Taking the next step ( mods galore ) update 3/25/15!
Re: Taking the next step ( mods galore ) update #1,2,3+!
Hey J-Dot....do you have a link for that plug n play gimbal? Thanks....
Re: Taking the next step ( mods galore ) update #3/21/15!
Hello everyone,
Here is what I've done so far, still having battery trouble ( battery #1 ).
Guess it is done? Battery #2 is working perfectly!
( still waiting on a few items to finish build )
Ok here it is ( so far )
I did notice, my GPS 4mm patch antenna upgrade, I get sat lock INDOORS, I don't get more sats, or lock quicker, but I DO get a STRONGER SIGNAL! Very cool!
I only ever got 0 indoors,crazy!
My controller is here, with capacitors, just waiting switches, shrink tube ( 1/16 inch ) also waiting a few more minor items, I'm going to do FPVLR Stage 4 setup! Ordered antenna brackets, SMA 90 degree adaptors, cables, ect. Will keep you posted!
Take care, Fly safe!
J Dot
Ok,
I give up, I cannot figure out how to make my
YouTube video work here?
So
Here is a direct link:
http://youtu.be/dIrvalXM_s0
Wanted to add:
Aborting copper foil mod, I'm going this route instead:
[youtube]http://www.youtube.com/watch?v=dIrvalXM_s0[/youtube]
Hey I got it? WTH?
My original link copied straight from YouTube, on my iPhone 4s,
Is this
( http://youtu.be/dIrvalXM_s0 )
I had to change to this for the video to work HERE!
( http://www.youtube.com/watch?v=dIrvalXM_s0 )
Why is that?
Take care
J Dot
:lol: Love the patch !!!
:?: Did the orange leg spacers give you any issues as far as the length of the cable with the new compass hooking it back up ? The new patch booster you show..did you have that on when you did the antenna test and ya coulda made the vedio a little longer ! ;) Looks great :D
I know ? ? ? ;)
Hey Dirkclod,
Lol, ARRRGH MAITEY!
The spacers are 14mm, everything worked,
Just enough cord but the spacers had to be modded
A bit, holes too small, radius too large, screws would
Not line up, but I got it, FINALLY!
The patch antenna,
After I installed it, did not see much difference,
Same # sats, in about the same time to lock. I was
A bit annoyed, expected better, but I have a bad battery
Issues with one of my batteries ( that is a different story )
So while I'm trying to kill the battery completely to try to
Cycle it, to see if it still fails, I was Inside with phantom on,
I got 7 sats inside and home lock? I've had it on in the house before
Doing the same thing with 0 sats, so there is an improvement there,
But I think it is more signal strength, than anything else!
Video:
I know short, but remember above ( bad battery issue? )
I was trying to take some video with new gimbal, that IS that
Video, unfortunaly, that is all I got before phantom came down hard!
( I edited that part out! ) lol, did not want to look like a:
Especially, trying to post a review about a new fangled gimbal,
" yeah here is the new gimbal, CRASH, whoops )
I'm going to take a better video, maybe tomorrow!
But at least you can see how stable it is, even if it is
Short as hell!
He he, take care, ole' friend,
Fly safe!
J Dot
( hey Dirkclod,
We're you talking about the fpv booster insert?
Sorry, did not have it during test, still waiting delivery! )
:lol: I understand now and it does look good and stable !!
The GPS booster has me puzzled though . It looks like from the picture it is on a plate that is just suspended between your puck and your electronics ? If That's the case do ya have a link to it as I would like to look closer at it .
Hey if worried about looking like a JA I would take up the whole screen and then some ;)
Thanks ? Dirk
Hey ( Dirkclod )
Here is the info:
Link to eBay auction
http://pages.ebay.com/link/?nav=item.view&alt=web&id=251887316481
This is a nice review, from a notable source: Simon Newton
[youtube]http://www.youtube.com/watch?v=8Qp2Xdc4DfQ[/youtube]
Hope this helps,
Your friend,
J Dot
Re: Taking the next step ( mods galore ) update 3/21/15!
J dot - do you have a link to the gimble you bought? It's exactly what I want.
J Dot -
Ordered the exact same camera gimble. So how hard is it to install? Is it basically plug and play or is soldering involved.?
Robb said:
J Dot -
Hello Robb,
NO soldering, plug -n-play!
