I'd have to ask the same question, I use fat shark dominator v3 and they are good for me but even they aren't the best,,,
Intriguing concept, but given the range of optical adjustment (+1 to -7 diopters) they really aren't going to be usable for anyone over the age of about 45.IMHO I think the Avegant Glyph are the best
I do have to agree with wrathorkahn, Glyph are the best, in fact it's on my Christmas list for my wife lol, but I'm also getting the goggles for my Magic as well!
Congratulations on your eyesight. You are clearly the exception for a 70 year old with presbyopia. Average correction for someone 50 years old or older is +2.3 diopters. Glyph states their adjustment won't go any greater than +1 diopter. That won't work for the majority of people with presbyopia.Well that is quite frankly, rubbish, I am almost 70 and they are absolutely pin sharp for me and I think you will find that on the Avegant website there are NO reports of anyone having problems with focus.
My eyes are such that anything less than 12 inches from my eyes gets progressively blurred as it gets closer.
If you can focus at 12 inches, your presbyopia is extremely mild for a 70 year old. My distance vision is 20/20. I'm younger than you and I require a correction of 3.25 diopters (sphere) in order to see "pin sharp" at 12 inches. That is about average for someone over 60. 3.25 diopters means Glyph is not going to work for me.Not sure where you are going with this but I can assure you that I do suffer from Presbyopia quite seriously, ie, blurring vision of things less than 12 inchs,,, especially newspaper, books etc are totally blurred.
Yet, I have no problem in focusing the Glyph to pin sharp.
There is obviously more going on here with the Glyphs Technology than you understand to apply to your theory that they are pretty much useless to anyone over the age of 45.
It would make no sense for Avegant to make the Glyph BUT only suitable for the people under 45 but if you are concerned or need further enlightenment why dont you contact Avegant directly or go on their forum where help is plentiful. Avegant Corp | Portal
i
Where I'm going with this is that Glyph says that their optical range is +1 to -7 diopters. Average correction for someone over 50 is 2.3 diopters. According to Glyph's website, their glasses won't work for the majority of presybopes because their glasses are outside their ability to provide correction for that degree of presbyopia.
I'm 53 and my eyes need +6 to see something 6" from my eyes. With Headplay googles the standard Fresnel lens options that come with the google won't work. I replaced the Fresnel lens with a Carson clip on +5 diopter lens (the strongest available). I simply removed the Carson lens from the provided clip mechanism, then nylon tied the lens to the top of the google using the headband peg, which happens to be the right position. With the +5 Carson lens I can use my standard reader glasses with the Headplay google to fly crystal clear. My optometrist says I'm average for eye muscle degradation with age. Getting old eyes sucks.
FYI, I tried the RHO lens replacement lens for the Heaplay Fresnel lens. Although the lens was very high quality, and expensive, it wasn't strong enough to work for me as a replacement to the standard Fresnel lens. The mounting of the lens was also mickey mouse, I had to fabricate my own frame inside the google just to hold the lens. Although my frame worked, the lens power didn't. RHO doesn't offer multiple choices for power grade, and what they offer wasn't powerful enough. The Carson lens is cheap in comparison, and is strong enough to work good with my eyes.
Why dont you contact Avegant direct with your findings,
I did just that. They got back to me this afternoon...
As I said, average presbyopia correction for someone over age 50 is + 2.3 diopters. Glyph's range is +1 to -7, so, going just by the numbers that Avegant provides....no worky.Hello MacCool,
Our current adjustments are found below .
• Diopter Adjustment: +1 to -7 range
By the sounds of it , you most likely would not have a very clear picture with your prescription .
I am setting the case to resolved but you may reply to this email and it will open the case again.
Thanks,
Christian Hayes
Well, that sounds promising. I've had to alter the Headplays a lot to get a clear view. They work OK, and they are the least expensive I've see with 720 resolution to match the downlink. However I'm not in love with them, they are quite big.Yep I was about the same as you with the Headplay and I also got the RHO lens and after much mucking around I found the optimum position for those lens AND left in place the Fresnel lens,,, I then used a clear mastic to secure the RHO lens in place semi permanently. The result was the best picture quality to date and all in focus.
And then I got the Avegant Glyph,,, WOW that was a massive improvement in the Focus {looks like 1080p & NO pixels}, the colour was so true to life, I no longer have this massive Headplay blob on my head, I can see up & down and be aware of people around me and look ahead to FPV.
As I said previously, best Goggles ever.
John
So is this below the google you're referring to? If those work, then I'm going to check them out. Those are much smaller. I assume you don't use glasses, right? I don't see how it's possible to use glasses with those, so I would be totally dependent on the adjustments in the google to compensate for my need for glasses.
I'm wondering if they mis-spoke and quoted the diopter spec backwards, and it's really -1 to +7. That would make much more sense. However in this webpage they clearly state +1 to -7.
