- Joined
- Apr 13, 2018
- Messages
- 110
- Reaction score
- 67
- Age
- 68
Does it outside after rotors start up, absolutly nothing around aircraft for 75 feet... unless your thinking downward sensor... if so, after three years ownership why would it start now?Proximity sensor warning.
Yes... no changeHave you tried a sensor calibration? May be something amiss with one of them sending erroneous info
While I truly appreciate the responses... Yes I have re calibrated the sensors with app successfully, twice... I understand the beeps indicate sensor alert... no, there is nothing blocking nor closer than 75+ feet away, even carefully cleaned the sensor lenses. I am flying from my launching pad at home where I have 100 plus flights with no issues. Flew 4 times day before without issue. Tried 4 different fully charged batteries... screen shows all functions ok.... disconnect remote from drone and reconnected... baffled Even at 100 ft AGL it continues to rapid beep... only settings changed were camera shutter speeds, Never crashed nor has it ever had a hard landing...Rapid beep sensors, slow beep remote sticks calibration. Something is in the way of sensors or sensor calibration required.
Yes…Just a shot in the dark, there may be a problem with the sensors in the end, but did you try calibrating them with your PC?