Basically,
1) unplug white wire from Fc200 camera ( thick round white wire )
2) unhook 4 anti-jello balls
3) unplug servo wire
4) set camera assembly aside
5) unscrew 4 Phillips screws, remove gimbal base from bird
( put all extra parts in a ziplock ) mark it ( stock parts )
6)camera assembly
A) remove rubber plug to reveal small Phillips screw on side of camera egg top
B) remove screw
C) pry insert out with small flat screwdriver 0-1 size ( very small flat )
( push insert ( servo adaptor ) out same direction screw came out )
D) separate camera egg from servo plate
( put these parts in same ziplock bag )
E) remove 4 hex screws bottom camera egg
7) mount egg ( fc200 camera ) to new gimbal ( screws supplied )
8) separate new gimbal plates ( off anti-jello balls ) we want top plate
9) mount top plate to phantom ( 4 screws supplied ) ( NOTE: BELOW )**
10) reconnect anti-jello balls to top plate ( top plate to bottom plate gimbal assembly )
11) plug in servo plug
12) plug original white round wire to adaptor wire ( supplied )
13 plug other ( head phone jack end ) to fc200 camera
14) plug 2 red power plugs together
15 ) zip tie everything to keep it neat and clean
( make sure camera can move freely all directions don't get wires too tight to keep camera
From moving full tilt )
16 ) power up bird ( gimbal takes a few seconds extra to boot )
17 ) check tracking by moving bird with your hand, tilting up-down, left, right, ect.
18 ) set limits ( NOTE: below )***
Note ( ** )
I ran Into an issue here, where top plate covers hole in bottom of phantom, leaving ONLY
the tiny circle hole in gimbal to access wire. Hole is smaller the servo plug end! I had to
Take wires out of plug end, pass wires though hole, and reassemble plug after installed top
Plate! ( take a picture of plug BEFORE disassembly, so you can put it back correctly! Pretty
Easy, just take your time! I showed pictures s couple pages earlier, I used a safety pin for
Disassembly!
NOTE ( *** )
After install , my gimbal went too far up ( hit bird belly ), and too
Far down, way past straight down! So I had to reset limits!
Default is ( max 1000, center 0 min -450 )
I did this
( max 900, center 0, min -250 )
This gave me just enough up to barely see arm of phantom , and STRAIGHT DOWN )
Hope this helps!
J Dot
Re: Taking the next step ( mods galore ) update 3/23/15!
Hello everyone,
I bought these props ( Orange self tightening )
eBay auction link:
http://pages.ebay.com/link/?nav=item.view&alt=web&id=390953102061
I'm not sure if they are different pitch ( look the same to me ) only difference is they are thicker/stronger props, don't bend as easy as stock!
I ran into a serious problem with them
1st:
The black counter clockwise props screwed right on, but the silver clock wise props were a VERY tight fit, felt like I was going to strip them out, puting them on, BUT the bigger issue
Is,
2nd:
With them on, phantom lags ( like it is carrying a load ) response time, like 0,
Phantom can't even get out of its own way? I almost crashed!
I was descending from an aerial shot, and when I wanted to level out, about 15 feet up, it kept coming down, I gave it 100% throttle, the bird came all the way down, just touching grass, before it finally pulled out of it? I tried again, same thing ( much higher this time to be safe )?
Then I tried rapid ascent, more like slow gradual climb!
I put white stock props back on, and it was back to its snappy self, rapid climb. Quick stops, very responsive!
So
Either these props SUCK or are simply different pitch ( too much for older style motors to handle )?
They look exactly the same as originals, but that is with blind eye!
I will NOT be using them again, but will display as they look nice!
Just a heads up folks!
Take care, Fly stock! {:0)
J Dot
Hello,
I got my ( toggle switches DPDT ON-ON ) and, my resistors as well, to do my slow pitch, slow yaw mods. Here are some pictures:
Will keep you updated!
J Dot
Thanks man! It should be here in a week or so.
Your instructions will be a HUGE help.
How do you like the video compared to the stock camera mount? Worth the $100?
Worth every penny! A lot more stable, you don't get dizzy watching the video playback.
You might need leg spacers or extended legs! I used to launch from my grass, but gimbal so low,
It would bounce while landed, so I started launching off a stepping stone, you have to keep the camera
Almost level upon takeoff to keep from twitching, now with spacers, I don't need to be so particular about it!
It does work with stock legs, but barely! Lol, I still love the gimbal, I just bought a second one as spare! Going to
Sell China gimbal! ( don't care for it ). Solder and what not!
Take care, Fly safe,
J Dot
Just ordered one too ! Thanks again for the link and assembly tips @J Dot. Guess I better get the leg extenders too.
J Dot....quick question.....you mentioned new plate covers phantom bottom and only has a small hole....from what you noticed could I remove plate from gimbal assembly and drill a larger hole ? Thanks
