, but if you do,
Remove 2 Phillips holding metal housing into camera top shell, remove housing with board #4 attached
Turn over, remove the 4 Phillips screws holding board #4 to housing
( take special note, if you SEPERATE this board, you'll need thermal paste for reassembly, goes between IMU/housing , you'll see the white dot )
Board #4 ( wifi board )
Hope this helps!
J Dot
:cool:
Reactions: dirkclod
jorge sanchez
