- Joined
- Mar 4, 2018
- Messages
- 110
- Reaction score
- 22
- Age
- 44
How many times can you charge a p3s battery before you need to replace it ....
Any concerns with respect to over discharging relate to flying the packs close to fully depleted state rather than full application of the throttle in flight.You can essentially use it until it stops charging. It will stop charging when the cells are no longer able to accept the balanced current from the charger.
More often than not, one cell will go bad, and then the whole battery is toast. As was mentioned, if you properly maintain the battery, there is no reason for the battery not to last for many years.
Environmental factors that can influence a batteries life are extremes of heat or cold outside of manufacturers specs, damage to any of the cells, and over-discharging such as repeated and deliberate full throttle takeoffs and braking.
I have found DJI batteries to be made of very good quality materials and I make a habit of never buying aftermarket, generic batteries.
Not true.... The flight controller ensures that the ESC are not commanded to deliver thrust at a level that might damage the AC. You cannot exceed the design paramaters coded into the software. As you have observed, the cells in these packs are good quality, a 10C discharge rating is no issue for them, something you won’t even get close to in full throttle application. In any case the BMS will limit current delivery if it is determined that the battery is in poor health.EDIT
Sorry but I dont agree. You can damage the battery and possibly other components by going from hover to WOT enough times. DJI Go will not let you fly to a fully depleted state if you have your RTH settings correct.
Under ideal circumstances and proper maintenance, it is possible to achieve 200 cycles. Bear in mind that is only an estimate and the battery MUST be properly maintained to get close to that.
Check out this post for more information on how I maintain my batteries.what’s the best way to do this bearing in mind I only have one battery discharge over 10days or 5
See Post #10 ( I keep mine at 2 bars at all times when in storage).Is there an actual list of the 'best practices' for long Lipo battery life?
