Remote status light flashing green
Hello,
I can no longer connect the Phantom 3 Pro remote with my phone (android) / tablet (iPad) app anymore.
I tried reinstallnig the app and when I select the drone model I don't get the "view camera" button after turning on the remote and the drone.
After turning on the drone the remote goes from solid red to flashing green (instead of solid green). I tried re-linking the remote with the drone and again it goes from red to green but not solid.
When I connect the remote to my phone the phone says it's charging (USB C) even though I now changed the setting so that my phone should by default go in file transfer mode.
On the drone I have the Firmware v1.11.20 and now if I try to update / flash that one again I fails after just a few minutes (solid red light on the gimbal and continuous beep sound) so I'm basically stuck.
Code:
========== 2021.01.23 13:33:02 =====================
Packet: P3X_FW_V01.11.0020.bin
Result: Failed.
Reboot the aircraft and try to upgrade the firmware again.
(this is without forcing "debug mode" but I also did try that)
This is the last part of the detailed logs within "MISC\LOG":
Code:
[00015496]========== remo-con disconnect. boot(15) ============
 [00015576]Packet [C:\P3X_FW_V01.11.0020.bin] detected, card sn [0x2d51ac11].
 [00015666]Packet upgrade start...
 [00015876]Packet checking...
 [00015961]Packet vlink 01.11.0020 <-> 01.11.0020.
 [00016048]Record vlink 01.11.0020 <-> 01.11.0020 (flow = 0).
 [00016138]Done.
 [00016296]Version checking[1]...
 [00028885][03 06][00] device not detected.
 [00041468][03 05][00] device not detected.
 [00041564][04 00][00] v1.48.0.0 -> v1.48.0.0
 [00054148][11 00][00] device not detected.
 [00066827][11 01][00] device not detected.
 [00079410][12 00][00] device not detected.
 [00091993][12 01][00] device not detected.
 [00104593][12 02][00] device not detected.
 [00117178][12 03][00] device not detected.
 [00129882][15 00][00] device not detected.
 [00142466][17 00][00] device not detected.
 [00155048][17 01][00] device not detected.
 [00167630][19 00][00] device not detected.
 [00167712][01 00][00] v1.32.5432 -> v1.32.5432
 [00167793][01 01][00] v1.32.5432 -> v1.32.5432
 [00180376][08 00][00] device not detected.
 [00180476][09 00][00] v0.0.0.0 -> v4.1.0.0 need upgrade.
 [00180558]Done.
 [00182643]Waiting for user confirm...
 [00192725]Timeout, start upgrade automatically.
 [00192893]Firmware upgrading[1]...
 [00193008][09 00] Firmware upgrade start...
 [00245182][09 00] Firmware upgrade finished successfully.
 [00245348]Done.
 [00245442]Version checking[2]...
 [00245551][03 06][00] v2.4.20.50 -> v2.4.20.50
 [00245671][03 05][00] v34.2.0.9 -> v34.2.0.9
 [00245760][04 00][00] v1.48.0.0 -> v1.48.0.0
 [00245911][11 00][00] v1.8.0.0 -> v1.8.0.0
 [00246071][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
 [00246152][11 01][00] v1.8.0.0 -> v2.0.0.33
 [00246281][12 00][00] v1.12.0.0 -> v1.12.0.0
 [00246407][12 01][00] v1.12.0.0 -> v1.12.0.0
 [00246540][12 02][00] v1.12.0.0 -> v1.12.0.0
 [00246671][12 03][00] v1.12.0.0 -> v1.12.0.0
 [00259253][15 00][00] device not detected.
 [00259390][17 00][00] v1.1.1.7 -> v1.1.1.7
 [00259555][17 01][00] v1.0.2.7 -> v1.0.2.7
 [00259660][19 00][00] v1.0.8.96 -> v1.0.8.96
 [00259751][01 00][00] v1.32.5432 -> v1.32.5432
 [00259836][01 01][00] v1.32.5432 -> v1.32.5432
 [00272433][08 00][00] device not detected.
 [00272541][09 00][05] v4.1.0.0 -> v4.1.0.0
 [00272628]Packet upgrade failed at version checking.
Any idea?
Many thanks
billyboy02
